Question about Ice Cream Makers
Taylor frosty machine 358-33, reset button has to be reset time after time through business day. Parts replaced Reset contactor, compressor contactor, and thermostate circuit board. Still having issues with machine any thoughts on the problem we are having.
5 Suggested Answers
  • 30 Answers
SOURCE: taylor 751 sp dead
Sound like you might have a loose wire or ribbon cable,might even be a loose wire on switch.Be sure to turn breaker off to machine and unplug it before you check them. Also check the motor reset.
Posted on Mar 07, 2009
  • 30 Answers
SOURCE: Taylor Icecream Machine Model# y754-27
Try slowing down the rate at which you are drawing the product from the machine,and giving it a minute or two between draws. If you take to much out to fast it starves the barrel and will cause it to freeze up,and that will make the belts squeal.
SOURCE: Taylor 8756 ice cream machine clogs at face
can i see a display of internal shake machine?
Posted on May 05, 2010
  • 4 Answers
SOURCE: TAYLOR ICE CREAM MACHINES SPARE REQUEST
Softserveparts.com has sells most Taylor parts. -Shaun B
Posted on Feb 21, 2012
Compressor hpco code comes up on panel of Taylor soft serve ice cream machine? Does that mean lack of water to machine?
There is a very good chance. Often the water has been shut off, or a wheel is pinching the hose.
HPCO stands for High Pressure Cut Out. The high side pressure is regulated by the water valve on water cooled equipment.
These are links to parts in the water cooling system.
046686 Water Regulating Valve 3 8
048287 Condenser for Taylor Water Cooled machines Taylor 035174 Scraper BladeReplacement 17
May 28, 2017 | Taylor Ice Cream Makers
Compressor hpco
Compressor hpco or (High Pressure Cut Out) means the high side pressure has went over the limit the machine has been set too. The safety is there to protect the compressor. If the machine is water cooled, the water flow has most likely been interrupted. So often the machine was moved for cleaning and the wheel is on the water hose. If the machine is air cooled, Either 1. the fan has stopped, 2. the condensers are dirty or 3. It's just too hot where you are trying to run the machine.
Soft Serve Parts C723
May 06, 2017 | Taylor Ice Cream Makers
Taylor 8756-33. Which components operate in standby mode?
In standby mode, the machine just wants to keep the product refrigerated until it goes back into auto.
So, the mix cabinet needs to keep the product cool in the bottom of the machine, that requires the mix compressor and fans to run. The mix cabinet temperature is read by a thermistor probe and regulated by the (left side) logic board.
The product in the cylinders should go back to liquid form in standby, but we still have to maintain that safe food temperature, the motor and compressor will run periodically. If the machine is air-cooled a fan will run anytime the compressors run. If it is water cooled, water will flow through the machine when the compressor runs. The temperature in the freezing cylinders is read by a different thermistor probe and regulated by the logic boards.
Here is a link to all of the parts in a Taylor 8756.
http://www.softserveparts.com/c-1335911-parts-8756.html
Jul 20, 2015 | Taylor Ice Cream Makers
Beater overload on one side
turn the power off and hit the reset buttons about the size of a quarter hole on the back or front panels. turn back on and it should clear if not then you will need to have the beater motor or contactor replaced.
Oct 08, 2014 | Taylor 2008 C713-27 Soft Serve Ice Cream...
Taylor 751 sp dead
Jan 24, 2009 | Taylor 632-27 Ice Cream Maker
Taylor 770 soft serve
754-27 Taylor soft serve machine Beater motor not running - compressor not engaging - Power to beater relay but not out of relay.
May 18, 2008 | Ice Cream Makers
Ice Cream Makers Logo
240 people viewed this question
Top Ice Cream Makers Experts
ray gallant
Ruth summersides
Are you an Ice Cream Maker Expert? Answer questions, earn points and help others
