Question about GE 22.3 Cu. Ft. Bottom-Mount Refrigerator - White-on-White
HOw do I clean the bottom of the fridge..Can I remove the base anyway?
  • GE Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 28, 2010
Runs much longer now than it use to, any suggestions
DURING Summer time you will find fridges run longer. When the last time you had the condensor cleaned. Pull the fridge our and remove rear cover at the base. Make sure your fridge is unplugged. Use a brush and vacuum to clean the lint. watch for condensor motor and clean between coils.
Jun 24, 2014 | Jenn-Air JFC2089HE French Door...
I have a Kitchen Aid side by side refrigerator. Under the refrigerator there is a plastic water overflow tray. It collects water and the water becomes foul smelling. I have tried removing the tray to...
You should be able to remove the base grill by opening both doors to 90 degrees and pushing down while pulling outwards on the base grill to unlock the top clips, once the top is away roll the base grill toward you and up. From there you should be able to see the pan underneath which should slide out.
Clean it thoroughly and use a mixture of baking soda and water for final cleaning rinse and replace, I also mix some baking soda and water and pour in the bottom of the fridge to allow the mixture to cleanse the drip tube leading to the pan.
Installation is in reverse of removal
Mar 12, 2011 | KitchenAid KSCS25FKSS Side by Side...
Bad smell from motor
You need to remove any spoiled food from the refrigerator and clean the interiors with hot water added with baking soda. You need to clean the door seals and remove the breaker strips. Also check for unusual wet insulation.
Hope this work
Jul 28, 2010 | Amana ABB1927DE Bottom Freezer...
Water on the inside floor of the refridgerator,
remove back panel from freezer and unglog hole where it collects water. its glogged
Feb 11, 2010 | Maytag MSD2756G Side by Side Refrigerator
Water pooling at the bottom of kenmore fridge
I had a Kenmore fridge - about 20 years old when I replaced it this year. It used to do the exact same thing especially in warm/hot weather. What it is is the water from the freezer defrosting. There should be something on the back near the top, inside the fridge sticking out - a tiny little tray sticking out and it may also be part of supporting one of the shelves, I can't remember. Anyways, water from the defrost pools in there and is supposed to evaporate, but it gets clogged with gunk and the water spills out and runs down the back of the fridge down to the bottom. Get a pipe cleaner or something and poke it into this hole and clean out the pipe to the hole isn't blocked. This is all inside the fridge, not outside, on the back panel outside. That's the best I can do to describe the solution - it's an easy fix you can do yourself. Good luck!
Jan 01, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Fridge and freezer too warm... freezer at 40 at fridge around 52
on the back or bottom of the fridge there is a coil, it is dirty, clean it, easiest way take fridge outside, wash with water hose
Aug 11, 2009 | Refrigerators
Bosch KSU 40 fridge leaks water
I found that the entire defrost system had frozen over. to check the fridge for this problem you will need to:
pull out fridge, turn off power, remove cord (whilst at the back check the grills are clean, all dust in the cavity of the house and the condensor is clean and ensure that the 'travel wedge' has been removed from the engine.
remove food and shelves from freezer compartment.
with small (2.5mm wide) standard pop the three white screw covers up from the bottom tray. Undo the 2 philips head screws (with a 2 point screwdriver) Pull tray out. Lot of ice underneath? It's frozen over! you're going deeper!
Remove centre tower by squeezing the sides at the base near the rear wall. remove.
Chisel ice and remove, pour a little hot water down the two funnels at the rear.
To examine how fair the problem is and to let air to circulate you can remove the rear wall and polysterene insulation by removing the panel in the left upper portion with the 2.5mm screwdriver and removing the red, far right socket (this is the fan's point). Use 2 point and remove the 2 screws on the rear wall and remove, remove insulation. You're in.
Let completely defrost, clean up and dry all water and re-install.
Jul 02, 2009 | Refrigerators
Not cold
A friend came to fix it there was a piece of insulation caught in the damper. Thanks anyway.
Aug 19, 2008 | Amana ABB1927DE Bottom Freezer...
Kenmore Elite Bottom Freezer Refrigerator Model 795.7554
the condenser coil on this is located in the back side and removal of the rear cover is need to get to the coil. It's on the right side looking at the back. make sure to unplug the ref before taking the back off.
Aug 09, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
How to clean my Maytag side by side MSD2732GRS coil
This fridge has the coils that are not supposed to get dirty, but do anyways. Unplug it. You need to pull the fridge out and remove the panel at the bottom. You will be able to access the condenser from here, but it's kind of hard to get a narrow enough brush through it to thoroughly clean it, but get the most you can and make sure the fan blades are clean as well. Be very careful not to bend the fan blades, they are easily bent. Then make sure the area under the fridge is clean so the fan can easily move the air under the fridge.
Jul 22, 2008 | Maytag Refrigerators
GE 22.3 Cu. Ft. Bottom-Mount Refrigerator - White-on-White Logo
20 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
