Question about Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2)
CAN YOU TELL ME WHERE I CAN GET A POWER SUPPLY FOR LINKSYS ROUTER WRT54GX2?
  • 34 Answers
SOURCE: WRT54GX2 Wireless-G disrupts both laptop and desktop internet connections
it might be because of interference...no issues dont worry about that...
JUst follow these steps and the issue will be resolved....
1,connect the blue cable between the computer and the router(any 1 of the 4 ports in the
router)
2,connect the other Ethernet cable between the Modem(came from ur internet people) and the
Router's Internet port(standalone port at the back of the router)
3,In the rear panel of the router u can see the reset button.with the help of the paper or
ball point pen,press it hardly and hold it for 1 minute..
4,Now turn off ur modem and the router..wait for other 1 minute..
5,turn onn only the modem first and wait till all the lights lit.now turn on the router and wait
till the power light is solid..open the internet Explorer it should work..
STEPS FOR WIRELESS CONFIGURATION
6,open internet Explorer and in the address bar..enter as 192.168.1.1..it will prompt for a
user name and password..leave the user name blank and the password will be admin.
7,
U can see the option WIRELESS in the black bar..click on wireless..
Wireless network mode should be "Mixed".wireless network name can be ur first name or
anyother name.select the channel as 11 and the SSid broad cast should be Enabled.click on
save settings.it will say like "Settings are successful"click continue.
8,to set the password for ur wireless network...below wireless tab in the black bar..u will
find a blue bar which says "wireless security".click on "wireless security". Security mode
should be "WEP"..Default transmit key should be 1.wep encryption should be 64
bits..passphrase should be empty..in the key 1 box enter ur 10 digit telephone number(ur
telephone number will be ur password for the wireless connection)click save settings and
continue..
9,
now in the laptop check whether the wireless switch is turned on...u can find ur wireless
signal..while connecting it will prompt for a password.enter ur telephone number there..
u will be connected to the internet..
Posted on Jun 03, 2008
  • 192 Answers
SOURCE: wireless WRT54GX2 keep getting message "unable to connect to..
Replace it with a new one.
Posted on Jan 12, 2009
SOURCE: how to install linksys router WRT54GX2 with no CD?
www.retrevo.com › ... › Linksys Wireless Router Manuals
you do not need CD you use a browser and log into router, please check, the manual, it shows you how step by step... download link above.
Posted on Mar 22, 2010
marked
  • 6487 Answers
SOURCE: My Linksys wireless router (Model # WRT54GX2)
You can follow the steps from this link to correct the problem.
http://www.fixya.com/support/r3801591-fix_blinking_power_light_linksys
Posted on Apr 25, 2010
  • 171 Answers
SOURCE: i need to figure out how to re-set my Linksys
How to reset LinkSys Router password
Posted on Nov 04, 2010
Wrt54gx2 won't stay powered up
Has the AC jack been damaged in the Linksys, due to pulling of the cord? Try wiggling the plug at the rear of the linksys to verify the connection. Check, reseat ALL cables. If it's connected to the ISP modem, can you use a Ethernet cable on the Linksys to the computer to verify signal? It may be bad, hard to say for sure.
Feb 14, 2013 | Linksys Wireless-G WRT54GX Router...
Router set to strict nat router is linksys wrt54gx2 how do i make it open to play xbox live?
XBOX
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And Also Make sure that UPnP is Enabled
Jan 15, 2011 | Linksys WRT54GX2 Wireless-G Broadband...
I need to figure out how to re-set my Linksys WRT54GX2 Wireless0G Broadband Router With SRX200
This article will guide you how to change the router's password and reset it to factory default.
NOTE: Accessing the router's web-based setup page requires a password. The default password of a Linksys router is "admin". For security purposes, it is recommended to change default password.
Changing the Router's Password
Resetting the Linksys Router to Factory Default
Resetting the Router Using the Web-Based Setup Page.
If any more problem encounter,post or thumbs back.
Nov 02, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
I flashed my wrt54gx2 with the latest linksys firmware and now the power is an unending blink no wireless and limited connectivity for lan
Try pushing in the reset button and then if that doesnt work, try reflashing it. if that fails, then try dddwrt firmware.
Sep 04, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
My wrt54gx2 will not power up,is this a common problem and how do i fix it?
Did you try plugging it in to a different power outlet? If there is no power light on your router still after trying a different power outlet, this means that the router has gone bad .
May 22, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
My Router loses power and then re-boots. My computer and my other device with Wi-Fi cannot detect its network.
1. check to see if you have a faulty power cord to the router.
2. You could have a faulty power supply.
3. this sound like an older router.
You may need to upgrade.
Apr 20, 2010 | Linksys 4-port Wirelss Router W/srx200...
How to install linksys router WRT54GX2 with no CD?
Mar 22, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Cisco SRX200 re-boots
- Updating the firmware of your router will do to fix the issue.
Mar 17, 2009 | Linksys 4-port Wirelss Router W/srx200...
Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2) Logo
20 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
