Question about Texas Instruments TI 810 Matrix Printer
My TI 810 printer has begun to error out. It prints a few lines, and the lines appear to "slide" to the left, until it is printing off the left edge of the paper, and then it stops printing, and the error light goes on. Pressing reset restarts the printer, but the error will repeat within a few lines. Any ideas?
  • 787 Answers
Hello.
This is a ribbon problem, it needs to be changed. The fact that the lines "slide" to the left prove that the carrier is not going back to its original position every time.
So, the solution is to change the ribbon.
Posted on Aug 24, 2010
Testimonial: "Thanks! Problem solved! I guess the older, dryer ribbon was causing drag on the printhead or something."
    Novelist:
  • 118 Answers
Carriage motor is losing its place. In the bottom right is a motor with a wire rope that moves the print head. The motor keeps its place with a disk and sensor under the cap.
It thinks it's gone all the way back to the left margin but it hasn't. This can be caused by the printhead catching on the paper or ribbon. Try adjusting the printhead out, away from the page with the lever at the end of the carrage bar. This will lighten your print.
You could also clean paper dots and dust out with a air hose. You can wipe the bars down but don't oil them.
The motor could be going bad or the printhead may have a broken pin that remains out.
Posted on Nov 26, 2014
Thin broken vertical line 8.15 cms from left edge of paper. Appears on both printed and blank pages
your printing drum got damaged there is a thin line on it that you may see with your eyes. you have to replace it
Aug 22, 2010 | Epson AcuLaser C900 Printer
Epson 4000
The error relates to a carriage movement error detected by the printer. This means the printer has detected too much power is required ti move the print head. Reason : All these Service Requests (Service Requests 00010004 , 00010005, 00010006, 00010007, 0001000A, 0001000F, 0001001D) are related to a Carriage movement error that is not automatically due to a Hardware fault. The reasons can be : - The carriage is lock not completely released. - The carriage lock has been partially pushed in after a paper jam or maintenance (for example). Reminder : The carriage lock must be released after unpacking the printer (see setup instructions) as follow : Points to check : In case such an error appears: - Power off the printer. - Ensure the Carriage lock is released (pulled to the left side) - Pushing down the cutter blade, slide the carriage to the left ? At the same time, please check if there is any foreign materials / dust / paper jam in the carriage path. If so, remove them. - Also, make sure that the carriage encoder (T-Fence) isn?t dirty and is correctly set and centered. Let me know how you get on with this info.
Aug 17, 2007 | Epson Stylus Pro 4000-PS InkJet Printer
How do I change the ink cartridge on my Dell 810 printer
Ink Cartridge Maintenance Replacing an Ink Cartridge
  1. Turn on your printer.
  2. Lift the printer unit, and position the scanner support between the tabs to hold it open.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
rcrtdrc1.jpg Aligning an Ink Cartridge You may need to align the ink cartridge when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridge:
  1. Load plain paper. For more information, see Loading Paper.
  2. In Windows XP, click Start® Control Panel® Printers and Other Hardware® Printers and Faxes.
In Windows 2000, click Start® Settings® Printers.
  1. Right-click the Dell AIO 810 icon.
  2. Click Printing Preferences.
The Printing Preferences dialog box opens.
  1. Click the Maintenance tab.
  2. Click Align Print Cartridge.
  3. Click Print.
A blue and black alignment page prints.
  1. After the alignment page has finished printing, place the page face-down on the scanner glass. Make sure the upper left corner of the front of the page aligns with the arrow on the printer.
  1. Press the Scan button scanicoa.jpg .
The page is scanned. When the scan is complete, the cartridge is aligned. You may discard the alignment page when the alignment is complete.
Please download the manual from the link below and go to chapter Ink Cartridge Maintenance:
http://support.dell.com/support/edocs/systems/PRN810/en/ug/ug_en.zip
Hope it helped.
Nov 22, 2009 | Office Equipment & Supplies
GenicomTally T6215 line printer not printing on edges
If your still having problems? 1st make sure the gap is not to tight(cause the to ribbon to drag up with paper). 2nd While printing in test mode, carefully lift up or push down on the ribbon where it comes out or where it goes back in the catridge. After doing the 2nd you should see the exact same thing as will stop printing on right and left edges. Remove the ribbon, their are 2 philip screw on the left and right side of the ribbon deck, loosen them(they will not come all the way out, held on by clips) lift the rbbon deck up and reseat it... tighten the screws back down. last you may have some bad ribbons...
Jan 14, 2009 | Tally Line Matrix T6215 Printer
Not printing
You probably have paper debris stuck to the underside of the print head.
