Question about Baby Gear
Front wheel shakes while pushing - Baby Gear
    Problem Solver:
  • 5 Answers
Have you tried locking the wheels? The wheels of some prams tend to shake when they are unlocked, but locking them tends to fix this.
Posted on Aug 24, 2010
Hi 2003 Honda Accord 2.0L Tourer. I'm having a problem between 55-70 MPH the car shakes when accelerating.I have had the front wheels balanced and now replacement front wheels.
Test the suspension parts by jacking only ONE front wheel just high enough to clear the ground. Now push the tire back and forth as if you were turning left or right. Is there a lot of movement before you can't push it any further? Watch the ball joints when you do this. Can you see the bottom half move but not the top half? If so then you need to replace them and have the car realigned after and again a couple of months later to correct any settling in changes that may have happened.
Aug 11, 2016 | 2003 Honda Accord
What makes it shakes
Sounds like bad brake pulsation, meaning warped rotors. When rotors are warped , they push the caliper piston in and out ,causing the brake pedal to pulsate and shake the steering wheel. I would start with replacing the front pads and rotors, and if you have drum brakes in the rear, have those cleaned and adjusted for a more balanced braking system.
May 15, 2014 | 2001 Plymouth Neon
1995 Ply Voyager 3.0 V6. Feels like the front passenger tire wobbles while driving above 20 mph on straight stretches. In a right hand curve (not turning, just a curve) at any speed the whole front end...
SOUND LIKE BAD WHEEL BEARING.SAFELY RAISE SUPPORT VECHICLE ON JACK STANDS,MAKE SURE VECHICLE PARKED ON SOLID LEVEL GROUND.GRAB WHEEL OR TIRE AT THE WITH ONE HAND TOP AND GRAB BOTTOM WHEEL TIRE WITH OTHER HAND,TRY TO SHAKE MOVE WHEEL IF WHEEL TIRE MOVES WHEN YOU SHAKE OR MOVE IT ANY.THE WHEEL BEARING MORE LIKELY BAD.IF WHEEL BEARING OKAY YOUR FRONT BRAKE ROTOR RUN OUT WORN OR WARPED.
Jul 21, 2011 | Plymouth Voyager Cars & Trucks
The front wheel shaking if i go faster than a very slow walking speed. Apparently it needs to be locked in order for it not to shake. And i found a small ball from the bearing i think.
The lock for the front wheel is a little plastic clip that should be just above the wheel itself if you push that down it should stop it from shaking
Hope this helps
Mar 02, 2011 | Baby Jogger City Elite Stroller
Shaking when driving. bought new tires in front 18 months ago. bought the car 3 years ago it was already lowered bought back tires six months ago had alighned two months ago started shaking after and tires...
get under the vehicle (use ramps) and check all linkages for movement pull push on the anti roll bar links, pull push on steering rack and pinion and linkages, any excessive movement, jack each wheel at a time, using a bar check the lower wishbone joints for movement, get the bar in the gap between the wishbone and lower part of the shock. and pull down, if any movement in ball joint up and down replace. while wheel on vehicle check for movement in bearing you will feel a tiny amount not much but pull and push on wheel with opposite hands on 12 o'clock and 6 o'clock and do the same at 9 and 3. now with both wheels off the ground but with the tyres still on, have some one holed one wheel and push pull on wheels each side there should be even movement between both wheels, if everything is fine with the the steering linkages and this dose not feel or sound right then this could be the problem also to add if the inside and out side of the tyres are wearing then the tyre pressure is wrong and needs adjusting to the right tyre pressure .
Jul 24, 2017 | 2000 Ford Mustang
Baby trend double jogger stroller pulls to the left when front wheel is in locked position AND front wheel wobbles (cannot push through it)when on swivel.
Hey! I just fixed my shaking wheel! There is a red lever above the swivel wheel. I pushed it up. And guess what... I can jog with my stroller!
Jul 03, 2010 | Baby Trend Expedition Double Jogger
Babyjogger city elite front wheel shakes
You need to put more weight on the front of the stroller. The wheel is shaking because it's able to swivel....
Apr 12, 2010 | Baby Jogger City Series Single Stroller
2002 jetta tdi with manual transmission, front end shakes
check for bent axle or missing vibration rubber damper that is usually on the axle.
Feb 02, 2010 | 2002 Volkswagen Jetta TDI
Side to side wheel play
It could be an indication of a bad wheel bearing assembly. Did you check the lug nuts to be sure they are tight? It could also be the tie rod assembly. I would take off the wheel and try to move the just the hub assembly. Do you hear any screeching/squealing noises? Any popping while you are driving? Are your tires wearing? All these are classic signs of a bad wheel bearing. Any decent tire/auto shop can put your car on a lift and check the wheel bearings.
Jul 24, 2009 | 2001 Dodge Stratus
My jogging stroller shakes
Well, i'm not positive in this, seeing how I never had kids, but while jogging are you pushing down harder on the stroller? or you could look for smaller wheels to put it on, but then again you might have'ft to bend over to do it, and if the handle which you push is tall that has to do with force viberating the stroller
Nov 29, 2007 | Baby Gear
Baby Gear Logo
118 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
