Question about Nintendo Wii Console
Cant get the internet on my wii - Nintendo Wii Console
  • 864 Answers
I can help assist you with this. This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting: Are you using WEP or WPA security on your router? Log into the router using the default IP (consult your router's manual for assistance) Locate the "wireless security" section of your router settings and find the WEP or WPA key. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters). If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot. If you are using WPA, the Wii console is compatible with the following types: WPA - PSK (TKIP) WPA - PSK (AES) WPA2 - PSK (AES)
If your WEP or WPA key is correct, then the problem might be related to MAC address filtering: From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model). If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings). If the Mac address filter was disabled, then continue troubleshooting.
Check Nintendo's router info for special notes, if available, for your router. Click here to go to our Wireless Router lookup page. Use the drop-down box to select, if available, your router manufacturer. Click on your router's model number, if available. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings: On your PC, click "Start" and then "Run." Type "CMD" into the field that appears to open a new window. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. if you require further assistance please let me know and i will be glad to assist you. -Midwest-tek
Posted on Aug 27, 2010
Wii connection
For instructions on setting up the PS3, Xbox, or Wii, for awireless/Internet connection. please click on this link :-http://fixhomenetwork.com/xbox-play-station-wii.php
May 02, 2012 | niu.edu
Cant connect to my router netgear
http://www.ehow.com/video_5168009_connect-wii-wireless-internet.html
  • 1Before you connect Nintendo Wii to wireless Internet, set up your Wii console according to the manufacturer's directions.
  • 2Turn on the Nintendo Wii and wait for the main menu to appear.
  • 3Using the Wii remote, point and click on the small Wii button in the bottom left corner.
  • 4Select Wii settings.
  • 5In the bottom right corner click the black square with the number 2 in it or use the right directional arrow to go to the next page. When you come to "Internet" click it.
  • 6To connect Wii to the Internet select "Connection Settings."
  • 7On the next screen select the first connection that says "none."
  • 8On the following page, when given the option for wired connection or wireless Internet, select "wireless."
  • 9Now it's time for your Wii to search for a wireless connection. To do this choose "search for an access point."
  • 10Press "okay" and find the name of your wireless Internet. If it's not on the first page, arrow down until you find it. If you need a password to access the Internet, you will be asked to enter it. Click okay.
  • 11Click save and okay so the Wii remembers the wireless Internet connection options for the future.
  • 12Finalize the Wii Internet connection process by testing the wireless connection.
  • 13When Wii's wireless Internet test finishes successfully, you're ready to play Wii online.
  • Read more: Video: How to Connect Wii to Wireless Internet ' eHow.com http://www.ehow.com/video_5168009_connect-wii-wireless-internet.html#ixzz1f6B48YnB
    Nov 26, 2011 | NetGear WGR614 Wireless Router
    I cant get the internet to connect to the wii
    I'm getting Error Code: 51420 when trying to connect to the internet with the Wii console.
    This is our first time trying to make internet connect with the Wii console. I have a USB cable connect from Wii console to the Modem. Any help
    Jul 16, 2011 | Nintendo Wii Console
    I cant figure out how to connect my wii to wifi internet
    mate i do not own a wii but my cousin does .. theres wireless internet on the WII !!! thats really cool so you might wanna go to configurations or settings check on wireless and your wii will search for acces points
    Apr 10, 2010 | Nintendo Wii Console
    Cant get into wii internet.
    You could try restarting your Wii internet or if you had your electricity turned off, then that's when you should restart your Wii internet. Also, check for updates (if it does something). Hope that helps.
    Feb 04, 2010 | Nintendo Wii Console
    How do I use the internet without a wireless router.I have a regular internet box and the internet cable for the wii,but i cant seem to connect to the internet this way.
    You will need to buy the wired internet connector for the Wii, called the Wii LAN Adapter. It plugs into one of the USB ports in the back of the Wii.
    There is a good step-by-step from Nintendo's website here:
    http://www.nintendo.com/consumer/systems/wii/en_na/connectingOnline.jsp?entryId=wdRouter
    Good luck.
    Feb 03, 2010 | Nintendo Wii Console
    I cant connect my wii to my wi-fi
    are you trying to play via wireless internet? if so you might not be getting a strong signal. if possible buy a ethernet to usb adabter for the wii. you can get them at bestbuy or anyother major electronic store. but you usually cant find them at walmart. this will guarantee a strong internet conection
    Jul 31, 2009 | Nintendo Activision Guitar Hero World Tour...
    Wii Internet Connection
    When you are not able to connect with Internet from Your Wii, means there is something wrong with the settings. You may go to Wii Fix Guide and check out the guide available there, This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.
    Jan 13, 2009 | Nintendo Wii Console
    Cant get our internet to work on our wii
    go here for some really good screen shots on how to get your wii online
    I hope this helps
    Dec 25, 2008 | Nintendo Wii Console
    Wii
    yea you have to go to one of the channels if there is not one go to the wii shop channel and go to installations and install the internet and when its done intalling it (it may take a while) should work the internet with the wii isnt that fast and cant take on some websites (dont worry it can take youtube and its pretty fast on that website) sometimes when you chek the wii installations on the wii shop channel there will sometimes be new updates for internet channel (free)
    Mar 28, 2008 | Nintendo Wii Console
    Nintendo Wii Console Logo
    15 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Bee Santiago
    Raj Patel
    Julian Wainwright
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
