Question about Ye Data YD-702D (850416000107) Internal Floppy Drive
IE DATA 702 fdd
I sold in the 80'/90' a lot off machine FACIT N1050 / 1060 for CAD/CAM and CNC applications. This machine include a floppy IE DATA product number 702 6037. The standard PC's floppy don't work in those machines. Did you now a totaly compatible floppy with this old model and where i can buy it if possible in Europe.
Thank you for help
P.Borel
WE HAVE THE PRODUCT YE DATA 702 6037, IF YOU WILL BUY THAT GOING TO OUR WEBSITE Goaagle.com. or sent sale#goaagle.cn.
Posted on Feb 12, 2009
I have one Usb Converter, Which converts Floppy to USB Pen drive. The device is same as Floppy disk drive and have same connector but in place of you insert floppy disk, You have to put a USB pen drive.
You can use this to solve the problem permenantly.
You can mail me on malav_ahd@yahoo.com
Posted on Jul 30, 2008
  • 13,433 Answers
Hello
I beleave it uses a HD/DD type of disk
Abbr.
Floppy Disk Type
Capacity
Info
SS/SD or 1S/1D
Single Sided, Single Density
100 K
First generation. Capacity varies
SS/DD or 1S/2D
5-1/4 inch Single Sided, Double Density
180 K
DD/DD or 2D/2D
5-1/4 inch Double Sided, Double Density
360 K
Most common type in the early 1980's
DD/HD or 2D/HD
5-1/4 inch Double Sided, High Density
1.2 Mb
DD
3.5 inch Micro Floppy, Double Density
720 K
Hard plastic case
HD
3.5 inch Micro Floppy, High Density
1.44 Mb or
2.88 Mb
Hard plastic case
Posted on May 05, 2008
FDD Y-E Data YD-380B Repair RFQ
I have a YE Data YD-380B disk drive. I/O error is appeared when it try to read floppy. How can I solve this problem
thanks
mehrdad
Jun 12, 2013 | Ye Data - yd-380b - Yd-380b 1.2mb 5.25...
How can I connect an internal FDD to a computer whose Floppy connector is larger than the FDD cable connector?
Hi Skuddle.
Try looking on eBay and Amazon, you can usually find what you are looking for. You should be able to find something, if not Google it. Hope this helps.
May 27, 2017 | HEWLETT-PACKARD HP Pavilion dv2-1033cl...
Hello! I have a Floppy Drive FD-235HG-C332 manufacturer TEAC. I want to know what data capacity (Operations modes) has my device: 720Kb, or 1Mb, or 1,44Mb, or 1,6Mb, or 2Mb. There are jampers, placed...
Your TEAC FDD (floppy disk drive) is a Tri-mode device (720 KB, 1.2 MB, and 1.44MB)
The "235" part of the model number indicates the drive's form factor (size) is 3.5 inches.
The "HG" part of the model number indicates that the FDD is a Tri-mode device, with the 3 modes
given above.
The manufacturer notes that it has no jumpers, but every FDD I've ever seen has jumpers for
bus master/slave selection. Either master or slave will work.
Here's the manufacturer's web site URL for your TEAC floppy disk drive:
http://www.teac.com/DSPD/support/floppy_drives/fd235hg_id_your_drive.htm
Here's the info on the NEC FD 1137C drive:
Enclosure Type Internal
Interface Floppy (IDC)
Platform: PC
Technical Features Capacity 1.44 MB,2.8MB,360MB,720KB,1MB,640KB
Minimum System Requirements:
Operating System Microsoft DOS • Microsoft Windows 3.1 • Microsoft Windows 95 • Microsoft Windows NT
Form Factor: 3.5" floppy disk drive
Here's the best info I found on your NEC FD 1137C Floppy disk drive:
http://www.aliexpress.com/fm-store/602209/210081532-394871196/NEC1137C-DATE1992-floppy-Adaptive-720K-1-44M-120M-Capacity-120M-40PIN-Interface-3PIN-Jumper-FD1137C-NEC1137C.html
May 13, 2011 | Teac Floppy Drive 235HG (FD-235HG) Floppy...
How to set sharp pc ax40 laptop bios to boot from usb flash drive?
Sad to say your model "Sharp pc ax40 Series laptop" does not support the "Boot from USB devices" options from the Bios.
It uses the "Floppy Drive 3.5" 1.44 MB floppy - External" ie portable FDD booting options.
Hope it helps.
Apr 03, 2011 | Sharp PC AX40 Notebook
What is floppy disks .and how its working.amd what is its usesatll m urgent.ok
Old PC and Laptop used to have software and device driver delivered on low capacity (usually 1.44MB 3.5 in) 'Floppy' disk diskette (FDD):
'A floppy disk is a data storage medium that is composed of a disk of thin, flexible ("floppy") magnetic storage medium sealed in a square or rectangular plastic carrier lined with fabric that removes dust particles'.
Newer machines usually will not come with FDD drive as we now use CD or DVD or even external USB stick/storage instead. If a FDD is required, you can get an external USB connected FDD as a standard FDD drive will require the support of a specific FDD adapter.
Hope it clarify your question.
Jan 23, 2011 | Computers & Internet
I am looking for floopy disk driver for Windows XP
What floppy disk driver do you need? The driver is already in the WinXP system when you install the Windows itself.
If your system cannot see the floppy disk ie "A", most probably it is disabled in the "BIOS settings". Check your "Bios Settings" first to ensure the "FDD" feature is enabled. Check the cable & power cable connecting the FDD too.
If your PC still cannot detected the Floppy disk, most probably your FDD is faulty.
Hope it helps.
Oct 20, 2010 | Computers & Internet
How to remove write protection in my USB?
if it is really a case with external floppy drive...
check the FDD first .
a 3.5 in FDD has asmall **** to be turned up and down that makes a small rectangular hole Visible/Invisible- THis is the write protection for FDD.
similarly with a 5 in FDD which hardly may be the case,
a sticker has to be attached on small cut in any of the 4 rectangular edges you may find.
its nothing to do with the Floppy drive.
Rate this solution an comment to keep in touch.
Sep 16, 2010 | Digital Research UNIVERSAL SERIAL BUS/USB...
Hello, Do you have a way to replace the JA-751 8 inch FDD by other one as CF card,...... Thank you. Weng Canxin
you can replace your matsuhita floppy disk drive by a DTX200 floppy disk drive emulator ,that work perfectly,no more trouble ..sincerely
Sep 15, 2010 | Matsushita Computers & Internet
I want to convert to usb drive a model pa2669u fdd . are there any converting cables for this? thanks joe shimchick
Thats looks like a proprietary connector, you will not find a cable that will convert that fdd to USB, sorry :|
Anyway I doubt the cable would be much cheaper than a new USB external FDD.
USB FDD on EBAY $10
Mar 21, 2010 | Toshiba (PA2669U) External Floppy Drive
Canon printer MP110
ok clink the above link directly
Nov 16, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Ye Data YD-702D (850416000107) Internal Floppy Drive Logo
584 people viewed this question
Top Ye Data Computers & Internet Experts
David Payne
David Payne
Are you a Ye Data Computer and Internet Expert? Answer questions, earn points and help others
