Question about Aroma ARC-930 20-Cup Rice Cooker
How do I go about cooking 1 cup of Sun West Harvest Medley (brown, wild, sweet and red) rice? Water? Do I remove the strainer? mix water and rice together or Place the rice in the strainer with the water below?
5 Suggested Answers
  • 34 Answers
SOURCE: My Aroma ARC 930 Over cooks white rice
try 2 cups rice 3 cups water using Medium grain rice, your adding too much water
Posted on Feb 17, 2009
heatman101
  • 43501 Answers
SOURCE: need basic directions
There is a cup that comes with it that equals about 2/3 of a regular measuring cup...one of these or 2/3 cup for every cooked cup that you want to end up with...
The water...
There are lines on most of the cookers with numbers that represent the number of cups you are cooking...fill with water to that line....
If you are not sure, just fill with water a bit over the top of the rice...the amount is not that critical as the cooker senses when the water is cooked off and then shuts down...so a bit more will only make the cooking time a bit longer... no biggee...
Also it is best to rinse your rice before you actually leave the water in the pot that you are going to cook with...
remeber also if you have a brown rice setting that the cooking times are MUCH longer...like up to 90 minutes, so get it started in plenty of time or you will be eating rice for a snack before bed...
These things are really goof proof and make great rice very easily...
heatman101
Posted on Jul 27, 2010
heatman101
  • 43501 Answers
SOURCE: ARC-930 20-Cup Rice Cooker: Do I have to use water to steam my rice in an arom...
Here is a tip that I wrote about rice cookers and the amount of rice and water needed...
How much Rice and Water go in the Cooker
http://www.fixya.com/support/r5396567-much_rice_water_go_in_cooker
heatman101
bayyagg
  • 1672 Answers
SOURCE: how to set time for cooking brown rice
You have to soak and left the brown rice for 10 to 15 minutes in the water before you cook them or adjust the water level a bit higher!
Posted on Nov 07, 2010
2cup rice with 4 cup water. Why is the water boiling out of the cooker?
Way too much water! Use the same amount of white rice to water and a third of a cup more when using brown rice.
Mar 16, 2015 | Farberware Kitchen Appliances - Others
I need insturctions on using the avon rice cooker for microwave
1. Before cooking, optionally rinse or soak the rice. This is necessary for some types of rice (especially brown rice, which is much harder than white rice), but it improves the flavor and texture of most types. To rinse, put the desired amount of dry rice in a container and fill it up with cold water. Use clean hands to sift the rice in the water. Drain and repeat. To soak, put the desired amount of dry rice in a container and fill it up with cold water. Let stand for 30 minutes, and then drain.
2.Mix rice and water in a microwave-safe container. A good place to start is two parts water for every part of rice (e.g., 2 cups rice to 4 cups water). You can adjust the ratio through experimentation, depending on how dry or moist you prefer your rice, the power of your microwave and the size/shape of the container.
3.Enhance the rice with flavor. Add salt, vegetable oil, olive oil or butter before cooking. A teaspoon of salt/vegetable oil or 1/2 tablespoon of butter should do the trick for each cup of rice.
4. Stir the rice mixture slowly with a wooden spoon. Combine the ingredients thoroughly. This is especially important if you have added other ingredients for flavoring.
5.Cover the rice. Place in the microwave and set the timer. Here are some suggested guidelines for a 700 watt microwave and white rice:
  • 1/2 cup rice, 9 minutes
  • 3/4 cup rice, 12 minutes
  • 1 cup rice, 16 minutes
  • 1 1/4 cups rice, 20 minutes
  • 1 1/2 cups rice, 23 minutes6
6. For brown rice, start with three cups of boiling water per cup of rice and cook it for 25 minutes
7. Let the rice sit in the microwave for five minutes after it turns off. Don't open the door. The steam will complete the cooking process. You might observe that the rice grains start to orient themselves vertically, like they're "saluting".
8. Fluff the rice with a fork and serve.
hop you enjoy it
Aug 15, 2014 | Kitchen Appliances - Others
Lost direction on how to use my rice cooker and havn't used it in a while
To cook rice, fill center basin of base with water. Place the rice bowl on basin. Add rice and water as follows. For white rice add water in a 1:1 ratio to rice plus 1/2 cup. For brown rice add water in a 1:1 ratio to rice plus 3/4 cup. Examples: 1 cup white rice, 1-1/2 cup water; 2 cups brown rice, 2-3/4 cups water. Put lid on and plug in and in about 50 minutes you should have delicious rice.
Please rate this answer. Thank you.
Mar 27, 2010 | West Bend 86712 12-Cup Rice Cooker
Need directions on how make rice on my oster rice cooker
There are many types of rice. Follow specific directions for variety used.
2. Accurately measure rice and water then combine in rice bowl.
Pour specified amount of water in water reservoir. Cover and steam.
3. For softer rice, increase by 1 – 2 tablespoons the water mixed with rice
by the specified amount of water on the chart. For firmer rice decrease
water mixed with rice by the same amount.
