Question about Sanyo PLC-XT16 Multimedia Projector
Sanyo PLC-XT16 dim circle in middle of screen. What can this be? THanks
SOURCE: Sanyo PLC-XT16
The problem is faulty capacitor on one of the control pcb's . needs to go to a technician for repair
Posted on Jul 04, 2008
  • 84 Answers
SOURCE: Sanyo PRO xtraX Multimedia Projector Mod.# PLC-XP1ONA
this is the normal condition> only when green led is off and warning temp led(yellow) is on something is wrong!!
Posted on Sep 25, 2008
  • 207 Answers
SOURCE: lamp life indicator reset
Here you go:
1) Turn projector on, press MENU button and ON-SCREEN MENU will appear. Press POINT LEFT/RIGHT button(s) to move a red frame point pointer to SETTING Menu icon (refer to page 36, 37).
2) Press POINT DOWN button to move a red frame pointer to "Lamp counter reset" and then press SELECT button. The message "Lamp replace counter reset?" is displayed. Move the pointer to [Yes] and then SELECT button.
3) Another confirmation dialog box appears and select [Yes] to reset Lamp Replace Counter.
Posted on Apr 30, 2009
projdoc
  • 2237 Answers
SOURCE: sanyo plc sw20a dose not work with my laptop what
you need to activate the external monitor port on your laptop.
Posted on Nov 09, 2009
  • 100 Answers
SOURCE: Sanyo plc-xt16 Projector
It sounds like the lamp is going.
Do you know how many hours of use are reported on the lamp?
Many times these projectors have circuitry to shutdown when they suspect the lamp is near the end of life. Lamp hours vary and usually will go up to and even beyond expectancy, but there is occasions you can receive a bad lamp and have it blow in a matter of hours...not common but it does occur.
I hope this helps,
Magoo
Posted on Mar 09, 2011
The projector is shuting down due to overheating after every 30min. how can i correct this?
There are four air filters that are accessible from the bottom of the projector .... make sure they are all clean.
Jul 18, 2011 | Sanyo PLC-XT16 Multimedia Projector
Sanyo plc-xp30. Lamp turns on but has a yellow tint , in a circle that does not quite take up th ewhole screen. the color looks normal around the edges.
U need to unplug unit and turn on its back replace filter . blow out. sounds like its getting hot and dusty. u need to clean before u burn out your optical engine like i did.
May 25, 2011 | Sanyo PLC XP30 Multimedia Projector
Sanyo plc-xt16 Projector After the projector is turned on and the countdown finishes on initial start up the projector shuts itself off within 5 seconds. The fan runs for 1 minute and then the projector...
I hope this helps,
Magoo
Mar 09, 2011 | Sanyo PLC-XT16 Multimedia Projector
All filters are clean on unit but while warming up it locks out on warming temp. If all filters are clean what else would cause this fault?
hi,
check , is the fan is working or not. a fan is used for cooling the lamp,( through out till it is on.) if the fan is not working the lamp will get over heated and the worming message will come.check it first.
ok
Dec 22, 2010 | Sanyo PLC-XT16 Multimedia Projector
No bright just for one second
when you connect a source, it refreshes your external display nothing major or minor, its normal
Jan 24, 2010 | Sanyo PLC-XT16 Multimedia Projector
The lower part of the display is dim.
the fly-eye lens (diffuser) is starting to fry and needs to be replaced. there is one right inside the lamp housing and one on the other side of the first. the second one is the one that usually fries. if that is ok, then check the light filters next to the lcd panels. they fry due to excessive dust and heat. if one of those go, you'll need to replace the entire optical engine.
Oct 15, 2009 | Sanyo PLC-XT16 Multimedia Projector
Lamp life indicator reset
Click Sanyo Support to download Instruction Manual copy and check page 39 for details about Lamp Reset procedure.
Apr 30, 2009 | Sanyo PLC-XT16 Multimedia Projector
Sanyo PLC-XT16
Hi there
Is there any on screen prompting ?
If not , open up the lamp door at the bottom and take out the lamp. Check on the lamp's shaft for any irregularity ( i.e. vein like looking black marks or bubbles or a white spot , also check that the fillament on the inside is not broken.)
If you spot anything I listed up here , your lamp will need replacement.
If you cannot see any irregularity , check when the unit shuts down which of the LED's on the unit flashes.
It will either be your lamp or the Ballast ( lamp's powersupply ) that is faulty and will need replacement.
Apr 15, 2008 | Sanyo PLC-XT16 Multimedia Projector
Sanyo PLC-XT16 Multimedia Projector Logo
21 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
