Question about Toshiba Satellite L45-S7423 Notebook
My uncles HDD died on his toshiba L45. He purchased a 350gb 7200rmp replacement drive hoping that the recovery discs would still work w/ a different HDD. Now when we try to restore it gives us an I/O error before even getting to the 2nd disc. Its finding the HDD because the correct size comes up when trying to build the partitions. Will the recovery discs work on a system with an upgraded HDD or do I need to get a replacement from Toshiba if I want to run the recovery discs?
  • 20 Answers
It should work with the hard drive. If its a SATA drive you may need to change the drive info in the bios to Compatability mode for it to finish the restore process.
Posted on Aug 24, 2010
Factory recovery toshiba satellite L45-s7423
If you do not have the original recovery media to do this, then you will probably have to contact Toshiba to download or purchase new media.
Start by searching their knowledgebase:
http://support.toshiba.com
Aug 17, 2014 | Computers & Internet
I need to reboot windows xp on my toshiba satellite laptop
The Toshiba Satellite A10-S169 includes several utilities to improve the performance or security of the computer, and to reconfigure the system's settings. Toshiba Satellites running Windows Vista 32-bit and Windows XP come with the Toshiba HDD Recovery Utility, which allows you to create a recovery CD of your system and applications. The recovery CD will allow you to restore your system and its settings in case your hard drive fails.
Click "Start." Click "All Programs." Expand "Hard Disk Recovery Utilities." Click "Recovery Disc Creator." Select "CD" as the type. Check "Recovery and Applications." Insert a CD into the disc drive. Click "Burn." The Toshiba A10-S169 will begin writing the recovery content to the CD. Follow the on-screen prompts to burn your recovery files to disc. Hope this helps.
Jan 10, 2013 | Microsoft Windows XP Professional With...
Recovery disc
Evidently Toshiba has a special page for this... it claims there is a recovery partition you can access to restore it to factory condition. Should this option fail, you can use the recovery discs it came with to restore manually... assuming the hard drive itself did not come defective (which is possible). If you determine the hard drive is shot I suggest you make a warranty claim... if you want it asap, buy a 2.5 in SATA HDD and get the service manual to install it, then run the recovery discs. I will warn you though these new laptops (2009+) sometimes don't take well to the 'wrong' parts being installed, the BIOS may not recognize it, or the recovery discs may not like it. If you going to go the surgical route, let me know. Good luck.
https://www.csd.toshiba.com/cgi-bin/tais/support/jsp/serviceUnitVerification.jsp
Jan 15, 2012 | Toshiba Computers & Internet
How do you go about to format a toshiba l650 and reinstall windows 7
Hi! If you have the Windows 7 disc just insert it restart the computer. It will boot directly from the disc. Then follow the step by step instructions here.
If you don't have the Windows 7 disc, you have two ways to reformat your Toshiba computer.
Using Toshiba HDD Recovery Utility from the recovery partition
In case of a hard disk drive failure, you may be able to restore the drive to the factory default state using the on-disk Toshiba HDD Recovery Utility (in a special partition on the hard disk drive).
You can select restoring the entire hard disk drive to the factory default state, or restoring only the C: drive -- without affecting other partitions (for example, a D: drive) -- or changing the size allocated to your C: drive, and then restore it.
To recover your hard disk drive from a system failure using the utilities stored on your computers HDD, follow these steps:
  1. If the computer is running, shut it down -- by clicking Start, Shut Down, and again Shut Down.
  2. Press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear, presenting three options:
Sample TOSHIBA HDD Recovery Utility screen
Restore Original Factory Image (Recommended)
CAUTION:
Restoring a hard disk drive to its factory default state deletes all partitions on the hard disk drive and all data stored on those partitions. All of your files and information will be lost! Be sure to back up all important files first.
  1. Press 1 to restore your hard disk drive to its original factory default state. A confirmation message will appear, indicating that all data will be overwritten and lost during the restore process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating the HDD has been restored.
  3. Press any key to restart the computer.
* The options 2 & 3 are for advanced users.
Hard Disk Drive Recovery using Recovery CDs or DVDs
You may also wish to to run the Toshiba HDD Recovery Utility from Recovery CDs or DVDs that you have created.
Insert the first Recovery CD or DVD into your CD/DVD drive, and turn on the computer. Once the computer is running, the TOSHIBA HDD Recovery Utility screen will appear, presenting the same three options above. Again Press 1 to
restore your hard disk drive to its original factory default state. Click Yes to begin the recovery. Press any key to restart the computer.
Installing Drivers and Applications
The TOSHIBA Application Installer allows you to reinstall the drivers and applications that were originally bundled with your computer.
To reinstall drivers and applications:
  1. Double-click the "Toshiba Application Installer" icon on the Windows desktop. This utility may also be launched by clicking Start -->All Programs --> Hard Disk Recovery Utilities.
  2. Click "Next".
  3. Click the item(s) you wish to install. To select multiple items, hold down the Ctrl key as you click your selections.
  4. Click "Install".
  5. Follow the on-screen prompts to complete the installation process.
Hope this helps.
Jun 19, 2011 | Toshiba Computers & Internet
Missing BootMGR on L45-S7423 won't let me use recovery disks from Toshbia...I also sent error messages while using recovery disk to you before..trying disks again what process to I select out of stste box...
It is possible that it is a HDD failure . I had a customer already today with the same problem . we end up changing the HDD . to be sure try to take out the HDD plug it into external case and plug it into another PC and see the results.
May 11, 2010 | Toshiba Satellite L45-S7423 Notebook
I was wiping the hard drive when the laptop
Please come back to us with the exact error if you get any.
However, how you are performing recovery. Using recovery manager or recovery discs?
If you are using recovery manager, please perform hard drive self test and check with the result.
Hard drive self test steps:
1. Turn Off the notebook.
2. Turn ON the notebook and keep tapping F10 key
3. Once you are in BIOS, navigate to tools/diagnostics tab with the help of left and right arrow key.
4. You will find Primary HDD self test or HDD self test.
5. With the help of up and down arrow key select the respective test and hit enter.
6. Short test will take only 4-5 minutes. However, long test may take 40-60 minutes.
If the hard drive is fine, try to perform recovery using recovery discs....
If still the problem exists try with different discs.
If the hard drive fails replace the hard drive.
Hope this will work for you!!!!!!!!!!!!!!!111
Mar 17, 2010 | HP Compaq Presario V2000 Notebook
Satellite L305-S5921 (again)
There is a greater chance that you have a bad HDD (hard drive). Since the Recovery image is in the HDD, you still need the recovery disc.
Replace the HDD and run full system recovery using the discs.
Hope this helps.
Dec 21, 2009 | Toshiba Satellite L350-ST3701 Notebook
Toshiba laptop a105-s4034
You need to set your CD/DVD/CDRW Disk Drive to Boot First. If the Second set of Recovery CD's don't work, Then they are the Wrong one's for that unit.
Feb 12, 2009 | Toshiba Satellite A105 Notebook
I have a toshiba satellite A 105-S2236 system unit. i bought it cheap, but there is a hdd password on it. is there a way to find out what it is? or am i just out of money? would greatly appreciate the...
Unfortunately, there's no way to remove an HDD password. You can, however, just purchase a new hard drive and replace it. You can always get/purchase a recovery disc from Toshiba. Just call their technical support and ask for a recovery disc at 1-800-457-7777
Sep 09, 2008 | Toshiba Satellite A105-S4334 Notebook
Open Questions:
Toshiba Satellite L45-S7423 Notebook Logo
60 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
