Question about Car Audio & Video
I have just recently installed a cd player in my 1990 Mitsubishi Triton dual cab. i couldn't find a constant power source so i took the clock out and used its constant power it was working for a week but now it just keeps blowing the interior fuse as soon as i replace it sometimes it wont go until the car shakes i have checked all connections and cant see where the problem is
    Problem Solver:
  • 30 Answers
Okay u will have to start all over..with the istall...it is best that u pick up a afermarket wire harnest ...and that wiill help u alot ..make sure that u remove the radio and connections ...replace all bad fuse from the fuse box....make sure work's the clock and interior light....u need a good ground with the black wire ...u must have a good batter 12v with the yellow wire...and a good 12v Igniton red wire.
Posted on May 05, 2008
Interior light wiring diagram to suit Mitsubishi Triton Mj 1992 diesel dual cab 4WD
Hello Robert, These diagrams can be found at the link below.
When your on the opening page....
Click Wiring Diagrams
Year: 1992
Make: Mitsubishi
Model: Mighty Max (AKA Triton)
Engine: 2.4 or 3.0
System: Lighting
Sub system: Dome Lamp or your choice.
dome lamp 2-lgkuwp4aw4khkvxj1psb51j4-3-1.png dome lamp-lgkuwp4aw4khkvxj1psb51j4-3-2.png
http://bbbind.com/free_tsb.html
Aug 17, 2017 | Mitsubishi Cars & Trucks
I have a 1999 mitsubishi triton 4wd rear axel bearings need replacing how do I remove the axle ?? to replace the seals
this is an involved process so best that you get a workrshop manual for the vehicle as the description is accompanied with photos that will explain the job.
Jan 20, 2015 | Mitsubishi Pickup Cars & Trucks
Which fuse is the cd player in the fuse box
One circuit is constant power to keep the clock and station pre-set memory maintained. The other is for the radio in general. If the clock works, pull both radio fuses and put them back in one at a time to see which one is constant power. If one of them is blown, you can usually see the wire inside it is burned with a gap. I don't believe there is a separate fuse for the CD player apart from the one for the radio. If the radio works but the CD player doesn't, I'm guessing it's an internal problem.
Jan 27, 2014 | 1994 Dodge Dakota Club Cab
Installing a dual cd player in a 2006 scion xb but dual cd player wont cut on unless both consistint power an ignition power are both together, making it impossible to hook up for memory.
The yellow wire needs to go to a constant source and the red wire should go to a switched (ignition) source. There should be a wire that is hot even with the key off.
Apr 21, 2011 | Pioneer Car Audio & Video
Hi! i just installed myself a new Dual Cd Player Xd 1222 on my ford focus 2002 4 door. The problem is when i start my car.. The dual reset every information like the bass and treble and all of the stuff....
This just means that you do not have your remote or memory cable connected to the correct power source. You need to connect this cable to a power source that continously runs. Underneath the driver side should be a fuse box. Connect the remote/memory cable to a fuse that runs, like maybe the old radio fuse. A schematic of the wiring for your vehicle would help you out a lot. This will show you the best source to connect the cable.
May 18, 2010 | Car Audio & Video
Unlock code for car cd player
If you can not find you ode in your trucks Owners Information under CD, Contact your Mitsubishi dealer with VIN# on the lower edge of your windscreen nd they should be able to retrieve the code from the VIN when you are given the code enter it with the station preset buttons. Best of Luck
Jul 15, 2009 | Car Audio & Video
Dual MXD55 W/6/5 SP CD Problems
make sure the speaker grounds are connected to the speaker ground wires on the deck and not the "chassis" ground. also make sure both power wires are hooked up to a power source. the thinner power wire is supposed to be a switched source (like the ignition key or an accessory switch) that turns the unit on and the thicker one is a constant source which actually powers the deck once the switched source is turned on.
Jul 01, 2007 | Dual MXD55 AM/FM/CD/Weather Receiver
Car Audio & Video Logo
295 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
