Question about Casio EXILIM Card EX-S770 Digital Camera
My CASIO EX-S770 won't charge - its been on charge for 48 hours and the red light is still flashing
  • 9 more comments
  • lpgiven Jun 26, 2008
    camera won't charge - flashing red light.
  • kristinaz Jul 07, 2008
    Hi My Casio Ex S770 won't charge, I left it over night on the charger but red light still keeps flashing? I still can you view the photos while it's on "charge", but then I remove it from charger it's not responding.
    Pls help?
    Kind regards
    Kristina
  • Anonymous Sep 19, 2008
    I borrowed a Casio EX-s770 from my brother and now it wont turn on! I put it on the charger and the light just blinks! I don't know what to do, Please help!! Thanks!
  • Anonymous Jan 17, 2009
    Same thing! I dont know what to do!
  • TR808 Jan 18, 2009
    FIXED!
    wow i had exactly the same problem as the other posters here. thankyou "rabscuttle"!
    9v battery trick = brillo.
    how did casio manage to not amend this?!
    it seem when you leave your camera alone for about a month, the battery will drain (even if you dont use it) and it will run into thos problem.
    thanks for your help
    Jack
  • crystalannie Jan 28, 2009
    I have the same problem!! I left it uncharged for less than a week then it wouldn't charge again! Does the trick really works? I'm afraid that it's gonna blow up or something....
  • ggo912 Jan 29, 2009
    My casio ex-770 battery,everytime i try to charge overnight,the' charger always flashing the red light.It won't charge my battery.How can i fix it? Can you help me thanks..
  • harebele Feb 12, 2009
    I had this problem while my exilim s770 was still under warranty. I sent it in to get it repaired for free, and when I received it back it was fixed. That was about 8 months ago and it just started it again. Whenever I place it on the charging dock, the red light just flashes.
  • Anonymous Mar 15, 2009
    camera ran out of battery sometime in the last 2 weeks, I left it alone and when I tried to charge it again (it was to the point of not even being able to turn on) a red light kept flashing but my battery remained uncharged. I can view my photos on the camera while it's on the dock but that's about it. hard reset did not work. looking for a brillo pad...
  • kolbeinnl Mar 21, 2009
    9 volt trick works grate thank you very much
  • johntheboy Apr 20, 2009
    it work fine for me great tip.
    Sniper:
  • 62 Answers
From theslug on another thread. Thi worked great for me...
"Hi,I just found a soultion on another website and it appears to have worked for me.Apparently the battery loses it memory when fully discharged,to fix this take a 9v battery and place the terminals + to + and - to - with the camera battery for 30 seconds or so then put the battery back in the camera and charge as normal.I just did this and it seems to be charging and the red light is solid.hope this helps."
Posted on Dec 06, 2008
The theory behind the posted suggestion is that there is a chip on the battery that tells the charger 'here I am, I'm a valid battery, please give me juice.' That way the charger doesn't give any power to something that might blow up. But if the battery is totally dead, the chip can't answer the call, and so no juice is provided. Seems valid - don't know that I'd use 9V to do it, but a good approach is to jump it from another battery in the same 3.6V range.
I was having the same pwr up problem from a dead NP-20 battery, so used another 3.6V pack to dump some joules in and sure enough it's charging properly now (w/o the flashing red light). I assume it will complete and be fine again. So the warning - try not to let your LiIon battery packs get discharged and sit around.
-Ross
Posted on Apr 12, 2009
  • 4 Answers
So I have posted this on several others hopefully you still have your casio. I was having the same problem where my battery wouldnt charge. I bought a new charger and battery. That did not fix it. The battery is held in by a locking clip that supposedly holds it close to the metal conductors that the positive and negative touch the camera inside the casing. I took the battery out, looked inside where the battery sits and used the paper clip to somewhat bend the metal up so that it makes contact with the battery hence you get your charge. If the battery was dead you will not know until you charge it for about a half hr. The reason I knew it was the metal conductors was because i charged my battery with separate charger that I bought and put it in and it still did not work. I pushed the battery in the slot and held it ther while simaltaneuously pressing the power button. The camera came on...once I let go of the battery it turned off. Then I got the paperclip and fixed the battery connection. This also explains why it will continue to happen over time.
hope it's that simple for you
Posted on Apr 28, 2009
I have a casio exilim ex z77. My battery to my camera wont charge when I put it on the charger. The red light just blinks.
hi, once you charge your battery and the red light blink it means your NP-20 battery is damage and you need to buy new one.TIP- charge 1.5 hours only and if youre not using you camera for a long time its better to remove the battery.
good luck and thank you my friend
Jul 08, 2010 | Casio EXILIM Card EX-S770 Digital Camera
Casion Exilim EX-S880 Charging Error
Clean your connecting areas with alcohol . If that dont work . It could be a bad battery
Aug 18, 2009 | Casio EXILIM Card EX-S770 Digital Camera
My casio ex-s770 camera does not charge battery.keeps flashing red light when its on charging.
There was a recall on the batteries. Call customer support and they will send you a new one for free.
Jun 07, 2009 | Casio EXILIM Card EX-S770 Digital Camera
Casio ex-s770
Call tech support and they will replace the battery for you free of charge.
Mar 25, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Exilim EX-S770 does not start or charge
same problem
solution: buy a new bttery or charger??
Mar 17, 2008 | Casio EXILIM Card EX-S770 Digital Camera
MyCasio exilim 2.0 won't charge!
Juat wondering if you have a casio exilim ex-s2 that you would want to sell for parts? Or if you know anyone that has one?
Werk73@yahoo.com please let me know
Feb 14, 2008 | Casio EXILIM Card EX-S770 Digital Camera
EXILIM Card EX-S770
call Casio Customer Support. They should be able to assist you.
Dec 27, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Casio EXILIM  Card EX-S770 Digital Camera Logo
697 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
