Question about Syntax SV266A SKA KT266A Motherboard
What is max new cpu speed to change for old cpu ? k7sv266ad
  • dick cory Jul 13, 2012
    Syntax was bought out by another co who does not support the syntax MB. Its a long time since I upgraded the cpu (which I ,just by chance, found at a surpluss website for $3.) this raised the cpu to 233mz. This I understand is min speed necessary to access the internet There is a dip swich which needs to be reset. (I will have to open my computer up to find then)
    I upgraded to a pentium mmx and use 1,300,000 mem.
    If you are still looking to do this, email me at rb0000@hotmail.com.
  • 5,660 Answers
The KT266A is a VIA motherboard chipset,
http://en.wikipedia.org/wiki/List_of_VIA_chipsets#Slot_A_and_Socket_A
The motherboard chipset for your motherboard, consists of a Northbridge, and Southbridge chip.
The Northbridge is a VIA 8366A
The Southbridge is a VIA VT8235
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
[Note*
CPU = Central Processing Unit. Another term used is Microprocessor, or Processor for short ]
The Northbridge chip handles the faster capabilities of a computer.
Handles the Processor, Ram Memory, and HIGH-speed graphics.
[A graphics card installed into a PCI expansion slot is Not high-speed graphics.
Integrated Graphics is Not high-speed graphics.
AGP and PCI Express are high-speed graphics.
If you have an AGP graphics expansion slot, it is handled by the Northbridge chip.
If you have a PCI Express expansion slot, it is handled by the Northbridge chip ]
The Southbridge chip handles the slower capabilities of a computer. This is shown in the diagram.
The VIA KT266A's Northbridge chip, (VT 8366A) supports AMD processors with UP TO a 266MHz Front Side Bus.
(266MHz FSB)
In the chart you see under the FSB heading -> 100 - 133MHz
100MHz to 133Mhz.
AMD processors are 'Double-Pumped'.
Therefore 133MHz becomes 266MHz.
233Mhz with the jumpers at their present positions?
Weird!
Looking at the motherboard, as it is mounted in the computer case; Processor to the Top, Ram Memory slots to the Right,
5 White PCI slots to the Bottom;
The J4 jumper is above the CMOS battery.
The CPU Frequency Select jumper.
(The J1 jumper is right next to the CMOS battery. To the left. That is the Clear CMOS jumper)
The jumper has 3 pins. Number 1 pin is on the LEFT.
From Left to Right; Pins 1, 2, and 3.
With a jumper block,
http://en.wikipedia.org/wiki/File:Jumperblock-shunts.jpg
,on Pins 1 and 2, you have a 100MHz FSB.
With a jumper block on Pins 2 and 3, you have a 133MHz Front Side Bus.
Processor you pick have a broken pin?
You can use AMD Athlon processors with up to a 133Mhz FSB, or AMD Duron processors with up to a 133MHz FSB.
[Actually 200MHz FSB, and 266MHz FSB. Remember what I stated about Double-Pumped ]
Example,
http://www.weirdstuff.com/cgi-bin/item/13160
Here is a link to a free User Manual, for the Syntax SV266A motherboard,
http://www.scribd.com/doc/41762039/Manual-Sv266a
(Just keep scrolling down)
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Jul 14, 2012
Change the back shock on a 1987 Mitsubishi mighty max 2.0 5 speed truck
Basically, remove the old one and fit a new one.:) If the shocks are inside a coil spring, you ay need to use 'spring compressor'. If it's using lef springs, it's very straightforward.
May 13, 2014 | Mitsubishi Mighty Max Cars & Trucks
What is the role of a high speed CPU in Mono Laser Printers?
it is to transfer the document to the ink system ready for print
Dec 23, 2012 | Brother HL-5340D High-Speed Laser Printer...
New cpu fan has 3 prong connecter, old has 4. what is,or does the 4th blue wire have to be connected?
You can connect the CPU fan as normal but it can only run at one speed and voltage hence only having 3 wires.
Your other CPU fan which had 4 wire was able to run at 2 different voltages and speeds and are mainly used to keep the noise down and run quietly.
Regards.
