Question about RCA RT2770 Theater System
Rt2770 need code for remote control no.rca192ab1
Which Brand And Type universal remote should I get to replace my OE remote for my RCA RT2770 Home Theater System?
Get the actual OEM remote, others will not do. You can get a remote like OEM from the link below. 1 800 Remotes
Jun 20, 2017 | RCA Audio Players & Recorders
Im trying to find a code for my rca rt2770. For a dish universal remote
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily......
http://electro-medical.blogspot.com/
Apr 06, 2016 | RCA Televison & Video
RCA RT2770 Sub-woofer sound doesn't come
The sub should generally have its own power supply, is it plugged in ???
Feb 16, 2016 | RCA RT2770 Theater System
Rca rt 2770 programming. My fm radio stations
You can manually program a station by pressing AM/FM to get to the correct radio band. Then tune in a station with the Tuner +/- (the left/right arrow) buttons on the remote. Next press Memory (just below 7) and then a number on the keypad. The number must be entered before the Program Preset number stops blinking. (For FM you can use some 2 digit numbers.) To scan through the stations in memory use the Channel +/- buttons on the remote or the Next/Previous track buttons on the RT2770. You could fill all of the memory slots automatically by pressing and holding the AM/FM button for two seconds. The unit will store the stations that it tunes in in order until the memory slots are full. Note: you do need to have the FM antenna and AM loop antenna connected (and extended for the FM antenna).
Retrevo has the manual for the RCA RT2770 available here: http://www.retrevo.com/support/RCA-RT2770-Home-Theater-Systems-manual/id/2869dj191/t/2/ . You will need to enter a code to download the PDF.
I hope this helps.
Apr 30, 2014 | Audio Players & Recorders
Rca rt2770 home theater universal remote code.where purchess
If the remote you purchased is universal and made before the RT2770 a code will not be listed in your code book, but you maybe able to call the universal remote manufacturer or visit there website for an updated list.
Oct 30, 2013 | Audio Players & Recorders
Have an RCA RT2770 unit and it will not turn on either by remote or unit itself. have all components plugged in and still nothing. any suggestion?
Possible this is a shut down due to a protection cut off.
Need to check the outputs and the power supply to confirm,
Sep 30, 2011 | RCA RT2770 Theater System
Greetings, i'm looking for a rca rt2770 remote or replacement. any ideas? can i change the speaker levels without it? thanks
You can purchase one here http://www.replacementremotes.com/RCA/Buy-RT2760-RCR192AB1-273471-Home-Theater-system-Remote-Control.html
Sep 23, 2011 | RCA RT2770 Theater System
I have a RCA RT 2770 receiver and the usb port does not detect any devices. It does have power as I have connected an IPod and it charges via the usb port. It just does not detect the mp3 player, IPod or...
look here
http://www.voxxsupport.com/images/manuals/RT2770/media/RT2770_UMEN.pdf
USB Device Playback Features
(Only support MP3/WMA file)
1. Press USB on front panel or remote control
to select USB mode.
2. Press to start playback or press to
pause playback.
3. Press to end playback.
4. Press CH+/- on the remote control or /
on the front panel to skip to the previous or
next file.
5. Press REPEAT on the remote control to select
repeat mode. (REPEAT ONE, REPEAT FOLDER,
REPEAT ALL, REPEAT OFF)
6. Press RANDOM on the remote control to
select random play mode. (RANDOM ON,
RANDOM OFF)
7. Press INTRO on the remote control to turn
on/off intro mode. The unit will play the first
ten seconds of each track on the USB device.
8. Press DISPLAY on the remote control to
select among mp3/WMA ID3 information,
elapsed time,current play Folder and Track
number and Play Mode.
Dec 10, 2009 | Audio Players & Recorders
Help
I cannot find any way of doing this from looking at either manual for the remote or the theater. It is my understanding that RCA makes "smart remotes" that supposedly recognize and control other RCA components, but I have no idea how this works. My suggestion is to read the manuals and maybe find something I didn't or contact RCA Customer Service.
Oct 09, 2009 | RCA RT2770 Theater System
hehehe i just found it mebbe i will tell u mebbe i will jk this is it either - 0790,1913,31023,31609,31254 mebbe one of those will help. the first one worked for mine. i take it u know how to program the remote
Apr 05, 2008 | Audio Players & Recorders
RCA RT2770 Theater System Logo
216 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
