Question about RCA L32HD31 32 in. LCD HDTV
Where do i find a replacement base? - RCA L32HD31 32 in. LCD HDTV
  • RCA Master
  • 3,866 Answers
You can find a Base for this at www.partstore.com they should have the base for this.
let me know ether way.
Please do not forget to rate you answer, thanks
Posted on Aug 24, 2010
  • Grand Canyon Tech
    Grand Canyon Tech Aug 24, 2010
    1-866-925-7278(PART) GIVE THEM A JINGLE
How do I remove the studs on the base of soft bodied pram to replace wooden base which got damp
If the attachments are press studs then drill out the centre of the studs to get them apart. replace using small bolts and nuts or use new studs again from hardware shop
Nov 10, 2014 | Baby Gear
I have a constant beeping on my jabra headset gn 9350
headset not syn'd with base, replace headset in base and remove power from base
count to 10 re-power base allow set up to complete, green lights across base and blue battery light on ear piece, allow to charge if less than two green lights on base.
if this still does not work slide ear piece apart count to 3 and silde back together again replace in base and allow to light up again, it will now work
Jul 18, 2014 | Jabra GN9350e Wireless Headset
How often do I need to replace me bed's base?
I advise you to replace both the base of your bed and your mattress at the exact same time. A base with inadequate support will cause a new mattress to dip in the center within weeks.
Aug 20, 2012 | Furniture
Charger arm will not stay locked in place to charge the razor
This is a common problem for older cleaning bases. The part is worn out. You will need to replace the upper housing of the cleaning base. You will find this item available at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html
If repairing the unit is not your thing, you can replace the entire unit instead. See item linked below
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-p-122.html
Jul 08, 2011 | Braun Syncro 7526 Electric Shaver
Braun 8585 shaver, charges fine, cleaning cycle acting strange where it thinks the razor is clean, but it is not. When new it cleaned at some level every time put in the cleaning base. Now it very...
The problem is the base, not the shaver. Most likely, the circuit board inside the base has gotten wet and is damaged. If this is the case, it will need to be replaced. You will find a replacement at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-8000-series-360-complete-clean-charge-base-p-116.html
Oct 09, 2010 | Braun 8585 Electric Shaver
Lg 42lb5d base stand
Here's a link to order the original LG base stand assembly for this model (42LB5D) from a major parts distributor. Please note, you would have to verify the complete model number of the unit as their are 2 versions availible (there should be either a C or F at the end of the model #):
LG 42LB5DC Replacement Part Base Stand Assmebly
LG 42LB5DF Replacement Part Base Stand Assmebly
Mar 23, 2009 | LG 42LB5D 42 in. LCD Television
Fitting Base Element for SMEG DO4SS-5
Some fan assisited ovens do have a base element, some do not.
If there is no heat at all in the oven , then it is safe to say that the fan element has gone, replace that first, if it does not reach correct operating temp, then it probably has a base element as well that needs to be replaced, this would mean removing outer oven panels to access it.
Plz rate my soution.
Thanks.
Jan 17, 2009 | Ovens
Handheld won't communicate with the base
i have the same problem and it has happened infrequently several times. you probably have to deregister the handset and re-register it and rest the base and handheld to communicate since my model is different from yours there may be differences in how to go about it but for my model the suggestion is as follows:
go to www.uniden.com for customer support here is a direct link to some frequentlt asked questions http://www.mycusthelp.com/uniden/supportfaq.asp?sSessionID=&lstFilter_a=&lstFilter_b=&lstFilter_c=&txtCriteria=hanset+won%27t+connect+to+base&optcond=2&iStartCount=1
DCT Series Multi Handset Phone - reset to have base and handsets communicate
Question:
I have a DCT Series Multi Handset phone and one or more of the handsets is not working, what should I do?
Answer:
Try resetting the phone system by using the following steps:
1) Enter the "System Reset" menu, then "Deregister HS" submenu.
2) Press volume/up or down arrow keys to select the handset ID to be de-registered from the list, then press the OK soft key.
3) Press the OK soft key. You will hear a confirmation tone. When de-registration is complete, "Deregistration Complete" appears.
4) After de-registering the handset, move to "Replacing the Base Setting" below. When you go through the deregister procedure if you get "out of range", That is okay. Go ahead and go to the next step.
1) Enter the "System Reset" menu, then "Replacing Base" submenu. "Do you want to replace Base?" appears.
2) Press the OK soft key. You will hear a conformation tone. The base information will be deleted. When replacing the base is complete, "Please Register" appears, register the handset to the new base.
If your handset is reading out of range. Check the the main base and make sure you unit has power. This can be done by placing the handset in the main base to see if the charge in use light comes on.
If your main base isn't getting power please make sure the ac adapter is plugged in and is warm to the touch. If not the ac adapter would be damaged.
To resolve out of range follow the below steps.
Press and hold the end key.
Press and hold the # key.
Release the keys and select replacing base and press select.
You will see Replace base?
Select Yes and press select.
Now place the handset on the base and it should register to the base and allow for calls to be made.
Jan 23, 2008 | Uniden CXAI5198 Corded Phone
How to change lamp in AGFA Arcus 2 flatbed scanner?
http://www.uktsupport.co.uk/scanner/agfa/arcus.htm#a2lamp
  • Turn off the scanner power switch and disconnect the power plug. Wait at least 15 minutes to allow the unit to cool down.
  • Unscrew the two screws at the back of the base.
  • Pull the SCSI board out enough to disconnect the ribbon cable that threads through the opening in the base (on the right).
  • Remove the two screws from the upper portion of the back of the base.
  • Remove the Transparency Option (TPO) from the base.
  • Remove the two screws from the top back of the base. These screws will be visible when the Transparency option is removed.
  • Remove the two screws from the top front of the base and lift the plastic housing off the scanner.
  • Move the carriage optical assembly backward until you can reach the lamp.
  • Remove the two screws from the top of the optical assembly that covers the bulb and remove the black cover.
  • Lift the lamp from the socket, working one end, then the other.
  • Replace the lamp with a replacement lamp. One replacement lamp is provided with the scanner and others are available through Agfa Parts Order.
  • Return the lamp cover the original position and replace the two screws.
  • Replace the plastic housing and replace the four screws holding the housing.
  • Thread the ribbon cable of the Transparency Option through the base and plug back into the SCSI board.
  • Return the board to the base and tighten the two screws. This insures a slack cable that won't be punctured when screws are put in to attach the transparency module to the base unit.
  • Replace the two screws in the back of the base to secure the Transparency Option to the base.
  • Nov 16, 2007 | Agfa Arcus II Flatbed Scanner
    RCA L32HD31 32 in. LCD HDTV Logo
    Top RCA Televison & Video Experts
    matt martin
    matt martin
    Computer Repairing
    Computer Repairing
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
