Question about Frigidaire Freezer Refrigeration White Upright Large Manual Defrost Freezer Model FFU2124DW
Frigidaire upright freezer ffu17f9gw2. defrost water drain (bottom of freezer)had continual ice build up to the point of freezing over the whole bottom back wall. Had someone come in to look at it. The service man changed out the heater to "fix" the problem. Now it seems the heater is not shutting off as the whole bottom part of freezer is burning hot.
sgregg
  • 133 Answers
SOURCE: Frigidaire upright not cooling
It sound like you had a freon leak, you REALLY need to get this checked by a tech. if you are leaking freon it can be dangerous.
Posted on Jul 31, 2007
VOTIT
  • 2071 Answers
SOURCE: Ice build-up
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Hope this may help;
Regards,
VOTIT
Posted on Sep 22, 2008
  • 56 Answers
SOURCE: Frigidire freezer motor will not start, thasw out ice inside, then start up. Is the motor going out, or the cause is too much ice build-up.
more info would help but sounds like you have a defrost problem and need a technician
Posted on May 30, 2009
  • 109 Answers
SOURCE: Freezer forming Ice on the bottom not draining water
pour some hot water in the drain if this does not work use compressed air
Posted on Aug 23, 2009
Testimonial: "So far that worked great, we will see if it continues to drain when the freezer is back on and does it defrost cycle."
bobicehouse
  • 1524 Answers
SOURCE: i have a frigidaire upright freezer.. it keeps
Sounds like a defrost problem to me.
Posted on May 25, 2010
Frigidaire FFHS2311LWD has water pooling up and freezing bottom drawer and lower vent. Drain tube doesn't seem to be clogged. Water leaks onto floor some days.
the drain tube is most likely clogged. if the lower vent is freezing up there is no way to confirm because it is covered with ice. the reason water leaks onto the floor is, the refrigerator goes into defrost, frost melts and runs down the ice to the door. use a hair dryer to remove all ice, then use hot water to check drain. drain tube may be up to a foot long and may have a trap. you may have to go in through the back to gain access to the drain
Oct 22, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Self defrosting / but there is ice in the bottom
The most common thing that causes this is a stopped up drain. Thaw the ice out of the bottom and locate the drain hole (probably towards the back, possibly behind the back panel) and clear with with a stiff wire or coat hanger.
If the water is unable to drain from the freezer during the defrost cycle it collects in the bottom and freezes there when the freezer is running again.
Hope this helps, let me know if you need further assistance.
Oct 06, 2010 | Frigidaire 11.6 cu. ft. / 328 liter...
Freezer model EV171NYMS04 we have ice build up on
There is a drain the back of the freezer that is frozen. Your trickle of water comes from the ice that melts off of the refrigeration coils during the defrost cycle. You need to turn off the freezer, then remove the rear cover from the back wall to expose the coils. With a hair dryer, melt all of the ice. You will find a drain under the coils. Melts all of the ice in this drain so water can get out of the freezer. When this drain is clear, you can put everything back together, and your freezer should work normally.
Mar 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Aug 23, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Side by Side Freezer ice build up and water in the
Either the drain hose is plugged up with ice and not dripping into evaporator tray, or the defrost unit needs to be replaced.
Aug 04, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Kenmore upright freezer Model # C675-287140J Serial # 08462430AJ water is freezing in bottom tray and building up.
defrost drain may be plugged.shut freezer off,melt ice with blowdryer,and unplug drain.drain probably located behind inner back wall beneath coils.
Mar 08, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Ice build-up
Hope this may help;
Regards,
VOTIT
Sep 22, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Running but does not get cold enough
feel the sides or the coils on back if it has any see if they are hot or cold
Feb 20, 2008 | Maytag 15 cu. ft. / 425 liter Upright...
Freezer not keeping items completly frozen
thius suggests the defrost system not working and the defrost drain blocked. take off the back panel inside the freezer, melt off excessive ice and free the drain at the bottom with hot water and patience
Apr 30, 2007 | Frigidaire 13.7 cu. ft. / 388 liter...
Ice build up in my frost free upright freezer
I looked at the BACK at the bottom underneath of my Sears Kenmore frost free upright freezer and what was causing the ice buildup was very simple. At the factory, the assembler looped the little hose too high and when the water went into the hose it could not get out due to being too high in one spot! An ice dam will form, blocking ALL water coming through
and freezing up any more water coming down giving you a HUGE wad of ice that is scary!!! I just removed the screw holding the loop that holds the hose and put a bit of warm water down the little hole on the INSIDE (Behind the grate) to melt the remaining ice in the tube.You need to take out 4 screws and remove the grate to see this. I could not believe that this was the problem! I haven't had any ice build up since.Now don't tear your freezer apart before you try this trying to fix the compressor, thermostat etc. It may be the only thing wrong with it!
Nov 11, 2006 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Freezers Logo
71 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