While you are printing, pull the lead from the back of the printer leaving the head free floating and unlocked so you can slide it back & fore. Get a piece of kitchen roll and fold it until it's the size of the track beneath the print head slide the head to the left, place the folded kitchen roll flat down in the print track, slide the head over the folded kitchen roll until it appears on both sides of the head. Grab both ends of the roll and lift it toward the head. Slide the roll sideways left and right to physically clean the bottom of the print head. Try not to tear it as it will trap under the head. let go of one end and slide the head away until you can pull the roll out. It should have a lot of ink and gunk on it. Plug the printer in and the head will reset itself.
Now because printing has been non existant, you'll need to "Prime" the heads. Use the maintenance software and click head cleaning, when finished do not allow the nozzle check pattern to print. Carry out 3 more head cleans cancelling the nozzle check after each one by clicking [Finish] until 4 cleans have been completed. Then allow the nozzle check pattern to print and it should be back to normal. If not perfect, carry out another "Prime" as above.
Hope this helped.
Nigel
The INK Store
http://www.the-inkstore.co.uk
Dec 14, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Will not print test page or documents
  • Make sure the printer is turned off and the paper-release lever is pushed back to the single-sheet position. Raise the paper guide upright.
  • While holding down the LF/FF button, turn on the printer. The PAUSE light flashes.
  • Slide the left edge guide until it locks in place at the guide mark. Next, adjust the right edge guide to match the width of your paper.
  • Slide a sheet of paper down firmly between the edge guides until it meets resistance. The printer loads the sheet automatically.
  • Press the PAUSE button. The printer begins printing the self test.
  • To stop printing temporarily, press the PAUSE button.
  • To end the self test, make sure the printer is not printing. Press LF/FF to eject the sheet; then turn off the printer.
Jul 04, 2008 | Office Equipment & Supplies
HHow do I print envelopes on a deskjet940c. What is the set up.
Here is a how-to for the printer, but I'm not sure if you mean the printer, or in a program.
If this is not what you need, let me know.
HP Deskjet 920c and 940c Series Printers - Printing Envelopes s.gif s.gif s.gif
gtabblt.gif Loading a single envelope gtabblt.gif Loading multiple envelopes gtabseps.gif Loading a single envelope Preparing to print
  1. Place the envelope, with the flap side on the left and facing up, into the single envelope slot.
  2. Push the envelope forward until it stops. See Figure 1.
Figure 1: Inserting the envelope c00104463.jpg Printing guidelines
  • Verify that the Out tray is in the down position.
  • Avoid using envelopes that have clasps or windows.
  • Avoid using envelopes that are shiny or embossed, envelopes with thick, irregular, or curled edges, or envelopes that are wrinkled, torn, or otherwise damaged.
Loading multiple envelopes Preparing to print
  1. Pull out the In tray.
  2. Slide out both paper guides and remove all paper from the tray.
  3. Place no more than 15 envelopes -- with the flap side on the left and facing up -- in the tray.
  4. Push the envelopes forward until they stop.
  5. Slide the paper guides snugly against the edges of the envelopes, then push the tray forward until it stops. See Figure 2.
Figure 2: Inserting multiple envelopes c00104464.jpg Printing the envelopes Each software program is different and requires different steps to successfully print envelopes. For instance, in many versions of MS Word, clicking Tools , and then Envelopes and Labels , accesses the envelope-printing feature. Other software programs will differ from this procedure. Consult the Help menu on a software program or User's Guide for instructions for the particular application. Printing guidelines
  • Never place more than 15 envelopes in the In tray at one time.
  • Align the envelope edges before inserting them.
May 27, 2008 | HP Office Equipment & Supplies
Epson 9800 Prints black dotted vertical line
This is a workaround - I too need a definitive answer. Symptom: black dotted vertical line 1/2 to 3/4" from leftmost image edge. I have begun adding single vertical line to my prints .25" from the left edge of the paper to force the "dots" off my print - this seems to have the desired affect, but it does not answer the cause or provide a true remedy (it will save many of your prints while we wait for complete solution). dkh
Apr 18, 2008 | Epson Stylus Pro 9800 InkJet Printer
Dell 810 not printing
Dear chibihamster, It seems that there is some loose connection in your printer. If you have a little knowledge in hardware, please open your printer carefully, check all the connected cable specially the printer head connector. The best way is that disconnect the printer head cable and reconnect it again. Do not do anything in your scanner circuit area, otherwise it will create you more problems. If this doesn't solve your problem, please contact the manufacturer. GOOD LUCK!!
Aug 31, 2007 | Dell 810 All-In-One InkJet Printer
69 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
