Question about HP Pavillion ZV6000 Notebook
Manage partitions I partitioned my C: drive successfully to provide a partition for data. Unfortunately the partition does not show up in COMPUTER. It clearly exists in the MANAGE DISCs utility. Even opening the new partition shows the contents here. In addition when I connect two USB flash drives the second one does not show up in COMPUTER. Is ther a solution or cause?
  • ianberesford May 12, 2008
    My ready boost usb shows in COMPUTER in the same usb port so that it cannot be the problem suggested. I tried it anyway. Any other solutions please
    Guru:
  • 55 Answers
Go to device manager and uninstall the usb root hub and restart the computer if the usb still does not respond then call hp total care for the replacement of the motherboard as the usb drives has gone bad ..it will be replaced for free if u r in warrenty..or u will have to pay ..
Posted on May 12, 2008
How can I rename hard drive partitions after having lost them by enlargening a partition?
I'm assuming you are on windows. Right click on My Computer and select Manage. Select the Disk Management option on the left. Right click on the partitions you are missing a drive letter for and then select Change Drive Letter and Paths. That should let you choose the drive letter.
Jul 30, 2014 | Samsung SpinPoint T HD501LJ 500 GB SATA...
How can I see the hide partition in HDD
click start control panel scroll to folder options view place a tick in show hidden files folders and drives
There are also Data Recovery programs that might be very helpful to recover your important information.
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities.
Some addition links found on Google
http://www.datarecoveryreview.net/
http://www.easeus.com/resource/hard-disk-data-recovery.htm
hope this helps
Oct 09, 2012 | Computers & Internet
How to partition. appreciate a step by step instruction. thanks
http://www.filehoo.com/download/Partition-Magic-8,0.aspx when you download partition magic you will have the option to make rescue to disks to boot from make these disks then change your first boot device your to floppy drive this will give you options to partition then partition only the good sectors of your hard drive and install an operating system to the good partition Partition Magic 8.0 description
Partitioning your hard drive plays an essential role in maintaining your computer-preventing conflicts, protecting data, improving efficiency, and increasing performance.
PartitionMagic allows you to create, resize, merge and convert partitions without destroying data. Award-winning PartitionMagic Pro from Symantec is a leader in hard-drive partitioning software. PartitionMagic Pro allows you to create, resize, move, and convert partitions without destroying your data. You can quickly and easily create partitions, which can act as file drawers on your hard disks for storing valuable information such as data files, applications, and operating systems. Storing information in separate partitions helps you organize and protect your data, safely run multiple operating systems, and reclaim wasted disk space.
i have used this and found it a very good program and is easy to install
hope this helps you
Aug 20, 2011 | Seagate Freeagent Goflex Desk 3 TB Desktop...
Lost NTFS partition on my WD1600BEVT, how do you restore so I can use again?
Depends on what you did to "lose" the partition-table.
Download the free 'PTEDIT.ZIP' file -- it is a "partition-table editor".
UNZIP it on a different computer, and extract the 'PTEDIT.EXE' program.
Run PTEDIT on your computer, and update the partition-table.
Jul 14, 2011 | Western Digital WD1600BEVT 160 GB SATA II...
Recover partition format
Did you want to recover formatted partitiom or recover the format (or called file sytem,such as NTFS and FAT32) of partition?
You can recover formatted partition with partition recovery program.I have succeed with Tenorshare data recovery.It can recover partition after deeply scanning your hard drive to look for lost data you accidentally formatted.You can get it here:http://www.any-data-recovery.com
If you want to recover the file system of partition,you can copy your data into a portable device and then transfer the file system of partition.
May 30, 2011 | Computers & Internet
I have my drive split into 2 partitions but only 1 shows up now, how can i get it back to 2 partitions?
With the drive connected to your computer and powered on, go to the Start Menu and you will see where it says "Computer" or "My Computer" (depending on operating system). Right click on "Computer" or "My Computer" and a menu will appear.
