Question about KitchenAid Superba KSRG25FK Side by Side Refrigerator
I have a SUPERBA 48 EXTEND FRESH i canot find a model number i need new seals for it were do i get them
3 Suggested Answers
  • 17 Answers
SOURCE: Model Number
Open the drawer or bottom cover panel and look on the facing where the door closes to
Posted on Dec 05, 2007
  • 5 Answers
SOURCE: not cold,everything defrosted ,motor noise still
Most of the time, it's the defrost timer failing and ice building up behind the back panel of the freezer. Also could be the thermostat both are easily replaceable.
Posted on Jun 20, 2011
Superba 48 stopped completely
Hello Shawn;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number. The model number is on a label, on the liner inside wall of your fresh food section near the top.
I picked a Superba 48 model number at random to see what you have. The model I picked - the control boards are not available. But these are not your problem.
Every 8-10 hours your unit completely shuts down except for the lights, and goes into a defrost mode. This is where your defrost heater turns on for 20-30 minutes, defrost your cooling (Evaporator) coil, and then turns your unit back on. You may have a bad defrost timer.
1.) Defrost Timer - Behind your unit is a defrost timer.
The timer is mounted on the back a steel bracket with a hole through it. Take a flat head screw driver, turn the round shaft one click at a time clockwise until the unit turns on and is running.
If the unit turns on, then you have a bad defrost timer.
Note: When replacing note what contact number the black wire is connect.
2.) Power On/Off Switch - In the lower back, you also have a Power On/Off switch. Unplug the unit disconnect the 2 wire leads on the switch. Using a multi-meter, set ant the lowest Ohms (Omega Symbol), Ohm out the switch. If you get a reading other that '0', then the switch is bad.
Dec 28, 2014 | Refrigerators
I need to replace the door seal. I cannot find a model # to confirm this is the correct one that I selected. I will be looking for the seal and instructions on replacing it.
The model number can be in 4 places need it to order correct part,it could be on; ceiling of fresh food section,left side wall of fresh food section,under grill below doors,under crisper drawer
Aug 02, 2011 | Estate TT21AKXKQ / TT21AKXKT Top Freezer...
Not cold,everything defrosted ,motor noise still there model superba 48
Jun 20, 2011 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid superba 36 probably 2001 model side by side - need a new door shelf. I looked for a model number but not one in sight. Not sure where the book is either. I just need to know where/how to get...
Hello , you must have the model to order anything. it is located in the fresh food side on face or somewhere inside. After you find it sears parts will be the best place to order.
Phil
Dec 01, 2009 | Car Audio & Video
My kitchen aid Superba 48 the meat drawer is broken and I need to replace it. Does anyone know were to buy the drawer?
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=KSCS25INBL01&productCategoryId=0165000&brandId=0593&modelName=COUNTER-DEPTH-REFRIGERATOR&diagramPageId=00003&componentDescription=REFRIGERATOR%20SHELF%20PARTS&documentId=W0606038&blt=06
Eric
Nov 21, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aide Superba 48 1997, refrigerator door remains ajar,Fix?
They actually make a guard that acts as a height shim. You do need to remove the door to install it though. Try looking at appliance411 they usually have some insight into out of the ordinary parts. Hope this helps. Good luck.
Aug 04, 2009 | KitchenAid Superba Architect KSCS25INSS...
How do you change filter in Kitchen Aid superba refridgerator
The superba series is a dishwasher type. the model number would be really helpfull. either way if you go to kitchenaid.com and click on product type then on refrigerator it shows all models and when you click on your model it takes you to its page and on the bottom of the page is the installation guide and every manual for your fridge. its all in PDF format and really easy to use. if you still need help please email me at phoenixnixinks@yahoo.com with the model number and i will be more than happy to help you farther.
good luck
Jan 14, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ge profile built in SS refrigerator
Go to www.geappliances.com - service and support section - parts and search for your model number . You will be able to get an exploded diagram in pdf format for each section of the appliance.
Graham
Nov 21, 2008 | GE Profile¿ 48" Built-In Stainless...
Model Number
Dec 04, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba  KSRG25FK Side by Side Refrigerator Logo
124 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
