Thread breakage occurs commonly with mis-threading. Be sure to ALWAYS RAISE the presser foot when threading the top thread. Also, since you are using 2 threads, thread one completely and then thread the other so the threads do not get twisted in the thread path. If your machine has duel tension disks, thread each tension disk separately with a single thread. Setting the thread spools to turn opposite directions may help.
Also, make sure the needle eye is the right size for the thread. Thick or thin thread could break easily in the wrong needle.
Also, use only good quality thread--no bargain bin or old threads!
The thread tension is dictated by the fabric being sewn, the application and the thread itself, as well as the type of stitch being used. These unknown factors must be addressed.
There is one available on the Singer site, it's free to download. http://www.singerco.com/accessories/manuals.html
Just type in 2037 and click on search.
On the next page click on free download!
The Model number is W2037 as the W stands for White.
Hope this helps!
There's a copy of the manual available free to download on the Singer website. http://www.singerco.com/accessories/manuals.html
The model number appears as W2037 as the W stands for White.
Hope this Helps!
You need to do a tension assembly test.
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Tension assembly test. To do this test. Pull the thread
through the tension assembly and test it to make sure the tension is working
correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or
something in the middle. Raise the presser foot and pull the thread through the
tension. It should pull easily!! Lower the presser foot and pull the thread. It
should pull noticeably harder.)
If it doesn’t work this way then you probably have a piece
of thread or lint stuck inside the tension discs. To remove it, turn the
tension to 0 zero and raise the presser foot.Using a small screwdriver, open
the space between the discs and spray with canned or compressed air. The stuff
should come out. Do the tension test again to make sure you got everything and
then try sewing again. sewman7
Okie Dokie..... Here's the way I see it.. The repair center was of little or no help to you . So, I will try to do my best..
First thing you need to do is unthread your machine and set the tension to 4.. Rethread the machine up to just before the needle.
When you get that far, put the presser foot down. If your thread pulls right thru easily, it is not threaded thru the tension wheel right. It your thread is hard to pull thru with the presser foot down, then it is threaded right.
General rule of thumb..
Loops on the bottom-- problem on the top
loops on the top--- problem on the bottom.
Hope this helps..
Mimi
Normal
0
font-size:10.0pt;
correctly.
then try sewing again. If it still messes up ,remove the bobbin case and examine it for burrs or scratches. Remove them with and emery stick and fine steel wool. sewman7
