Question about Panasonic Televison & Video
I have the DVD recorder DMR EX77 and it has suddenly stopped operating. I can't get the remote to control the system (yet there are no buttons on the machine that I could use in stead) - it's not the batteries, or the remote, I have tried replacing both. When I press any button on the remote, the display on the machine reads DVD2 and nothing else happens. This is the only thing that it does and it does this regardless of what button I press on the remote. I have tried turning the machine off & on & unplugging etc....
SOURCE: Panasonic DMR-E55 DVD recorder - 'remote DVD2' command
I had the Exact same problem, after finding nothing on the net I called Panasonic customer-Support and they gave me the information which led to the solution:
If your DVD screen reads 'remote DVD2':
Press and hold simultaneously the "2" & "Enter" buttons (for more than 20 seconds)
If the screen said remote DVD3 then you would hold "3" & "Enter"
What I found happens when this command is accepted, the DVD screen changes to display the channel & counter
e.g. "A2 0:00.26"
If the screen changes back to "Remote DVD2" this means that the signal from the remote control has been interrupted (you stopped pressing, or the batteries have become weak.)
Providing the batteries have power, try again remembering to hold the "Enter" and number displayed after DVD.
The first time I did this it seemed to take forever (more than 30secs.), but other times it's been accepted in 6 secs.
Posted on Jan 03, 2008
  • 1019 Answers
SOURCE: Panasonic DVD Recorder DMR-EX77
It sounds as if the actual T/V channel is out of tune.
I,d suggest powering the player On.
Then using channel 8-12 on the T/V to Scan for its frequency.
When you,ve located it to the Player.
Lock the channel, then use the DVD on Channel 8-12.
Mike @ compurepair.
p.s also check the output from DVD To T/V lead has,nt come loose.
Posted on Mar 17, 2008
SOURCE: Panasonic DVD recorder DMR-EX77 -
It's actually a fault on the device that needs to be repaired.
Posted on Jul 16, 2008
SOURCE: Making my Panasonic DMR EX77 multi zone
i have the same player and wont play burned dvds
Posted on Sep 27, 2008
notsomot
  • 67 Answers
SOURCE: WE HAVE LOST THE INSTRUCTIONS
You can get the full instructions here
http://tv.manualsonline.com/manuals/mfg/panasonic/dmrex77_dmrex87.html
That is the whole booklet. Please let me know if you have any problems
Posted on Jan 11, 2009
I want to be able to record on my DMR EX77 from another DVD player. cant locate how to do this. Thanks
Hello, maybe you can try to copy your DVD and backup on your DMR EX77. And in this process you may need a DVD Copy. Hope this idea can help!
Leawo DVD Copy Software Clone Copy DVD movie to DVD RW disc or hard drive...
Aug 30, 2016 | Televison & Video
My panasonic dmr ex77 is not multi region. How can i make it so?
The procedure below is a hack , can interfere with the normal working of the DVD player
*** Please note *** You will need a laptop with an Infrared (IR) port to use this method.
Most modern laptops have now dispensed with IR ports in favour of WiFi and Bluetooth, so you may need to forage around and find an older laptop with IR.
1) Download both parts of Chachi's RAR file (both of these files can be easily found on this forum).
You will need both files, as the ISO image file has been split across two compressed files.
2) Using WinRAR or WinZip unpack the ISO image file to a folder on your hard disk (the desktop is a good place, so you can easily find it later).
To successfully unpack the ISO image file, both of Chachi's RAR files must reside in the same folder.
As you extract the ISO file from the first archive, WinRAR or WinZip will automatically move to the second file and continue the unpacking process.
After the unpacking process has completed you will be left with a single file with the extension ISO.
3) Using Nero (or similar), use the "Burn Image to Disk" feature to burn the ISO CD image onto a blank CD (just copying the ISO image file onto a CD will not work).
I used Nero to achieve this, but most CD burning software can do the same.
4) On the laptop, ensure that the IR port is set to COM2 in the BIOS (note the original settings, so you can put them back after you have reprogrammed DMR-EX77).
Try to select an older IR mode if available.
My old Toshiba Satellite 4030CDT only supported FAST IR modes and wouldn't work.
I then switched to an Acer Aspire 2000 and through trial and error found the "IrDA (HPSIR)" mode worked perfectly.
5) Boot the laptop from the CD
If your laptop does not give you the option to change the boot drive order at POST, you may need to temporarily change your boot drive order in the BIOS (note the original settings, so you can put them back after you have reprogrammed DMR-EX77).
6) When the laptop has sucessfully booted from the CD you will be presented with a menu.
Using the down cursor key, select option "4. Minimal Boot" and press return.
7) At the "A:\>" prompt type "cd winamp" and press return.
8) At the next prompt "A:\>WINAMP\" type "winsamp" and press return.
9) The Remote control test tool should now be loaded (blue screen with white text).
10) Press the "r" key to load in the REMOTE.TXT file (this file contains the IR signal information required to reprogram your DMR-EX77).
