Question about Nintendo Wii Console
For some reason I cannot connect to the internet...I get a error code:52031...what is that?
    Genius:
  • 1,234 Answers
Error Code: 52031 This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
    1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
    2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
    3. If the Mac address filter was disabled, then continue troubleshooting.
  3. If your connection was working previously, try power cycling your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. (Some routers may lose their connection to the Wii console while it is in Standby or turned off for a period of time. Check with your router manufacturer's website for the latest firmware, as there may be an update that will help prevent this issue from occurring in the future.)
  4. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Posted on Aug 27, 2010
Im trying to download net flix on my wii and im getting the error code 52031...what does that mean?
Error 52031: It's possible that the wireless security pass code for your home network may have been changed or is entered incorrectly on the Wii console.
However if you're using Wi-Fi to connect to the internet, your ISP may be blocking the ports allowing you to use netflix from your WII. You may need to contact you ISP in order to verify this problem.
Aug 23, 2011 | Nintendo Wii Console
My Wii will NOT connect to my WiFi. I got the error code 52031. HELP!
Error Code 52030, 52031, 52032 WEP / WPA Troubleshooting
nintendo link
May 10, 2011 | Nintendo Video Game Consoles & Games
Error code: 52031
hello. good day. this error appears when you are unable to connect to your wireless network. the reason could be that your security settings entered into your Wii are not the same as what your wireless router is set to allow, or your router is not able to assign the Wii an IP address. to fix this make sure the security key and security type are entered into the Wii exactly as they appear in your router's settings. hope this helps. goodluck!
Apr 29, 2011 | Nintendo Wii Console
Trying to connect wii to enternet. Recieved code 52031
This error message is usually due to an incorrect security passcode being entered for your wireless network. Double check and make sure you've got the right passcode.
Apr 26, 2011 | Nintendo Wii Console
Im trying to to connect the internet on my wii like it usally has and for some reason it says on the wii settings 52031 and it dosent connect what do i do ive already tried the key and password so idk what...
It appears that your Wii console's Internet connection may be affected by wireless interference. Try the following:
Change your wireless router's channel to 1 or 11
Changing the wireless channel on your router may help. Most wireless routers have a channel range of 1 through 11. The best channels to try are usually 1 and 11, as they do not overlap with other channels. Typically, the channel settings for your router will be found in the router's main "Wireless" tab.
Where is your wireless router located?
Move your router away from walls and off the floor and try to place it in a central location in your home. Also, keep it away from metal objects such as metal filing cabinets which can cause interference.
Look for other devices
Noise from cordless devices (cordless phones), or wireless electronics (wireless keyboards, headphones, cell phones), especially those using the 2.4GHz frequency, can interfere with your wireless signal. Also, older microwave models can cause wireless interference. Avoid electronics that use the 2.4GHz frequency, instead look for devices that use the 5.8GHz or 900MHz frequencies.
If you've tried the above steps to reduce interference and you're still experiencing problems, it's possible that the wireless security pass code for your home network may have been changed or is entered incorrectly on the Wii console.
Apr 22, 2011 | Nintendo Wii Console
Error code 52031, unable to connect to the internet
very common problem....if you just powercycle(reboot) your router that should solve your problem
Apr 21, 2010 | Nintendo Wii Console
Nintendo wii unable to connect to internet error code 52031
the are your in dosen't have internet connection
Feb 17, 2010 | Nintendo Wii Console
Nintendo wi
you can try messing with the settings on you router and try it
Jul 31, 2008 | Nintendo Wii Console
I HAVE A WIRELESS CONNECTION AT HOME.AN ERROR SHOWS UP IN THE TRYING TO TEST THE CONNECTION FOR THE WII.THE ERROR CODE IS 52031.CAN YOU HELP.
Hi normbrus,
According to Nintendo's website, this error usually relates to a security issue in the network. You should try reentering your security settings manually. For a full description of the error code and how to resolve it, visit http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=52031&system=Wii&locale=en_US&action2.x=7&action2.y=15.
Thank you,
Jason,
Go Ahead. Use Us.
Nintendo Wii Console Logo
41 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
