HOW DO I USE LEXMARK SCANNER - AM A COMPLETE COMPUTER VIRGIN!
Computer does not recognise scanner
Try using the Lexmark Printer Home. To access that, on your computer, click on Start > All Programs > Lexmark > Lexmark Printer Home.
If you don't see that option in your computer, just insert the installation CD and install the Lexmark Printer Home software.
Jul 17, 2012 | Lexmark Pinnacle Pro901
All in one center not working
Please visit the Lexmark website to download and install the Lexmark X4270 Printer Driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation.
Feb 20, 2012 | Lexmark X4270 All-in-One Multifunction...
I cant get my Lexmark x2250 Printer/scanner to connect with my computer. It use to work with this computer and I have checked the usb cables and restarted my computer. Do I need to get some sort of...
What is the operating system on your computer? Make sure to set your Lexmark X2250 printer as your default printer in the Control Panel (for Windows) or in the system preferences (for Mac). If you don't see the Lexmark print object in the control panel or system preferences, you should try to download and install the driver for your printer. Visit the Lexmark website using this link Lexmark X2250 Drivers. Select your operating system by clicking on change OS.
Then click on FILTER.
Click on the complete driver under Recommended Downloads. Download, execute the file and follow the instructions on the software.NOTE: Use the Vista driver in Windows 7. If you encounter any problem downloading or installing the software, please contact Lexmark technical support for additional assistance.
I hope this information has been helpful. Thanks.
Dec 27, 2010 | Lexmark X2250 All-In-One InkJet Printer
How does one scan a picture with an all in one Lexmark printer
Hi, normally, if you have installed the complete driver set of the all-in-one, the easiest way is to run a program with scanning capability i.e. photoshop, or word. the software normally given with a scanner is a 'twain' which becomes linked to the photoshop program. If you have MS word (I'll use this as an example ), ensure the scanner software is installed, the brother switched on and connected to the computer correctly click Insert select picture then scanner - (or it may say twain). At this point the Brother mini program - the 'twain' should start and then follow the scanner instructions and a scan of whAtever you have selected should be inserted into the word document. Bit of trivia - TWAIN stands for Tool With An Interesting Name - yup it really is!.
Apr 18, 2010 | Lexmark X5150 All-In-One InkJet Printer
Lexmark x3350-4500 scanner doesn't work
Please follow the steps given below to update the scanner driver:
1. Right click on My Computer and select Properties.
2 Click the Hardware tab and select Device Manager
3. Right click on the scanner entry that is displaying a conflict.
4. Select Update Driver from the drop-down menu that appears. The Hardware Update Wizard appears.
5. Select Install from a list or specific location, then click Next.
6. Select the Don't search... option and then click Next.
7. Click Have Disk. The Install from Disk dialog appears.
8. Click Browse and select the Lexmark CD from the Look in drop-down list.
9. Double-click on Drivers.
10.Double-click click on Scan, select the lxbksxp file, and then click Open.
11.Click OK. The following screen appears:
12.Click Next to start the scanner installation.
13.When the installation is complete, click Finish to close the wizard.
Aug 23, 2009 | Lexmark X5470 All-In-One InkJet Printer
Not compatible with new windows vista computer
Can you give complete details please? What do you mean by not working? No lights? Printer does not power on? Any error messages? Exact make and model of printer..
Oct 23, 2008 | Lexmark X2500 All-In-One Printer
Scanning problem
My proposed solution was given to me by a Lexmark Tech. It applies to 4350 and 4850.
2. Repair Microsoft1.gif Framework 2.0
3. Load MSCONFIG
5. Uncheck Loadup Start Items -- allows the complete program to load
6. Uninstall Lexmark
8. Install Lexmark files from support.lexmark.com
Dec 11, 2007 | Lexmark P4350 All-In-One InkJet Printer
Error 2200 on a Lexmark P6250
This is a scanner error. The light bar that goes back and forth during a scan is getting stuck for some reason. You might also double check your cartridges. There is a complete article about this on the Lexmark website at: http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:462:0:0&framed=&docid=ENUS24402&relevance=1 The user's guide should be installed on your computer (Look under Lexmark 6200 Series in your Start Menu) You can also find the manuals at http://www.lexmark.com/publications/eng/6200/index.html
Sep 18, 2007 | Office Equipment & Supplies
Lexmark 2300 all in one not scanning
I had this same problem.
For some reason when the printer installs, the scanner is disabled.
You will need to be on a user with administrative rights to complete this fix.
Also be sure you have downloaded and istalled the latest drivers from Lexmarks site.
  • Right click my computer.
  • Select manage from the dropdown menu.
  • Press continue if a UAC popup comes up.
  • In the left pane click Device Manager.
  • From the list of devices, expand "Imaging devices".
  • Right click on the lexmark xxxx-xxxx series.
  • Select enable.
Windows should automatically find the driver you installed and the scanner should would without a hitch now.
Hope this helps ya!
Sep 25, 2006 | Lexmark X2350 All-In-One InkJet Printer
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
