Question about Brother PED Basic Card Writer Box & Embroidery Magic II for PC
Computer doesn't recognize ped design writer box it did before not now
I have a Rose and the Customizing Software v 5.1 software and the card reader/writer with a 25pin end. I tried an adapter to a USB, and it won't recognize the reader/writer. Any other suggestions? I am...
You need a driver for your computer that recognizes the card writer. The Hus Rose site should have this, or possibly the people who made the card writer.
This is older technology so you may have to do a google.com search of the Internet for a better explanation.
Or find a Rose blog site and ask there.
Mar 17, 2015 | Husqvarna Sewing Machines
I am not sure the program has downloaded on Windows 7. The embroidery designs will not move there--
Sometimes embroidery files download in ZIP format.Check your download folder, and double click on the downloaded file. windows shoukd extract it into a folder of its own. open that folder and the .pes files should be in it. Then open the Brother program to access that folder with the .pes files.
Sep 27, 2014 | Brother PED-Basic Embroidery Software w/...
The DVD writer doesn't recognize that there is a
Most DVD drives are also CD drives, and it sounds like the DVD part is broken, you need to replace the DVD drive, this is done simply by buying a new one, I recommend Newegg.com ( if your unsure search exactly what you already have) then opening your case (tower) and just unplugging old one and plugging new one in, it really is very doable for even a novice.
Jun 26, 2011 | HP Computers & Internet
I transfer the pattern to the card and when I put it in my machine to sew it tells me that this card does not work in this machine
I've just had the same problem and found that you need to change the size of your hoop down to a smaller hoop size. Hope that works for you!
Aug 18, 2010 | Brother PED Basic Card Writer Box &...
I have plugged it in but don't know what to do next, please help
HI irenepaine. I've installed this once and I know it could be a little tricky because you need to use the software to convert whatever design you want - from JPEG to the machine's type. Then you use the card to save the file and then connect it to the sewing machine and then, using the display select the file you want. You need to use like 2 different software to acomplish this. Also you can do it thru the USB cable. Since I can't remember - I'm sending you the brother support site. Please find the correct model and see if it helps.
http://welcome.solutions.brother.com/bsc/public/Model_list.aspx?reg=us&c=us&lang=en&titleid=36#pe
Please dont forget to rate and provide positive feedback for our free support today. Thank you :D
Apr 29, 2010 | Brother PED Basic Card Writer Box &...
Blank Card, PE Design says it's a ''read only''
Hi - I think the problem is that although the Magic Card is compatible with your machine, it is not recognized by with the PED writer. I have the Brother PED-Basic sfotware and a Brother PED-Basic USB card writer box. The only blank card that the my Brother reader can read is the blank cards made by Brother. Which embroidery machine do you have (not critical - I'm just curious).
If you have both a Magic card and Magic Box, the box should have it's own software. I don't think the PE Design software recognizes non-brother equipment (bummer). The link I've provided below is to a dealer that sells two different blank Brother Cards. One of the cards is 1 mb. The other is 4 mb. They are the same price. You might check your documentation to see whether both cards are compatible with your reader and software. If you're not sure, you can call the dealer directly and ask. I have dealt with this dealer many times and find that they have great prices and are very knowledgeable. This link should take you to the page on which the blank Brother Cards are displayed - scroll down if you don't see them right away.
http://webstore.quiltropolis.net/stores_app/Browse_dept_items.asp?Shopper_id=1617251646531617&Store_id=492&Page_id=17&categ_id=42&parent_ids=0,20
This dealer is located on the East Coast, so you probably won't be able to reach them by phone until tomorrow. I don't know of a dealer on the West Coast to whom I can refer you. One more thought - Babylock equipment is often interchangeable with Brother equipment. If you have a Babylock dealer in your area, you might be able to find a blank Babylock card that you can buy off the shelf. Just make sure you can return it just in case it won't work.
Let me know if I understand your situation correctly - if not, send me another comment and I'll be happy to research further. BTW - if it turns out that you can't use the Magic card and can't return it, you can probably sell it online.
Thanks for getting back - I really love doing this. If you have general questions about embroidery, feel free to ask. I own several consumer embroidery machines, and I operated a commerical embroidery business for several years.
Ginny
Feb 05, 2009 | Brother Sewing Machines
Brother PED-Basic Driver?
Dear Kooks57, you have not deleted your designs, the program, card reader and card you purchased are for downloading designs from the internet or a computer. You will find free designs all over the internet including Brothers site. To use the reader you will download your designs from the internet or another card with designs on it and put them in a specific folder on your computer, then you can tell the Basic program to seach that folder and move the designs you want to the card in the reader. Once the designs have been moved to the card you can use it in your machine. Hope this helps if you need more help please follow the user instructions step by step and it should get you where you want to go, See page 8 in the manual.
Gale
Mar 21, 2008 | Brother SE-270D Computerized Sewing...
Brother PED Basic Card Writer Box & Embroidery Magic II for PC  Logo
142 people viewed this question
Top Brother Computers & Internet Experts
Michael Galve
Michael Galve
Are you a Brother Computer and Internet Expert? Answer questions, earn points and help others