11) The captions "button 1" to "button 10" near the bottom of the screen will now have changed from white to pink.
These are the emulated buttons you will need to press in order to unlock you unit.
Ensure "button 1" is highlighted before proceeding to the next step.
12) Power on your DMR-EX77 and switch it to DVD mode.
You must ensure the disk tray is empty during this process.
I had my disk tray empty and ejected (sticking out) during the process just as a precaution.
13) Point the IR port on your laptop at the IR receiver on your DMR-EX77.
The IR port on the DMR-EX77 is located just above the DVD/CD Open/Close button on the right of the unit.
I found the optimum distance between the laptop and the infrared receiver on the DMR-EX77 was approximately 5~6 centimetres, any more and it may not work.
14) With the IR ports aligned and "button 1" highlighted in pink press the return key on the laptop, wait a moment, cursor right to "button 2" and press the return key, wait a moment, cursor right to "button 3" etc....
Keep repeating this procedure until you have entered all buttons highlighted in pink from 1 to 10 in order.
If your DMR-EX77 reacts as mine did during the process you may see the display on the DMR-EX77 change and also experience the TV channel changing.
Don't panic as this appears to be quite normal during the unlocking process.
15) If all has gone well the display on the DMR-EX77 should now read "HELLO" and you should hear the hard disk spin down for a second, then spin up again.
The DMR-EX77 has new reset itself and has successfully been reprogrammed.
Leave the unit alone for approximately 10~15 seconds before doing anything else, just to be on the safe side.
16) The buttons on the front of the DMR-EX77 unit will no longer function, so switch the DMR-EX77 off using the remote control.
If you left the tray poking out during the reprogramming process (as I did), just wait a few seconds and it will close automatically, you can then switch off the DMR-EX77 using the remote.
There is no need to disconnect the DMR-EX77 from the mains supply.
17) Switch the unit back on, pop in any region DVD you like, sit back and enjoy biggrin.gif
Switch off your DMR-EX77 using the power button and leave it off for a few seconds.
Switch back on your DMR-EX77 and when it's ready try the proceedure again.
I failed several times initially, but it didn't seem to do any harm and everything is fine.
You may also find that changing the IR mode setting in your laptops BIOS may help.
I had to try a few different modes until I found one that worked.
If you can't find the files you need, or require the procedure for using another type of device to region free your DMR-EX77, then visit:
http://www.dcevolution.net/panasonic...tpage&Itemid=1 user_offline.gif
Apr 22, 2008 | Televison & Video
How do i record tv programs on digital stations. Only option is analogue.
On the EPG (of the DMRs channels) press OK on the remote at the program you want to record. After that you can choose HDD or DVD-RAM and the quality Ep-Xp and possible subtitles (STTL). Press OK and the recording settings are saved. Note that to record 16:9 or 4:3 aspect ratio, you have to have that setting made from setup.
Nov 09, 2013 | Televison & Video
Panasonic DMR ES15 remote stopped working with dvd/recorder...
Try holding enter button and 1 together on the r/c for at least 3 secs
Sep 30, 2009 | Panasonic DMRES15 DVD Recorder
Stop, play, on/off/ dis
The remote is required for most operations. You can get one on Ebay--or clean your family room/house and find the one you lost.
Jan 09, 2009 | Panasonic DMR-ES25 DVD Recorder
Panasonic DMR E55 DVD Recorder
Hi James,
When in EXT link mode the recorder is looking for a signal from the TV to start recording off the TV's timers system.
There is a EXT Link button on the remote control and pressing that will take the machine back to normal mode. The button is near the bottom of the remote.
Hope this helps
Andy
Sep 09, 2008 | Panasonic DMR-ES10 DVD Recorder
Panasonic DVD recorder DMR-EX77 - suddenly unable to play DIVX
Jul 15, 2008 | Televison & Video
Unlocking region code panasonic dmr-ex77 dmr-ex87
I have a panasonic dvd recorder. Model dmr-ex87
I was going through the options for the remote control and i selected dvd 3..Well this has caused problems as the remote only displays dvd3 when you press any buttons on the remote. How can i get it back on dvd1??
Apr 16, 2008 | Televison & Video
Panasonic DVD Recorder DMR-EX77 My DVD Recorder is communicating between the Remote Control and the DVD Recorder, but the Recorder is not communicating correctly with the television. The DVD Recorder seems...
Mike @ compurepair.
Mar 17, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Panasonic DMR-EH55 DVD Recorder
i have panasonic DMR-eh55 dvd and for the first time when i played that it was in japanies language thus i tried to convert the language in to english through remote control i selected one by one thus suddenly there came a message U302 and now when i play my dvd and as i press remote control it show on dvd screen U302. please how my remote will work again and how can i get the solution so that my remote control works....
Nov 11, 2007 | Panasonic DMR-EH55 DVD Recorder/HDD...
Televison & Video Logo
57 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
