Question about Frigidaire AGQ6000ES Gas Dryer
Model # AGQ6000ES2 Fridgidare gas dryer wont start. It displays a lock. How do i unlock it?
5 Suggested Answers
Ben-mrfixit
  • 68 Answers
SOURCE: Fridgidare dryer spins but no heat.
If the dryer runs but doesn’t heat, don’t even think it’s the thermal fuse. If the thermal fuse was the problem, the dryer wouldn’t run at all.
First thing to do is verify your source voltage for the dryer; for those of you in Manhattan, this means to use your multi-meter to measure the voltage at the dryer outlet to make sure you have 240v. Y’see, Slick, the dryer motor only needs 120v supplied by one of the lines to run. But the heating elements, on the other hand, need 240v supplied by both lines to get hot.
If the source voltage is ok, then the most likely bad parts are listed below. As always, you should use your meter and the tech sheet supplied with your dryer (and cleverly hidden inside the control panel) to verify:
1. Even Heat Board
2. Heater Relay
3. Thermostat
4. Sensor
Posted on May 05, 2009
dmftrucker
  • 1922 Answers
SOURCE: where is the fuse located at
possibly an electronic 5volt fuse in the control panel,but check for 120/240volts at the appliance,then chk your neutral wire to the element they burn off from heat and age,then could be an open element
Posted on Aug 22, 2009
  • 127 Answers
SOURCE: fridgidare dryer model GLGQ2152ES3 runs but does n...
ok, you can remove the small screws below the kick panel below the door on the front. that will gain you viewing space to watch and see if the ignitor is even glowing, if it is then you most likely need gas valve coils, or to turn on the gas.
if the ignitor is not glowing at all you will need to do some testing on the safetys and thermostats within the dryer. they are all closed at rest so you should have continuity through them. there is the operating stat on the air duct blower housing in the front of the dryer. there is also a hi limit that is on the rear housing of the unit that you will need to remove the top of the dryer to view and gain access to..
those dryers have been a pain and the rear hi limit is especially susceptible to poor venting practices so very common today, and the higher operating temps caused by the poor venting..
best of luck..
Posted on May 24, 2010
  • 1531 Answers
SOURCE: Fridgidare Dryer Model #GLER34IAS2/Serial #XD40311703:
check the main terminal block and make sure there is no shorted wires.There is also a chance that the heating element has grounded out on the cabinet frame. causing it to draw to much power yet still dry clothes
Posted on Sep 12, 2010
Dryer thinks the door is open
sounds to me the child lock is working normal. What model dryer? Electric or gas
Apr 12, 2015 | Dryers
How do I reset my Frigidaire Affinity front load gas dryer when the LOC is displayed
Likely solution as I do not have the full model number of your dryer.
This means dryer control board thinks your machine is locked--- to get it out of lock mode normally do this:
press and hold "Options" and "Select" at the same time until it unlocks
If it doesn't unlock within 20 seconds you have a bad control board and it needs to be replaced.
see page 11 in this manual.
http://manuals.frigidaire.com/prodinfo_pdf/Webster/137118600een.pdf
Sep 03, 2014 | Washing Machines
Agq6000es2 frigidaire affinity gas dryer comes on the ingniter glows but the gas does not lite
Hello Tim, I understand the dryer comes on but will not heat. Let's try resetting the unit by either unplugging it or flipping the household breaker to the off position. Wait approximately two minutes, turn on the dryer and select a normal cycle. If these troubleshooting steps prove ineffective, you may wish to contact a professional as the unit may possibly have a defective cord, wiring, power supply, control board or door switch. In this case the service can accurately diagnose the dryer to determine the root cause to reduce the risk of unnecessary parts.
Aug 13, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Fridgidare leq2152ee not heating
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 08, 2011 | Dryers
Dryer is locked
May I det the make and model # so I can get you the right info to unlock the dryer
Jun 01, 2010 | Frigidaire AGQ8000F Gas Dryer
Fridgidare dryer model GLGQ2152ES3 runs but does not heat how do I get inside front or back to check the ignitor. It doesnt light (i think)
best of luck..
May 20, 2010 | Dryers
My dryer will not start. When I push the star button everything lights up but it will not start. It is a fridgidare and about 6 years old. It is an energy efficient Fridgidare.
Open the door, push in the door switch, press the start button and rotate the tub with your hand. If it starts running you have a bad motor. BE CAREFUL and this is obviously easier with 2 people but is possible with 1. Thanks for rating me after you view this.
Dec 12, 2009 | Dryers
Where is the fuse located at, in model AGQ6000ES2 Fridgidaire Dryer. it spins but does not get hot
Aug 12, 2009 | Frigidaire Dryers
Fridgidare Affinity washer door won't open after wash cycle
Try the following site for full information on unlocking Dryer -------
http://www.freepatentsonline.com/4908957.html
Sep 14, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Dryers Logo
156 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