Jul 10, 2009 | eMachines T5048 PC Desktop
Want to increase the speed of my pc
Hello alanwemple,
Increasing the RAM is surely a good first step to speeding your computer up some. It was my impression that the a340n supports a total of 4GB, so you might want to recheck your manual. And 4GB would certainly be better than 2. As for the CPU, it's upgradeable on this machine, it uses a "Socket 478" chip. Simply remove the old one and insert a new one. But, the CPU is probably not contributing that much to your slowness problem.
Two things that I'd look at first, before I tackled the CPU is video performance and the hard drive. A faster video card with more video RAM can substantially speed things up. And, the hard drive may need some maintenance, starting with defrag. You may also want to do a disk cleanup and while you are at it, run a full virus check and malware detection program such as MacAfee or Norton to make absolutely sure that no bad stuff is slowing you down. And these are cheaper than replacing the CPU.
Hope this helps.
Apr 07, 2009 | HP Pavilion a340n (DQ099AABA) PC Desktop
How do I overclock a Celeron 733mHz PGA370?
You can only overclock your computer if it has ATAPI BIOS. So get into BIOS upon bootup and if you have ATAPI then it will say it across the top. It will also have a section for the CPU with the current speed and an option to change it.
Dec 22, 2008 | Intel Celeron, 600 MHz (SL46U) Processor
Changed cpu on an abit va-10 mb but the fsb stays at 266
Unless the mobo is compliant with a front side bus speed of 333mhz, the cpu you have will only run at 266mhz max, in other words the cpu will down-clock to the 266mhz bus clock and therfore run more slowly. check with the mbo handbook, or on CMOS tosee if yoy can change the fsb setting. ask for more help if needed.Can you give me the full code of the mobo ?
Nov 29, 2008 | Abit VA-10 333MHz FSB VIA VT8378 Chipset...
Acer aspire 3050 (XP2) - cpu speed nearly always about 800 mhz (1/2 speed) even tho settings are for max speed etc
I fixed this problem by uninstalling the Acer management suite, everything much faster now and the operating system has facilities for changing everything you need to anyway.
Jul 24, 2008 | Acer Computers & Internet
Upgrading CPU not booting BIOS
Key Features
Form Factor Micro ATX
Compatibility PC
Chipset Intel 865GV
Compatible Processors Intel Pentium 4
Front Side Bus Speed 800 MHz
Technical Features
Integrated Input/Output Ports USB 1.1 x 4 • Serial Port x 1 • RJ45 Lan Port x 1 • PS/2 Mouse x 1 • PS/2 Keyboard x 1 • Parallel Port (ECP/EPP/SPP) x 1 • Floppy Port x 1
Expansion Slots PCI x 3
Storage Controller Type(s) Serial ATA x 2, DMA/ATA-100 (Ultra) x 2
South Bridge Chip Intel ICH5
Processor
Socket Type Socket 478
Max supported CPUs qty 1
Memory
Number of Memory Slots 4 x DIMMs
Supported RAM speeds 400 MHz
Max Supported RAM 4 GB
so this is the board..no doubt that the cpu fits and is a good choice for you.
however,if the old one works fine and this one ,even if it is new,does not wiork,the only rational conclusion is that this one is malfunctioning ,maybe from the factory,or maybe one of the pins doesnt make a real contact.
check very attentive the integrity of the pins and of the cpu socket in the motherboard.
there are also some cases that the motherboard doesnt support the high Frequence of the new processor,but that was a problem for the old PCs..I doubt you have it with your motherboard.
I suggest you to bring it back and to ask for a replacement,or at least go with it to  a specialised cervice and let them check it.
sorry for not beeing a huge help to you,so dont rate my answer if you dont feel to..
bye bye and good luck..keep me up to date with your situation
bye
Feb 06, 2008 | AOpen MX4SGVI-4DN2 (91.8B810.407)...
Extreme slow performance, cpu performance maxed out
Boot to safe mode and see if the problem is the same.
Have you checked for viruses and spyware?
Look in Control Panel/Admin Tools/Event Viewer, System and Application for red marks.
Do you have a temp monitor installed?
Have you changed anything in the BIOS? Set to safe defaults.
Oct 26, 2007 | ASUS P5N32-SLI Premium Motherboard
Syntax SV266A SKA KT266A Motherboard Logo
228 people viewed this question
Top Syntax Computers & Internet Experts
Steven Burn
Steven Burn
John Anderson
John Anderson
T-Comtech Repairs
T-Comtech Repairs
Are you a Syntax Computer and Internet Expert? Answer questions, earn points and help others
