A SIMPLE AUTORUN CREATION
I LOST MY AUTORUN .INI FILE AND NOW I CANT OPEN THE PORTABLE USB DRIVE (AUTORUN).NEED HEL
  • 6,487 Answers
If your portable usb drive still detected by your pc you can just simply right click it and go to properties and there just go to Autoplay then select Open folders and files.
Posted on May 12, 2008
Cannot rename hard drive
autorun.inf is a hidden system file. Make sure you can VIEW hidden files. Then look again at your portable drive's root folder.
(View TAB in your file explorer - Hidden Files checkbox)
Jan 28, 2014 | Toshiba Canvio 500 GB USB 3.0 Portable...
How do I rename the Urdrive when it shows up on My Computer?
Something to add to HoboPelican's solution, if you open the autorun.inf file with notepad or wordpad you can change the name on the last line where it says "LABEL = KINGSTON URDRIVE" then just replace KINGSTON URDRIVE with the name you would like to call the drive.
Jun 12, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I am having a Seagate FreeAgent portable hard drive(500GB), a corrupted icon is being shown when I attach it to any PC and it gives a dialogue box of "open with" when I double click on it, But I...
Hi amanvirdi198
The problem seems to be an infection of a virus which has changed the icon of your removable drive and also when you open it up you get the "open with" option by default.
Please follow the below instructions.
  • Select show all files option from the folder options which you find in the start menu the path is :-Start - Control Panel - Tools menu - Folder options.
  • In folder options go in the view tab and select show hidden and system files.
  • Once you are done selecting this option , all you need to do is open your removable drive by right clicking on it and select the 'Open' Option , Or if that does not work use the explore option as you have been doing already .
  • You will find that the hard disk now shows up the contents, so you need to find the autorun.inf file in the root drive , once you find it , you have to 'delete' that file, also delete any suspicious hidden .exe file which is in hidden state and of a small size , which is nothing but a virus which spreads as soon as you plug in your external hard drive and the autorun.inf file get's executed automatically.
  • Therefore once when you delete the autorun file , you should have your hard drive working properly.
  • The above method was the manual method , now if you want to delete the autorun problem automatically via a software , i recommend you to download autorun virus killer by clicking on this link http://bit.ly/k3dOve
Hope this helps...:)
Your feed back would be appreciated.
May 26, 2011 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
Autorun a .exe automatically off a USB drive.
Open Notepad Type in: [autorun] open=PStart.exe action=Run PStart Program icon=PStart.exe label=My Portable PC Save the file as autorun.inf Put the file in the root of your USB flash drive The next time you insert your removable drive into your PC, the specified program will autorun from the USB drive
Of course you use your own names at the Commands.
Jan 26, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Any file or document from word or excel.I have tried with other flash drive but same problem applied.
you may have a virus which is possibly resident on your flash drive.
Lately virus have been attacking flash drives and being spread to computer.
look in your drive for autorun.ini autorun.inf desktop.ini
if your see these files your infected and will need to take steps to get rid of the virus.
do a search for "flash drive virus" in gogole and see what comes up
Jun 05, 2009 | Dell Dimension 1100 PC Desktop
CD html presentation-hyperlinks don't work with other pc's
To create an Autorun-enabled CD-ROM, proceed as follows:
  • Create an Autorun.inf File
    Autorun.inf is a text file that is located in the root folder of your application CD-ROM. It provides to the computer the name and the location of the startup program for your application that is installed when the CD-ROM is inserted. The Autorun.inf file can also contain optional information including the following:
  • The name of a file that contains an icon that represents your application's CD-ROM drive. This icon appears in Windows Explorer instead of the standard drive icon.
  • Additional commands for the shortcut menu that appears when the user right-clicks the CD-ROM icon. You can also specify the default command that runs when the user double-clicks the icon. Autorun.inf files are similar to .ini files.
  • The [autorun] section contains the default Autorun commands. All Autorun.inf files must have an [autorun] section.
  • icon: Specifies the path and the file name of an application-specific icon for the CD-ROM drive.
  • open: Specifies the path and the file name of the startup application.
Autorun.infThe following is an example of a simple Autorun.inf file. It specifies Filename.exe as the startup application. The second icon represents the CD-ROM drive instead of the standard drive icon.
[autorun]
open=Filename.exe
icon=Filename.ico
May 07, 2009 | Dell Dimension 4600 PC Desktop
E:/ Access is Denied
this might start by some virus which have put an autorun file on ur harddrive. the best option to fix this problem is just format the harddrive or the partion on which u r having this problem. or else u have to searchon ur harddrive that weather there is any autorun.ini file is prset or not if it is there then just delete it.
Mar 28, 2009 | Western Digital 250GB MyBook External USB...
Can not open drive C
hello
this problem can be fixed by
1 install window again
or
2 attach your hard drive with another system hard drive making your hard drive slave
Nov 16, 2008 | Microsoft Windows XP Professional for PC
ANY DRIVE DOESN'T OPEN????????
it's a virus, undetectable with antiviruses, there is a file named autorun.inf in the drive delete the file and recheck it.
Feb 07, 2008 | Microsoft Windows XP Professional With...
Autorun file
is there and U3 software installed on the device? could you post the contence of th INI file for us to see?
it sounds like you have a program on the pendrive autorunnig when you connect the pendrive this could be some software that can with the drive from the manufacture or something more nasty like a trojan. if you really want to fix it copy everything you want off the drive then format it, this is the quick dirty way of fixing the problem but if you have a U3 style smart disk the autorun software will stay intact.
Nov 21, 2007 | Electronics - Others
Computers & Internet Logo
241 people viewed this question
David Payne
David Payne
