Question about Honda Garden
Spring fell off and kids put it on in wrong spot. now it just putters not full throttle. i dont know were it goes. honda yard pro 160 model y160y21r year 2010 c_jdennie@hotmail.com I am looingfor a throttle assembly picture so I can put spring right
SOURCE: Battery replacement prg 40 model 2271
The silver spring goes in a very small hole in the plastic casing on the bottom side of the watch located next to the wristband under the sensor. Hope this helps
Posted on Sep 11, 2008
SOURCE: Ihave a honda ganerater MODEL#ES3500 and dont know were the battery goes.
The battery '+' attaches directly to the starter and the '-' cable is grounded to the frame/block.
Posted on Dec 11, 2008
slohry
  • 87 Answers
SOURCE: husqvarna 365 order to install trigger, throttle catch and spring
Here's a link to the husky parts list.
http://www.usa.husqvarna.com/support_manual_search.aspx?webecsearch=10527&O=true
Posted on Apr 10, 2009
  • 274 Answers
SOURCE: 2001 Honda accord trunk latch spring fell out
It probably goes on the outside of the casing One end arond the cable to hold the latch against the cable
Posted on Jul 10, 2009
  • 124 Answers
SOURCE: I am looking for a diagram on how install the
Go to your Briggs dealer and ask him to help you. Briggs sells a rope and handle kit with a tool and instructions to do this.
Posted on Sep 13, 2009
The spring fell off the throttle and I dont know how it is supposed to be reattached
Go to any Briggs and Stratton dealer and they will print you off a schematic to show you where and how it attaches.
May 10, 2016 | Mtd Yard Machines 158cc Briggs and...
I have a yard machine 46 inc deck i took the deck off and now i dont remember where the pto engage blades spring goes model number 13rn771h729 yr. 2007
it will be near the rear of all the pulleys probably just above top of pulleys look for a simple hole where it hooks usually a 1 inch piece of stock
May 16, 2014 | Yard Machines MTD Gold 20 HP Lawn Tractor ...
Intertherm model nomenclature
Look for 2 plates on top of carb. Rear plate, rear hole should be spring attachment.
Jul 31, 2013 | Husqvarna 675 hp 21" Honda Rear Bag Push...
The govenator spring fell off my push mower
make sure not to stretch it out this is critical under filter houseing is the throttle useally white plastic on a shaft going down through carb and has a hole or 2 one for governer rod and the other for the spring then a tab a inch or so away with a hole carefully hook into the metal tab and carb with out over stretching the spring
Sep 05, 2012 | Mtd 22" Yard Machine Push Mower
Gas seems like its sticking and hard to stop
It could be the cable-not supposed to have a lot of slack. Try unhooking the cable from the throttle, start the car and operate the throttle with your hand. Does throttle operation smooth out? If still binding it may be the spring or it may be a gummed-up (dirty) throttle valve-look inside with the rubber boot off and watch the valve move from idle to wide open. If it looks dirty in there, wipe and clean it out as best you can. A good throttle body cleaner spray can may help.
Jun 06, 2012 | Cars & Trucks
My sthill bg 86 blower has had a slight flat spot when reving it from new - it had its first service but no difference after that . six month down the track it has become so bad it wont rev out at all
When you say flat spot do you mean it goes from full throttle to slightly less with a slight puttering noise intermittently? If so this is the governor, totally normal, however from the description it sounds like a fuel and or vacuum related issue, Most likely the carburetor has failed or needs rebuilt, or the fuel lines or fuel tank vent have failed
May 20, 2011 | Garden
After complete dissassembly and cleaning of
Try taking the return spring out and give it about an additional one inch of length by gently stretching it out. Over time, the spring can loose some of its original tension.
Even the smallest debris particle can cause the throttle slide to hang up. If it isn't foreign matter causing it to stick, then there could be a ding or gouge in either the slide or the carburetor body. Take the slide out and put some blue machinists dye on it, then slide it up and down inside the carb - this will show you where any high spots are. Carefully remove the high spots with 1,500 grit wet or dry sandpaper.
Nov 15, 2009 | 2005 Honda CRF 450 R
Part fell out of gun dont know where it goes
is it the carrier support spring or the trigger spring?
go to www.winchester.com look for owners manual for model 94 come times the site dont work well.you may have to call them and ask for a schematic parts break down they will send it to you or e-mail it.
Oct 28, 2009 | Sport & Outdoor - Others
Jul 09, 2009 | 2001 Honda Accord
Garden Logo
54 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
