Question about Maytag Dryers
Maytag stack unit washer dryer error 7E washer works dryer wont do any thing
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
Maytag Electric Washer/Dryer - error message 7E. Dryer won't operate
Hello
Error code 7E is a temperature control error and is caused due to overheating. Start with cleaning the vent and then please check the Thermal fuse located on the blower wheel housing inside the duct for continuity with an ohm meter. The fuse cannot be reset if it is bad then it needs replacement, if the fuse if fine then check the cycling thermostat. Please get back to me if you have any other questions.
Kevin
Nov 16, 2010 | Maytag Dryers
The tub is leaking in the botto center
had the same problem...the washers that hold the water in need to be replaced...only $20 for parts, but labor is $700 to take entire thing apart and is not covered after 1 year [I've had 9 yrs]; I opted to trash / replace entire stack unit; buy new amana washer & dryers @ home depot b4 7/29/09 / big sale!
Jul 14, 2009 | Maytag LSE7806A Top Load Stacked...
My washer wont drain water or spin.
Do you have any lights flashing or error codes?
When this happens, it is either due to plugged drain or screen/filter or the system is faulty.
Jun 30, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag stack unit Model LSE7806ACE leaks
It is most likely the tub seal. Take the two phillips head screws out of the front cover located low on the cover lift forward and remove. Set the machine two low level and fill with water only no soap or clothes when unit starts agitating look at the bottom center of the clothes tub if water is leaking here then you will need to replace the tub seal and tub bearing assembly.
Apr 06, 2009 | Maytag LSE7806A Top Load Stacked...
Replace wax motor on neptune stacked w/d
I just recently purchased a used Maytag MLE2000AYW Stacked washer/dryer. The problem I am having is that the washer unit seems to turn on, the lights go on, fills with water, but doesn't not engage in the wash or spin cylce. There also seem to be a kind of intermittent spinning sound every five seconds or so when it is in the wash cylcle. Can anybody give me some ideas to troubleshoot for?
Mar 31, 2009 | Maytag MLE2000 Front Load Stacked Washer /...
Maytag s1000 stacked washer will not start water fill and cycles.
could be wash spin relay stuck in spin must be 15 years old
Feb 19, 2009 | Maytag LSE7806A Top Load Stacked...
Washer won't agitate, drain or spin
quite possible that the fuse has gone bad again, if that s the case i would recommend replacing the fuse, and the lid switch.
Dec 08, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag stackable LSE7806ACE - dryer wont run...washer is fine..
I had the same problem, take the easy rout first and check for obstructions in your venting. Mine was clogged and it shut itself down (to protect itself?)
Jul 06, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag dryer model lde710
Check for a stuck relay. that's the only thing else that comes to mind
Dec 27, 2007 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
143 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
