Question about Dell PowerEdge R200 Server
Hi My Dell R200 Service gives amber light with no display on the screen And all the Fan's are running at Power-On Please help Cheers Dev
    Problem Solver:
  • 5 Answers
What is UID status? is it blue or amber
Posted on Aug 26, 2010
How do I fix problems of Dell computer 780 with power light yellow and black screen?
getnet,
What do the diagnostic led lights show. The diagnostic LEDs are located on the front of the chassis next to the power button. These diagnostic LEDs are only active and visible during the POST process. Once the operating system starts to load, they turn off and are no longer visible. Below is the manual that provides information on what the led pattern shows to help resolve the issue.
Optiplex 780 manual
http://dell.to/1HqoNmD
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Nov 20, 2014 | Dell Computers & Internet
My power button cable is missing so i plug into the wall pc starts up no noise but fan amber light but black screen graphics card fine?
Dont worry about on/off cable. if you have restart / reset button, remove that cable from motherboard and insert it in power on pins and use reset button as on/off switch.
Jul 22, 2012 | Dell XPS 700 PC Desktop
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
Dell opitiplex 280 is not giving display. first of all his fan speed to much high and then after 4 or 5 day its display disappeared. its just picking now power and fan also start with high noise and...
OK, I use GX280s as home servers and ran into a similar problem with one of them...
The problem may be serious and not worth fixing (motherboard).
Turn power on
Fan(s) come on full power, sounds like a jet engine, or eventually gets that loud.
See if you power light has gone amber.
You get nothing on the screen, no Dell splash screen/post, nothing.
This is what I posted a while back concerning the above. Obviously I cannot bee 100% certain as I do not have your box in front of me. This a known issue.
See if the power light goes amber after power up. I had (have - still siting in my basement) one that did same. Power up, fans go full blast . Power light goes and stays amber. This is USUALLY caused by bad capacitors on the mother board. Known GX280 problem going back. If you look on the motherboard, the capacitors should have flat tops and not leaking. If the are rounded or leaking, the MB has probably gone bad. Bottom line this is usually a defective motherboard. Mine was a bad caps issue, you issue could be different, but it does sound like the motherboard.
You can google "gx280 solid amber light loud fan" and see the issues. Here is one link.
http://community.spiceworks.com/topic/111476-gx280-solid-amber-light-and-loud-fan
I just replaced one of my old 280s with a dual core Dell Precision 390 workstation for about $118, and that included shipping, off of ebay.
Sep 25, 2011 | Dell OptiPlex GX280 PC Desktop
My dell GX 270 computer has amber mother board light,No display,processor fan runs,power supply fan rotates.
hi ansilesh
If the power light is steady amber - The computer is receiving
electrical power, but an internal power problem might exist.
Ensure that the microprocessor power cable is securely connected to the
system board.
it might also be a failed mainboard already since you are experiencing a blackout.
hope this helps
janc30
Feb 11, 2011 | Dell (002TR) Motherboard
Dell GX270 won't boot up with solid amber light on Power button
Check motherboard for bad capacitors. I had the same problem and when i had bad capacitors replaced everything is ok.
Feb 14, 2009 | Dell OptiPlex GX270 PC Desktop
Amber light on power button of Dell Dimension 4500
ok - the amber light of doom on a dell means one of two things - either your power supply is pooched - or your motherboard, If under warranty dell will send out a friendly tech to replace them - if not it will cost you a bit. get the price and consider if it worth upgrading instead. Contact your dell rep or dell tech support and see what they say
cheers Pete
Nov 30, 2008 | Dell Dimension 4500 PC Desktop
No display and wont boot
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Power supply is easier and cheaper to replace.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 12, 2008 | Dell Dimension 4700 PC Desktop
Amber Light and fan running
1st thing, disconnect everything but keyboard mouse and monitor, see if anything changes.
If the issue persists, ensure that all power and card connections for the motherboard are tight and secure. If you've added RAM or other parts, remove them. Reseat the RAM in the motherboard that came from Dell.
If none of those ideas have any effect on the issue, replace the motherboard.
Jul 01, 2008 | Dell Dimension C521 PC Desktop
Dell GX280 no display
plug in a video card in a pci slot and see if your video comes on and do the same with your agp slot
Jan 25, 2008 | Dell OptiPlex GX270 PC Desktop
Dell PowerEdge R200 Server   Logo
613 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
