Question about JBL Mr 17 Silver Sirius Ready Am/Fm/Cd Receiver
I have a jbl radio mr16w im trying to hook up to the boat i need a wiring diagram
5 Suggested Answers
  • 122 Answers
SOURCE: i got a stock ford JBL amp with no wiring diagram
ok on most amps there are two sets of wire ports one for speakers & one for +12v,grd & 12v remote start if you look over each port it will say what port is for what wire if it is in a connector it gets slightly more complecated what you do is with a vm check from wire to chassis ground [like seat bolts] 12v with key off when you cet power isolate wire then turn key on till radio comes on then do the same test for 12v isolate that will be remote start then turn key off &check from the first wire to other wire for ground to find speaker wires connect a regular peace of wire to chassis grd & touch the wires you will here the speaker pop be sure not to hold the wire on long cause it will blow the speaker
Posted on Jun 04, 2009
rteemon
  • 578 Answers
SOURCE: hooked up after market radio in 2004 camry it was
check you ground and your spkr polarity make sure they are correct
Posted on Jun 26, 2009
SOURCE: jbl audio wiring diagram/schematics/color codes/ect.ect.ect.
http://documents.victorytechnologies.com//documents/product/2322.pdf
Posted on Nov 09, 2010
logosc75
  • 625 Answers
SOURCE: 2007 toyota camry jbl wiring diagram
Do not attempt to hardwire this. Here is the part you need: http://metraonline.com/part/TYTO-01
Posted on Sep 09, 2012
I have a 2002 olds alero and im tryin 2 hook my
Ok to start you need to go to this website and you will have to get the factory adapter for your radio so it can be modified.
.http://www.installer.com/cars/by_car.php?carid=4267 and also check this site this wiring diagram will help.
http://www.modifiedlife.com/2002-oldsmobile-alero-car-radio-stereo-audio-wiring-diagram/
Apr 16, 2010 | Car Audio & Video
My son and his buddy recently installed an amphlified stereo system on our center console and there is something strange going on that I can't figure out. It is a Clarion stereo with a JBL amp. The boat...
If a boat is anything like a car, the amp's negative post should not be connected to the battery, but to the ground of the boat. In a car, the entire chassis is grounded to the negative terminal, so when you run a line from the positive terminal of the battery to the positive post on the amp, and a line from the negative post on the amp to the chassis it is a complete circuit. I highly recommend placing a fuse on the positive line from the battery to the amp. Wiring this way prevents the amp from blowing up your battery, as well as prevents the battery from blowing your amp. Hope it works.
Jun 25, 2009 | JBL Boating
Diagram on what wires go were for 2003 chevy cavalier / gm radio interface to sony xplode cd player
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Apr 29, 2009 | Car Audio & Video
LOOKING FOR WIRING DIAGRAM FOR STOCK HEADUNIT
Radio Constant 12V+ Wire: White/Green
Radio Switched 12V+ Wire: Yellow/Red
Radio Illumination Wire: Red/Black
Radio Dimmer Wire: n/a
Radio Antenna Trigger Wire: Yellow/Green
Left Front Speaker Wire (+): Green/Black
Left Front Speaker Wire (-): Light Green
Right Front Speaker Wire (+): Green/Yellow
Right Front Speaker Wire (-): Gray/Red
Left Rear Speaker Wire (+): Blue/White
Left Rear Speaker Wire (-): Blue/Black
Right Rear Speaker Wire (+): Pink
Right Rear Speaker Wire (-): Blue/Yellow
pls rate
Apr 04, 2009 | 2003 Honda Accord
Need dash wiring diagram for a 1993 Dodge Colt
i had this problem , all you need to do is hook the ground wire from your new radio to the braided wire that hooked on your old radio and insert a bolt in the hole and tightin ,then check fuses and your dash lights will work and dome light.
Oct 05, 2008 | 1993 Dodge Colt
JBL Mr 17 Silver Sirius Ready Am/Fm/Cd Receiver Logo
71 people viewed this question
Top JBL Boating Experts
drshaddock
drshaddock
Level 1 Expert
DocZachary
DocZachary
JonSnell Electronic
JonSnell Electronic
Are you a JBL Boating Expert? Answer questions, earn points and help others
