I have a weird problem with my Pionreer DVR-420HS DVD Player. Whenever I'm watching a DVD or a programme recorded on the hard disk for some reason it switches back to the tv yet the dvd is still playing. You can still see the timer continuing. The only way I can watch the dvd again is to switch off/on the dvd player. This happens at irregular times. Do u have any idea about the strange problem? Thanks.
  • 476 Answers
If you have connected the DVD to the TV with a scart lead, the lead could be slightly loose. In this case push all the scart leads in firmly.
Pin 8 of the lead carries a switching signal. When the DVD is powered on it tells the TV to switch to that input. If the switching signal is lost the TV will switch back.
Posted on May 07, 2008
Not recording selected programme from hard disk to DVD
1) clean the OPU optical pick unit.with disk cleaner
2) uninstall the driver and reinstall from your supplier and try again and fix it.the driver can be corrupted.
God bless you
Sep 23, 2012 | Televison & Video
Recording and actually WATCHING the programmes I record
this feature its not from the TV is for DVR box, that storage the information on a hard drive inside, check your DVR model and number and google the proper manual for it
Mar 15, 2010 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
CyberHome DVD 1600 won't record to Sony disk
I believe the recorder is bad, it should be able to accept all brands and types of disks. You might want to try another brand and type of disk just to make sure, if it does not work, the recorder is bad. Good luck to you!
Jan 03, 2010 | Cyberhome DVR 1600 DVD Recorder
Pioneer dvd recorder/player does not read its own recorded dvds, and some others recorded on other players it throws them out?
Thanks for your help re: dvd player recorder.
I have now desided it needs a new read write drive and am searching for local repair shop to do this.
Thanks again
Vasos574
Oct 18, 2009 | Pioneer DVR-5100H DVD Recorder
Adding a dvd player to my dvr and older tv
leave coaxcil cable on dvr ;unplug the colored wires from the dvr output and plug them into the output of the recorder;plug a second set of colored wires into output of dvr and into input of recorder;be sure to set recorder input to proper setting on recorder (input one or two) now you should be able to record what your dvr plays or just use it as a dvd player ; you will need to have all three on to watch tv though.
Mar 01, 2009 | Cyberhome DVD Recorder - DVR1600
Caanot play CD-R/DVD-R burnt from PC
First check that in your user manual that the dvd player is JPEG compatible. When you say you are having the problem on other DVD's do you mean when you use DVD+R and DVD-R disks on your own player or that yu have tried to play the same DVD disk on other brand DVD players without success? You dont mention which software you are using to save your JPEG's to Disk or whether you can in fact view them on your PC. After making sure that your Windows media player displays your pictures ok, Try using the NERO dvd burning Rom programme to load your JPEG's. I am assuming that you are not trying to record a DVD in a CD burning drive? hope this helps - hattonhall
Sep 08, 2007 | Pioneer DVR-330 DVD Recorder
Programmed recording to the hard drive
Either You haven't set the time/timer correctly or you need to find a way to clear/format the hard disk.
Aug 16, 2007 | Samsung DVD-HR735 DVD Recorder/HDD...
Changing Channels
Unfortunately, no. The tuner in your DVD recorder works differently than how your satellite receiver works. You *must* use the satellite receiver to select the active channel, and then send that channel to one of the inputs on your recorder. You can then record that channel. Unless your satellite receiver is has "dual tuners" in it, you are stuck watching the same channel that the DVD recorder is recording. If your goal is primarily time-shifting of shows (as opposed to archiving shows forever to DVD), you might consider getting a different satellite receiver with a built-in DVR (hard disk recorder). These allow you to mark shows in advance, have them recorded to the hard drive, and then you can watch them whenever you want, skipping all the commercials. You also get the ability to pause and rewind live TV.
Apr 14, 2007 | Panasonic DMR-E50 DVD Recorder
Dvd recorder wont finalize etc
The DVD drive works harder when trying to record the info faster. As the unit ages, tracking is less precise. DVD-R copies occur at 4-16X real time. Try DVD-RW disks which copy slower (now that the price has dropped substantially), and you may find that your aging drive can still copy programs from the HD to the DVD.
Oct 16, 2006 | Pioneer DVR-530H-S DVD Player/HDD Recorder
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