On that menu click on "Manage" and it will open up the Computer Management window.
In the Computer Management window you will see "Disk Management" on the left towards the bottom. Click on that.
In the Disk Management window you will see a list of all of your drives and partitions. Find the hard drive that has the missing partition and see if the missing partition shows up in there. Make sure it shows that the partition is formatted as a filesystem that Windows will recognize such as NTFS and also make sure that it is assigned a drive letter.
If the partition is formatted and does not have a drive letter assigned, Right-Click on the partition and a menu will appear. On that menu, click on "Change Drive Letter and Paths". That will open a dialog box that will take you through the steps of assigning a drive letter to that partition. Once you finish, it should show up in "Computer" or "My Computer" as a drive.
If the partition is not formatted to NTFS or the filesystem you would like it to be (NTFS is recommended for Windows), just Right-Click on the partition and the menu will appear. On that menu click on "Format" and go through the process of formatting the partition to NTFS or your preferred filesystem and it should format the partition and assign a drive letter to the partition and should now show up on your computer.
WARNING: If you format the partition, you will lose any data on that partition and you may not be able to recover the lost data.
I hope this helps! If it does, please leave me a good rating and feedback. I would greatly appreciate it!
Best Regards,
James
Jun 02, 2010 | LaCie (300770) 250 GB Hard Drive
Is it possible to keep the operating system on drive c and the data on drive d and how to do this
yes, partition the drive...
If installing a new OS, Partition drive one with 1/4 of the drives size, then install the os to that partition, once installed if using Windows, partition 1 should show as C: drive, and partition 2 should show as an additional drive.. Each Partition will show as a separate drive..
If the OS is already installed, you can use a program such as partition magic, or you can use MS disc manage (right click My Computer, Select Manage)..
Oct 03, 2009 | Computers & Internet
Partition problem
In my humble opinion, the best option is to install a second (blank or larger) drive. Install some recovery software such as "easy recovery pro" or something that will be able to read files from a filesystem that has had the partition table written over. Start with trying to scan using FAT32, and in failing that, try NTFS. Restore the data to the second drive, format the first and partition as required. Copy the data back to the first drive to the partitions that you specified, and erase the data from the second drive. A free option may be pandora recovery, available at http://www.pandorarecovery.com/features/
Jan 20, 2009 | Microsoft Windows XP Professional
Partition parameter
From the data you provided, the D drive is deleted and is newly created. But it is not yet formatted. So the data is virtually deleted. Why I said virtually is because, the data is still there on the drive physically and you can recover it using third party tools like OO disk recovery tool. That is why partition magic is still showing data on it.
And it is also obvious that the task which Partition Magic started (splitting drives) is not finished properly. That is why K partition is incorrectly formatted. It is natural that it asks format of D drive because D drive belongs to no file type and it must be of FAT32 or NTFS or other file system.
The solution for your problem is try recovering your data on D drive using disk recovery tools. Then format it using FAT32 or NTFS. Format K drive also in FAT32 or NTFS. Use either partition magic or Computer Management. Since already PM caused problems on your computer, try computer management. It is safe.
C: Drive space issue
Hello
if you have to little space on your C partition you can resize it, if you using vista.
1. right click on my computer->manage
2. choose storage->disk management
3. right click on the C volume and extend volume
4. put more space on C and then OK. that should solv your problem
you can also move your swap file to D: that gonna save some space on C.
1. rightclick on computer ->properties
2. click advanced system settings
3. click on the advanced tab settings on performance.
4. choose advanced tab->change
5. click on D: and write a custom size(it should be double of your amount of ram)
6. click set
7. then click C in same window and choose "no paging file"
8. click set and ok, then restart your computer.
good luck dont forget to vote.
Sep 08, 2008 | Acer Aspire 3680 Laptop
HP Pavillion ZV6000 Notebook Logo
54 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