4. Check doneness and consistency of rice at minimum time specified
for each type, stirring rice at the same time.
5. When checking/stirring rice, be careful not to drip the condensate into the
rice bowl which would reduce the quality and flavor of the steamed rice.
6. Use only clean water in water reservoir
7. Rice may be seasoned with salt, pepper or butter after steaming.
Combined In Rice Bowl Approx. Time
Type of Rice Rice Amount Water
(Minutes)
Brown
Regular 1/2 cup 1 cup 42 – 45
Parboiled 1 cup 1-1/2 cups 45 – 50
Long Grain and Wild Rice Mix
Regular (6 oz. pkg.) Mix 1-1/2 cups 50 – 55
Quick Cooking (6-1/2 oz. pkg.) Mix 1-3/4 cups 18 – 20
Instant 1 cup 1-1/2 cups 15 – 18
White
Regular 1 cup 1-1/2 cups 45 – 50
Long Grain 1 cup 1-2/3 cups 50 – 55
Oct 25, 2009 | Oster 5712 10-Cup Rice Cooker
Manual
Here are the instructions that came with the cooker:
Cooking times may vary due to variations in microwave ovens. Adjust cooking times for best results in your oven.
To Cook Rice:
1. Remove basket.
2. Pour 1 cup of uncooked rice into the bottom of the basket, rinse rice thoroughly with cold water.
3. Transfer the rinsed rice from the basket to the bottom of the cooker.
4. Add 1 1/2 cups of water and 1 tsp salt (salt is optional).
5. Secure lid and lock clamps. Open vent holes.
6. Microwave on medium setting (50%) for 10 - 12 minutes (white rice) or 18-20 (brown rice).
7. Remove from microwave, close vent holes and let stand with the lid fastened for 4-5 minutes (the steam continues to cook the rice.)
8. Remove rice from the cooker and fluff with a fork.
Yields: 3 cups of cooked rice or 4 to 6 servings.
Cooking Potatoes and Vegetables:
1. Insert Basket.
2. Pour one cup of water plus 1/4 tsp. salt into the bottom of the cooker.
3. Peel vegetables (if desired), cut into evenly sized pieces and place inside basket.
4. Secure lid and lock clamps. Close vent holes.
5. Microwave on high for 3-4 minutes.
6. Remove from microwave and let stand with lid fastened for 3-4 minutes (the steam continues to cook the vegetables.)
Cooking Pasta:
1. Remove basket and lid (lid not used initially for preparing pasta inside the microwave).
2. Pour 2 cups (5 oz.) of uncooked noodles into the bottom of the cooker.
3. Add 2 1/2 cups water.
4. Microwave on high setting 10 minutes, stirring after 5 minutes.
5. Remove from microwave, stir noodles, secure lid and lock clamps. Close vent holes. Let stand for 3-4 minutes.
Sep 01, 2008 | Nordic Ware 64000 8-Cup Rice Cooker
West Bend Steamer 86600
RICE Bowl: appliance part with N O holes in the bottom ! ! ! ! Put your rice (1 cup and water 1 2/3 water in to this part). In addition, fill bottom steamer with water to the MAX level.
Liz (see above)
May 31, 2008 | West Bend 86600 Rice Cooker
How much water
Well, the ideal rule of thumb is about 1.5 - 2 inches of water above the level of rice. Then again, it depends what type of rice you are cooking...But 1.5 inches should work.
Cheers!
IrishDruid
PS..Dont forget to assign a FixYa rating! Should you have any further queries, please post back and I will assist you as best I can :)
Apr 27, 2008 | Oster 3072 20-Cup Rice Cooker
Salton RA3 3-Cup Rice Cooker Question
Put equal amounts rice and water (up to 3 cups only) in liner pot, plug in, put lid on, flip little front switch. 10-15 minutes later it will be done and the pot will switch to "warm" mode by itself. Gently fluff with paddle before serving. You can also add salt or other seasonings to the water/rice mixture before starting.
Mar 19, 2008 | Salton RA3 3-Cup Rice Cooker
How do I cook brown rice?
yup! there is a different ratio for brown rice.
1 cup brown rice = 2 cups water
hope this helps
Jan 01, 2008 | Continental Manufacturing Company CE23201...
Cooking rice
I have a Sunbean Instant Streamer model 4710... I just wash the rice, add it to the bowl and add 1 cup of rice to 2 cups water. I fill the the bottom of the streamer to the max line and turn the steamer to 50 minutes.. The rice comes out great in my streamer this way
Sep 08, 2007 | Sunbeam SUN-4710 5-Cup Rice Cooker
Aroma ARC-930 20-Cup Rice Cooker Logo
Top Aroma Kitchen Appliances - Others Experts
Irene Tulloch
Angel Joseph Jr.
Angel Joseph Jr.
Tom Chichester
Are you an Aroma Kitchen Appliances - Other Expert? Answer questions, earn points and help others
