Question about Maytag Washing Machines
My maytag washer (about 4 yrs old) quits during rinsing cycle. I took the top off where the wires are to see what I could see. ;) The "buzzer non-adjust" zapped me when I touched it. Could this be what is making the washer quit in the middle of a cycle?
  • 2 more comments
  • Model no SAV515DEWW Serial no 10835173ee I sure appreciate this.
  • I thought I sent my model no. It is SAV515DEWW I just went and put the buzzer-non-adjust back on and the damn washer kicked back on. So, I turned the timer to extract and it's extracting. I have an appt. i will see if it extracted and spun when I get back and get back to you. Mary
  • It finished the cycle. I will start another one tonight. gotta get to work. thank you much!
  • I got home tonight and the washer and stopped during the rinse cycle. Then, while I was standing there it started again. Sounded like it was trying extract water. My new buzzer non-adjust came in the mail, so I switched them out. Did the same thing. Started working, but I could smell an electrical burning smell, that I forgot to mention before and then it stopped, so I just shut it off.
  • 530 Answers
Any time you touch live wires you will get an electric shock
always make sure you turn your power off before making any repairs.
more than likly the answer to your question is no that is not the reason why your washer stops mid cycle
it would either ne your lid switch causeing this and or if you can manually advance your timer to the next step. it is your timer that is failing.
please be careful
Posted on Aug 24, 2010
  • 2 more comments
  • Thank you. I didn't touch the wires. I touched the little plastic thing that wires hook up to. Manually trying to advance the timer didn't help. I sure appreciate your advice.
  • erica graber Aug 24, 2010
    can i please get your model number
  • erica graber Aug 25, 2010
    can you turn the washer back on or advance the timer to a different spot to make it work?
    is it only this one point on the timer where it stalls everytime?
    Will it spin and drain?
    I need to know more detail.
    This model normal faliars are bad bearings, pump, and sometimes the timer.
    Have you been hearing a loud noise when it goes into spin. like an airplane takeing off.
    good job i hope it works for you now
Maytag washer very loud on spin cycle
I know the exact sound you are hearing, I had the same thing several yrs ago on my old Whirlpool. I think it was something with the transmission, but what I needed was no longer available. I found a lot of info by entering the make/model nr in search box at appliancepartspros.com. You could also look atR44U61 RepairClinic.com
May 02, 2017 | Maytag Washing Machines
OUt of balance during rinse and spin cycles
I have the same problem. During the spin cycle, the washer spins all over the room.....very loudly.
Dec 26, 2009 | Maytag Washing Machines
Water pressure for Washer (rinse only)
you nead to turn off both cold and hot water.next you nead to remove cold water hose from washer.remove screen and clean it and replace it.hookup cold water hose to washer and turn water back on.you should have better pressure.your rince cycle is cold water.
Nov 18, 2009 | Kitchen Ranges
Washing machine not agitating during wash cycle. Only when rinse
This occurs when your transmission has failed & requires replacement.... Good luck!... Bill
Apr 28, 2009 | Maytag MAV4755 Top Load Washer
Maytag Washer whines during rinse belts burn
that friend is about the best possibility I can think of. This site has all your parts for the washer you have www.repairclinic.com
Mar 21, 2009 | Maytag LSE7806A Top Load Stacked...
Belt squeek during rinse cycle
Mine the same concern, I took it apart and found the thermo fuse in the motor had a bad terminal. Maytag parts man said you must get a new motor even though the fuse has a part # on it and is easy to change. I made temporary repairs until I find a fuse from a used parts machine. Scott
Aug 02, 2008 | Maytag Atlantis MAV6000 Top Load Washer
I own a Maytag Performa 4 Speed/24 cycle Washing machine. it is 4 years old. Problem: A very LOUD grinding sound when washer engages into wash, rinse, spin cycles. The Tub does agitate - but I don't...
sounds like you have a tub seal problem, which took out the bearings, I take it one buzy mom does lots of laundry! Maybe time for a new washer.
Jul 11, 2008 | Maytag Washing Machines
Maytag Legacy top load washer is SMOKING!
this is a bogus website that is trying to push smelly washer product....no real fixes and there are other products out there for less just use bleach first
May 05, 2008 | Maytag Legacy Series Top Load Washer
Washing Machines Logo
94 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
