Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Model lsq9264 no spin cycle - Whirlpool Ultimate Care II LSQ9549L Top Load Washer
My washing machine only spins on the normal cycle, no spin at all on the gentle cycle. What do I need to replace?
your motor of ur washing machine have some problem , i hope so u go to a washing machine or manufacturer feed
Oct 14, 2014 | Washing Machines
I have a whirpool LSR7233DQO model top loader washing machine, a month ago it stopped agitating, now it will not spin at all on the spin cycle. It actually sounds like there is movement in the bade of the...
Sometimes the switch goes out (that little thing you held your finger on to keep it running). That's ~$20 to fix. If the washer runs, fills with water and won't spin once it reaches the spin cycle you probably need a new motor.
Feb 05, 2014 | Washing Machines
No spin cycle
This is usually caused by the pressure switch. Here is a link with the other possible problems. To check the pressure switch follow the link to the video. http://appliancehelponline.com/topwashernospin.html
Jul 16, 2010 | Kenmore 24032\24036 Top Load Washer
Spin Cycle "Whines" and keeps spinning after cycle is complete
need make & model # to correctly solve problem, it could be timer shorted or the drive motor has gone bad.
Oct 09, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Manual claims machine has ability to spin out water but there are no options on the control panel
There are different models withing this line by GE. There is one model that have a "Drain & Spin" cycle on the main cycle selection knob, but on the higher end models, you'll need to use the "Rinse & Spin" cycle.
This will add some water to the washer, but the basic cycle will give items a quick rinse and spin.
If you're trying to use just a spin cycle to wring out towels, etc. and you don't have the "Drain & Spin" cycle, (which you shouldn't based on your higher end model #), just use the "Rinse & Spin" cycle and it'll do a nice job of getting out a lot of moisture from your clothes, towels, etc.
I have this same washer in my own home and refreshed my memory by reading my manual (again) to see that this is what you need to do, to spin out stuff.
Hope you find this Very Helpful and best regards!
Aug 22, 2009 | GE WCVH6260FWW
Top-loading, direct drive Kenmore model won't do spin cycle
In other words it pumps out but when it goes into spin nothing happens. The first thing to check is to remove the tranny(get the agitator out) take the 3 bolts loose and slide out the tranny(no need to get the tub out) Take a look see at the plastic brake release collar mounted on the bottom of the basket drive. The ear will break off and thus no spin.3ef16e8.jpg If that looks ok let me know...
Jan 07, 2009 | Kenmore 22422 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
41 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
