Question about Singer White Speedylock 1634
Don't have a manuel how do you take out a needle
    Genius:
  • 1,788 Answers
Go to www.singerco.com and put 1634 in the instruction manual under customer support search and you can download one for free, Also, if you have a problem call the customer service at the number listed in the site, Good luck
Posted on Aug 24, 2010
I have a easy lock serger Model SL4300 and I need to know the needle size and what brand should I get, lost my manuel
Manual:
http://www.sewingpartsonline.com/instruction-manual-simplicity-sl4300.aspx
Free Manual For Simplicity Easylock Serger Model Sl4300
Parts:
http://www.sewingpartsonline.com/simplicity-sl4300-serger-machine-parts.aspx
This site shows Organ and Schmetz needles but most quality needle brands would be suitable for your machine. A standard 130/705H needle will work. Just be careful as I believe my machine recommends no needles larger than a size 90.
SL4300 Overlock Serger
Jul 12, 2017 | Sewing Machines
IT HAS TO HAVE THE NEEDLES CHANGED AND I DON'T HAVE A MANUEL HOW DO I DO IT PLEASE
Search the internet for:
Manufacturer + Model + the word "Manual"
or search YouTube for "sewing machine install needle"
sewing machine install needle Google Search
Jan 14, 2016 | Sewing Machines
I can't seem to thread my machine. The thread keeps coming out of the needle. Also, is there a Manuel that I can get on the Belvedere Adler?
try changing the needle
go to the website of a1sewingmachines.com ,, they have a phone number that you can call and talk to them , you can ask them about a manual.
Aug 16, 2013 | Sewing Machines
I have a capital model 777 about 40 yrs old. The top thread keeps breaking when I try to use it and the manuel no longer can be found. Can anyone help?
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Jan 07, 2013 | Husqvarna Sewing Machines
When bobbin in filling, the needle won't disinguage?
slide the bobbin winding spindle. if that doesn't disengage the needle... your machine may need professional servicing.
Sep 01, 2012 | Janome MC 4400 Computerized Sewing Machine
Need service manuel
soundss like mine so I cleaned it using canned air and then had to sew on rags for a bit and get the needle to pick it up works well now but I had lots of cursing and purple air about me before I finally got it to work. hope it helps you
Feb 21, 2009 | Sewing Machines
Manuel
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
May 26, 2008 | Janome L-344 Mechanical Sewing Machine
Bobbin/raceway and timing problem; Necchi 3577
ok.....without the bobbin case in and a fresh needle in, turn the machine to the side and turn the crank wheel counter clockwise, the hook of the machine should bypass the cusp of the needle, thats the part of needle that is by the eye and curves in alittle, if it is not the timing is off, try to adjust this by adjusting the needle bar, this is not a easy easy repair but takes patients, im assuming that, thats where it was thrown off timing
Jan 21, 2008 | Necchi 3537 Mechanical Sewing Machine
Bobbin Thread won't come through
Thread the machine and the bobbin. Turn the handwheel towards you with your right hand and hold the the top thread in your left hand pulling slightly to the back of the machine. When the needle goes into the needle plate keep turning the handwheel untill the needle picks up the bottom thread and by pulling the top thread you shold be able to pull the botoom thread through the needle plate.
Practise makes perfect.
Regards
Dupina
Dec 11, 2007 | Singer Featherweight II 117
Singer White Speedylock 1634 Logo
21 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
