Question about HP PSC 2175 All-In-One InkJet Printer
HP2175 says "printing" - job is stuck in printer - have uninstalled and reinstalled software and run updates - I can remove print job from computer - can't find or remove the one stuck in the print queue
    Director Badge:
    Uploaded 100 video answers.
  • HP Master
  • 685 Answers
Need to clear everything out of the printer queue then uninstall &reinstall the printer & driver
Open Printers and Faxes. Open printer. Highlight jobs and Right click > Cancel, or Documents > Cancel.
For those stubborn jobs, Right click My Computer > Manage. Choose Services and Applications > Services > Print Spooler. Right click and stop. Then start.
Delete the printer from Printer and Faxes to uninstall. You should check Add remove programs for any printer software.
Windows will install automatically with a refresh or reboot. Or, use software that included with printer.
Oct 10, 2012 | Dell Photo 926 All-in-One Printer
My dell dimension 2400 series computer has lost comms with the local dell AIO A920 printer. Connections seem to be good. It seems a print job has got stuck somewhere. HELP! AJCook
how your printer icon is looking on control panel, if dim, it means it is not detecting , if normal it means detecting then,
go to control panel open printers, then open your printer, cancel all the documents, then send a print command and check
Nov 01, 2008 | Computers & Internet
Print job disappearing and not printing
1. Check for a paper jam. Paper jams occur when one or more sheets of paper become stuck in the feeding or printing mechanism. Gently remove any jammed paper and reset the printer.
2. Check ink levels. Those ink cartridges run out fast. If your printer looks like it is printing but nothing comes out on the page, you might be out of ink. Try replacing the cartridge and printing again.
3. Check for a clogged print head. If you know you have ink, the print head might be clogged. Navigate to "Control Panel > Printer > Right Click > Properties > Maintenance > Clean Cartridges" to attempt to clean the print head.
4. Reinstall printer drivers and software. If none of the above helps, try uninstalling and reinstalling the printer and software to correct possible software bugs, errors or conflicts.
Canon-Specific Issues
5. Check printer drivers. Navigate to "Control Panel > Printers > Right Click > Properties > Update Driver" to check for a new driver for your printer. You can also find drivers and software on the Canon Support site (see Resources).
6. Resolve the Waste Ink Error. Press menu on the printer and press scan/copy to enter service more. Press the right arrow to access "NVRAM." Set ABS-M level to 0. Set ABS-P level to 0. Press "Stop" to exit.
7. Resolve Wrong Cartridge Message. Turn off the printer and unplug the power cord. Remove the cartridges and the print head. Clean the print head in lukewarm water. Set it aside to dry. Clean the contacts gently with an eraser and wipe with a tissue. Reinstall the print head and reinsert the cartridges. Run a cartridge alignment.
8. Resolve E0D02 error. Clean the cartridges and the sender strip. The sender strip is behind the rubber drive belt behind the main hatch. It runs horizontally across the machine. Wipe it gently with a lint free cloth.
Aug 19, 2012 | Canon Pixma Mp250 Printer
Printer was turned off during a print job and now will not print an entire page. Is there a master reset on this printer?
I would suspect it is the computer sending the printjob and not the printer itself. uninstall the printer software and reinstall it. after that perform all updates and attempt to print again and should receive a full document.
Sep 26, 2009 | HP LaserJet 1320 Printer
HP PSC 2410 stopped printing. Reinstalled sw - printer scans faxes prints self test but won't print docs! HELP!
When you reinstalled it did you unplug it from the computer. Often links to printers are lost, it's a Windows thing, frequently people reinstall in desperation, forgetting to uninstall the original and disconnect the printer USB. So, unplug the printer USB from the computer, go to control panel,and printers and delete the printers that you are going to reinstall which you see there. Then go to add and remove programs and remove all software.
If there are print jobs pending you may not be able to uninstall or delete, so click the printer and delete all jobs pending, then try the uninstall again.
When all is uninstalled, restart the system and reinstall, plugging in the printer only when the software asks for it.
It being an HP the uninstall option may well be on the installation disc so you can use that if you wish.
Aug 01, 2009 | Office Equipment & Supplies
Why can't I Uninstall Hp2610 software for Reinstall?
Hi all of you
to uninstall you have to clear the bended print job, then go to Add/Remove.
hope this helpful for you,
thanks
Hamedo
Nov 17, 2008 | HP Photosmart 2610 All-In-One InkJet...
Laserjet 1020 with mac osx
Ok, you may want to consider re-installing the printer driver or in any case download updated printer drivers. Just don't forget to reboot after installing:)
Oct 16, 2008 | HP LaserJet 1020 Printer
Can't print from the 'print' button on screen, will copy and scan from printer, will run test from computer
try uninstalling the update as long as it is not one necessary to new programs. Find the uninstall for it by doind a search in the run menu, and the uninstall file should come up. Follow prompts. Now try printing again. If this fails, you may have to uninstall printer drivers ie go to remove programs, unilnstall printer and all related files. Now reinstall using your original printer canon disk for your operating system. Try printing again.
Apr 16, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Cannot print unless I turn off computer and then reboot.
I'm not a big fan of Lexmark in general in part due to their software and drivers. For me this type of behavior from their printers/software became common about a year ago, the fix being to use the more generic Windows supplied printer drivers. I would suggest that you uninstall all software the printer installed and remove all of the printers print queue(s)including any associated with the fax function. Unplug the printer USB cable from the computer, reboot your PC and reinstall the printer from scratch using your original installatin CD.
Dec 03, 2006 | Lexmark X73 All-In-One InkJet Printer
Dell 922 aio printer
it's unusual to have same problem if completely uninstalled printer(removing printer, then uninstalling,after which use printer installation cd then re connect printer when prompted). If you have a spare usb port install software then connect printer to a different usb port. Lastly try; go to printers and faxes folder>right click on printer icon>properties>advanced, then click the radio button 'Print Directly to the Printer' and see if it prints. Also make sure this printer is set to default printer Try an updated driver, if any,from the Lexmark web site, as they are the same printer without the Dell logo. Your rating is appreciated.
Nov 13, 2006 | Dell 922 All-In-One InkJet Printer
HP PSC 2175 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
