Question about Kenmore HE2 Plus Front Load Washer
When i wash clothes in my LG front loader it sometimes smell like rooten eggs,and my clothes never smell good no matter what detergent or softner i use...help
  • 4,102 Answers
Hi, it sounds like it has had standing water in it and this has caused mould to build up inside the machine the best thing for you to do is get some old towels and put them on the hottest wash setting not quick wash bot hot was use powder or liquid and put 3 or 4 table spoons of salt inside with the towels doing this softens up the mould and should solve your problem.
after doing that wash cycle check and see if the towels come out smelling good or not,
if they do you need to remember that their is always a small amount of standing water sitting inside the machine at all times so if it is not going to be used for a few days then the best thing to do is to leave the door slightly open doing this will prevent the build up of mould due to their being air circulating.
let me know how you get on or if you need further assistance ok
good luck and you should have no problems after doing the above
Posted on Aug 24, 2010
Top load washer smells like rotten eggs when water is draining into tub
As someone who has had a deep well drilled and found water, but water contaminated with iron and sulfur, I can tell you first hand about the rotten egg smell. The water softener will remove the iron that can turn clothes orange, but doesn't do anything to remove the rotten egg odor. You will need a charcoal (carbon) water filter to eliminate the sulfur smell.
Sep 19, 2014 | Whirlpool WTW8600YW: 4.6 cu. ft. Cabrio...
SMELLY washing machine
First i hope you have cleaned out your filter. For the smell: Switch from liquid to powder detergent, no fabric softner, not necessary. Clean the big gasket with detergent and run a half load (without clothes of course) very hot cycle with 2 cups of vinegar only. Leave the door open whenever possible. This helps in drying out your washer and preventing mildew. Shut your wall water valve after your wash
Click helped if really helped.
Apr 09, 2013 | Whirlpool Washing Machines
Washing machine smelling
First i hope you have cleaned out your filter. For the smell: Switch from liquid to powder detergent, no fabric softner, not necessary. Clean the big gasket with detergent and run a half load (without clothes of course) very hot cycle with 2 cups of vinegar only. Leave the door open whenever possible. This helps in drying out your washer and preventing mildew. Shut your wall water valve after your wash. Actually you can search by clicking on "ask anything" indicating your problem, this site.
Clothes stink
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hope your filter is clean. Don’t wait for the machine to jam to look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use very hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Put the Affresh pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
May 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have an LG front loader. It washes fine, drum is clean ... no smells in the drum. After each load, I have a huge bowl of water that I have to get out of the little black hose (left side bottom). It...
There will normally be a few cups of water left in the hose although it should not smell very bad though as this water from the last rinse and should be fairly clean. If the drain is connected to the drain under a sink make sure the hose goes up as far as possible then down to the washer.
Apr 19, 2010 | LG WM-2277HW Front Load Washer
My samsung wf448aap washer leaves clothes smelling like wet dog???? Using HE Tide and Snuggles still when they are done they smell.
vinegar apparently is good for using in a machine instead of fabric softner and will remove unwanted smells as well
Jun 11, 2009 | Samsung WF338AAB 4.0 cu. ft. Front Load...
Washer smells bad
Whirlpool and Tide make a cleaner that you put into the washer and run it through a cycle. Front loaders get a build-up that cannot be cleaned by hand. Make sure you are using a detergent that is marked "HE". Do not overfill the detergent or softener cups. I've heard that other used a lot of bleach in a wash cycle to clear out the smell. Bleach is bad to use if you're on a septic system, though.
May 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
LG TROMM - awful smell while washer is running
Use the aafesh tablets as instructed, this will clear hoses that have developed some mold, also inspect drain at the wall, these get moldy and as machine runs, smell comes out of there as well.
Jan 20, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Rotten Egg Smell
Make sure the rubber door gasket is clean. Pull it back and clean under and around it. The gasket will collect dirt and begin to mildew causing various odors. Run the machine empty, boil a medium pot of water to almost boiling, then put it in the machine during the wash cycle. This will help clean the lines, during the rinse cycle place a 1/2 cup of vinegar in the unit. Make sure you are using HE detergent. 1-2 tablespoons will due. If your using liquid fabric softner, dilute it by half. These machine use less water than a typical top loader and can't dissolve regular detergent effectively. There by causing your lines to get clogged with gunk.
Nov 02, 2008 | LG WM1814CW Front Load Washer
Front Loading LG Washing Machine leaves smelly sludge in wash tub
This machine has a tub clean feature that you're supposed to run with bleach. I did this and it helped the smell s bit. Recently we had an error code and the repair man that came to fix it gave me some good tips. His experience has been that the smell is from too much soap causing build up in the seal and along the tub. His suggestion was to cut back on the amount of he detergent (he said a tablespoon is sufficient). His company recommends using a product called Whirlout (you can buy it at Home Depot). It was originally meant to clean scum out of hot tub jets. Apparently if you call LG they will recommend this product, but haven't bothered to suggest it in the owner's manual. I was told to put one to two capfuls directly into the tub (not the detergent bay) and run the tub clean cycle. I used it last night and it worked - no more musty, yucky smell!
Aug 10, 2007 | LG WM0642H Front Load
Kenmore HE2 Plus Front Load Washer Logo
47 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
