Question about Cell Phones
My samsung d700 wont turn on. When i turn it on the backlight comes on but i dont get anythin else. the buttons also light up. Pretty sure it isnt the screen as when the lights are on it wont recieve calls either. Any ideas?
    Sergeant:
  • 218 Answers
It sounds like it is a problem with its software u must update it
Posted on May 05, 2008
I have a Samsung TV that will not turn on.
You have diagnosed the fault yourself. The main board of your TV is defective and needs to be replaced.
Good Luck.
Oct 02, 2017 | Samsung Televison & Video
Tip
How to Format a Memory Card with a Nikon D700
1) Insert the memory card you wish to format into the Nikon D700's body using the memory card slot on its' right side. Make sure the power is off before you insert the card and that you place the card in correctly. The D700 will only accept CF cards, so make sure you have this type available.
2) Turn the camera on with the power switch. Only do this after you have inserted the memory card and closed the memory card slot.
3) Press and hold both the Trash and MODE buttons down for about 2 seconds. Together, these are known as the 'Format' button. The Trash button is located on the back face of the D700 body next to the Preview button, and the MODE button is located on the top of the D700 body next to the shutter button and power switch. If done correctly, the letters 'For' should appear blinking in the shutter-speed sections of both the view finder and control panel.
4) Press and hold both the Trash and MODE buttons again to format the memory card. This will delete all photographs on your memory card and format it. Do not turn off the camera or remove the memory card while the card is being formatted. If you do not want to format the memory card, simply do not press the Trash and MODE buttons the second time and wait for the blinking 'For' to disappear, which it will do after about 6 seconds.
5) Wait until the blinking 'For' disappears. The display will now show the full amount of photographs that can now be taken on the formatted card.
6) Alternatively, you can also format your memory card from the Setup Menu in the D700 LCD menus. You can access this by pressing the MENU button on the back of the D700 body, selecting the Setup Menu and pressing Format Memory Card, OK. This will format your memory card immediately.
on Jan 10, 2015 | Nikon D7000 Digital Camera
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
My galasy s 4g model d700 wont go past the first screen it stop working what can i do?
while the phone is on, remove your battery, after 5 to 10 seconds put it back.. then switch it on.
Dec 16, 2012 | Samsung Sprint Galaxy S Epic 4g Sph-d700...
How to unlock samsung sph d700 from sprint for free?
May I know how to unlock Samsung epic model SPH-D700 for free that will unlock it from Sprint?
Jan 10, 2012 | Samsung Galaxy S 4G Cell Phone
I have a Polaroid 42" TLX-04244B. When turning the power on the polaroid logo comes on for a sec. then screen goes black with the blue power LED staying solid. Im pretty sure the power suply board isnt...
The Inverter is trying to produce the high voltage to light the backlight. It looks like it cannot hold the charge to maintain the high voltage level in order for it to stay on - you get a momentary display at initial power-up thus see the logo. Replace the Inverter board.
Sep 08, 2010 | Polaroid Televison & Video
The picture wont come on
First make sure to hit the menu button on the TV's remote and if nothing is there then friend while the set is on turn a bright flashlight on and shine at angle into the set push the TV menu button if you can see a image then your back light is not working.
You can also check the transformers they are close to were the wires plug into the panel, make sure all transformers read the same amount of resistance if not you have found a bad one. Now you will have to check to see if the power supply is sending 24v to the backlight, if not the power supply is bad. Cost backlights around 150.00 and power supplies around 100.00. Well this should help you friend.
Dec 02, 2009 | Toshiba 46H84 46" Rear Projection...
Computer wont work when 2x2 connector is plugged in
sounds like a cpu problem, or a failing power supply.
Dec 28, 2008 | Intel Motherboard
My m:robe wont work at all!
If the screen doesnt even light up then you pretty much stuffed.
If battery isnt charging then the battery's life is gone. you cant really get another battery all you can do is remove it to prevent damage and use it plugged in.
Open the case by unscrewing the four screws (2on bottom and 2 on side)
move the HDD (hard disk) and take out battery and unplug
replace HDD and lid.
Jan 03, 2007 | Olympus m:robe MR-500i MP3 Player
Cell Phones Logo
113 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
