SOURCE: sharp aquos LC-37D4ou
What kind of connections are you using?
If component (red, green, blue) double check to make sure they are seated properly. I'm thinking it sounds like the blue one got loose.
SOURCE: SHARP AQUOS LC-26P70E - Clock
Most TV's don't change with daylight savings time, since they do not operate with a date, just time. You will need to change it via the remote.
Good luck
SOURCE: Sharp Aquos LC-20B6U-S TV NOW
This can be caused by many different things. Check power supply fuses. If ok suspect inverter board which drives screen. Check for bulging capacitors and open transformers or just find replacement cost using numbers on board. That may fixya.
SOURCE: Where do I buy Sharp
Good Day, coopsl;ine;
Try calling (630)-226-2699; SHARP, or go to NATIONAL PARTS CENTER: [email protected]. Good luck, big IRISH.
Sharp LC-32GD8EA Aquos
On analogue TV the time and date stamp show correctly.
On digital TV the time stamp is one hour out i.e. the current time should be 14:06 and the time showing is 13:06. Can you help resolve this issue please
