Question about Maytag Dryers
Dyer turns on but turns on but does turn off and clothes come out damp
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Posted on Sep 12, 2010
Stackable dryer. clothes gettin stuck in dyer causing holes in clothing
well depending on the brand some brands use a felt seal in the rear and front of drum to seal against the door shroud overtime the felt wears down and clothing get snagged in the gap as the drum turns and tears clothing....
Jan 26, 2011 | Washing Machines
Clothes dyer takes to long to dry, already clean all exhaust vents.
is it gas or electric?if it's gas you could have bad gas coils,they work for a while then cut out leaving clothes damp.if it's electric and heater is working check outside to see if flapper is opening,you might have a blcked vent line.you can remove vent line from back of dryer and run it and if clothes dry you know your vent line is blocked,if it is blow out vent line with leaf blower,short blasts at first so you don't damage vent line
Nov 02, 2009 | Kenmore Dryers
Whirlpool Duet Dryer, Dampness sensing only partially working.
inside dryer there is 2 metal strips clean tham off with a eraser if that dont cure it make sure vent clean going out of your home if both are done and still does it depends on dryer if its a sencer are control board
Oct 03, 2009 | Whirlpool GEW9250 Electric Dryer
The dryer does not stay hot
You probably have a restriction in the exhaust somewhere. Check vent to outside , if that is okay remove hose from back of the machine and look for lint buildup in hose and machine. More than likely the problem is in the duct in the front panel where the lint screen goes. To check and clean this you will have to remove the front panel.
Apr 04, 2009 | Maytag Atlantis MDG8400AW Gas Dryer
LGE59777S Not drying
There is a little sensor that tells the dryer when to heat and when not to heat. that sensor is bad. If you take the back of the dryer off you will see it. It is about the size of a half dollar and has 2 wires that plug into it. While you have it apart make sure that the dryer vent on the back of the dryer is not plugged with lint. Major cause for fires in dryers.
Jan 04, 2009 | LG DLE5977 Electric Dryer
Clothes not drying even after 4 cycles
you have to check your dyer vent hose and vent pipe to outside for any restrictions. #1 problem for extented drying time. it like having a backed up sink
Dec 13, 2008 | Maytag PYE2200 Dryer
Whirlpool Electric Dyer Problem
most of the time the dryer vent hose,wall vent and dryer vent hole must be clear to allow the dryer to vent,also you can pull dryer hot put you hand on the dryer vent hole turn on and see if it is venting this will let you know if the blower wheel is turning, let me know what you find-mike
Sep 25, 2008 | Whirlpool Dryers
Dryers Logo
37 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
