Question about Dryers
My maytag electric dryer start switch went out. I replaced it and it burned out again.
    President:
  • 1,218 Answers
Good day,
It's possible you just got a bad part. If it's under 90 days you should be able to return it.
If that corrects the problem, then the only thing causing premature failures would be the motor drawing too much current. However, other issues usually show up such as the machine shutting down before a complete cycle is run, or you have excessive noise indicating bad bearings causing the drum to drag and overloading the motor.
P.S. The only way to determine if the motor is drawing excessive current is with an amp probe. If you don't have one, try to borrow since they are very pricey. It's a device that clamps around one of the motor leads and gives you a reading, while the machine is running.
If need be, post back on more detailed use of this tool. Electricians carry them as well.
Posted on Aug 24, 2010
What causes start/pause button to work sporadically?
It sounds like the switch is getting bad, contacts in the switch no doubt have burned spots and it is hard to get a connection through burned spots. So I would say replacing the switch is in order.
Jun 21, 2014 | Maytag MDE5500AYW Electric Dryer
Maytag neptune gas dryer was purchased in 1998. Had matching pair. Washer went long agodue to faulty transmission. dryer just went a little while ago. Basically when i press start it doesnt want to start...
If the motor is not burnt up you will need to change the capacitor on the motor it energizes the motor to start up and should be on the side of the motor. Presently it is single phasing or just turning over and not getting all of the power it needs.
Apr 21, 2017 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDE3000AYW. The start button on my dryer went out. It tried to start and then died and smelled burnt. I am guessing the switch burned up. Any thoughts on how to fix it? Thanks
sounds like motor is in a bind see if you can rotate drum by hand if you cant then your belt is hung up,or a belt pully is bad,if drum turns freely,sound like motor is going bad
Jan 23, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Dryer can't turn on. Start button just buzzes.
replace the "Broken-Belt" switch by the drum motor,when the belt breaks it shuts off the heating element so as not to burn the clothes because the drum can't turn to produce air flow to dry the clothes as they tumble,when you replace the belt it will make the switch close the circuit again and it will start
Dec 26, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Dryer with strong "burned electrical wiring" smell
Sounds like the motor went out. Before trying to start it it needs to be inspected. If you are not comfortable opening up the cabinet then I would would recommend calling a service tech. If you need further assistance please let me know.
Ken
Mar 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer makes an electrical buzzing noise when start button
It sounds to me like the motor is not turning, but the heating element is coming on. with no air flowing over the element, it is getting too hot. Can you operate the start switch with the top tilted up so you can see if the motor is turning but the drum is not, and just where the buzzing is coming from. Also, I would try the dryer on manual setting and on air dry to see if any setting works. Good luck
Jan 07, 2010 | Maytag MDE6000 Dryer
Maytag electric dryer. LDE9314ACE Drum won't turn, but sometimes will. Had friend turn drum manually while I pressed start/door buttons. Drum turned fine but when I let go of buttons to shut door, dryer...
The motor capacitor is burned. You can replace it yourself. It's on the motor. Take it down to a motor shop and they will have a new one. (electric motor repair shop)
Sep 25, 2009 | Dryers
Dryer won't start
Are you getting any power to unit? The power supply most likely overheated and burned out a capacitor. It is possible that the relay may have gone bad to.
Jun 23, 2009 | Maytag PYE2300AY Electric Dryer
Electric dryer won't start
HI, check the following to address this issue you are experiencing.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jun 02, 2009 | Maytag MDE2600 Electric Dryer
Maytag electric
Yes, I would replace the starter switch...Also, there is a relay next to the starter switch(behind panel) that may be on the blink.. Try switch first as they are cheap.. The Repay retails for around $50.00. Goodluck!
Dec 15, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
22 people viewed this question
Top Dryers Experts
