Question about Refrigerators
Schematic diagram for wine enthusiast 272 02 30
2 Suggested Answers
  • 905 Answers
SOURCE: Wine Enthusiast 16-bottle thermoelectric wine refrigerator DEAD
usually bad power supply, if the cooling fan isn't running either. These are horribly inefficient coolers that use a lot of power to accomplish little cooling. The power supplies are quite notorious to burn up.
If your supply is 12vdc output, you might be able to replace it with a supply from radio shack. dont use a battery charger though.
Posted on Nov 02, 2009
I have a wine enthusiast wine cooler model 272 03 27. Not cooling,compressor kicks on. The fans are running.The temperature never gets below 64.Is it the temp sensor or Control board? Thanks Randy
It sounds like it is in the correct temperature range. You may ned to adjust the temperature to a lower setting.
°C °F Wine Style 19 66 Armagnac, Brandy, Cognac 18 64 Full Bodied Red Wines, Shiraz 17 62 Tawny Port 15 59 Medium Bodied Red Wines 14 57 Amontillado Sherry 13 55 Light Bodied Red Wines 12 54 Full Bodied White Wines 11 52 Medium Bodied White Wines 10 50 Ros?, Light Bodied White Wines 9 48 Vintage Sparkling 8 46 Fino Sherry 7 45 Non-Vintage Sparkling
Dec 01, 2016 | Furniture
Tip
Benifits of Wine Coolers & Accessories
Wine Coolers are a great choice for many wine enthusiasts. Wine Coolers & Accessories can be placed virtually anywhere in the home and Wine Coolers offer either a single or dual temperature control zone. A wine accessory is generally any equipment that may be used in the storing or serving of wine.
http://www.jilliandistributors.com/products/wine/
on Aug 16, 2016 | Furniture
Good morning, our wine enthusiast fridge, model 280 06 26 04 is making a drawn out humming noise. Any insight on what to do?
If the sound is from the back of the fridge the there is problem with the compressor or the motor fan. sound from the bottom of the fridge is due to your fridge is off balance. If the sound is from inside the fridge and becomes louder when you open the fridge, then your evaporation motor is probably broken.
Nov 07, 2016 | Wine Enthusiast Refrigerators
Wine Enthusiast Silent Wine Refrigerator is making a loud buzzing/whirring noise.
Since this unit doesn't use a compressor, the only moving parts are the whisper fans inside of it that circulate the air. One of those fans may be going bad. If you are handy you can remove the back to see if all the fans are working but your best bet is to use the one year warranty and have a qualified techncian figure it out.
Jan 07, 2014 | Refrigerators
I have a wine enthusiast Model 2720206 and I don't know how to set the temp?
The answer is partly incorrect. This type unit DOES NOT USE freon as it is thermoelectric utilizing a heat pump. Unfortunately, part of the answer is correct. It likely will cost about $100 to "ring the door bell".
Sep 19, 2013 | Wine Enthusiast Grand Cru 1600 Wine Cellar...
One side of my Eurocave SoWine Cooler does not work.
As you must be aware there are individual fans in both the compartments. Check if the fan is running in the compartment not cooling. If not, check the wires / connection of fan or replace the fan.
If the fan is working than the issue may be with the THERMO ELECTRIC ELEMENT. you'll need to replace it.
Sep 09, 2013 | The Wine Enthusiast Wine Enthusiast...
The bottom section of my wine enthusiasts model 272 03 24 dual temp wine cooler is "dead".
These units cool using the same technology as your PC. There is a heat sink (aluminum block with fins) that has a fan that exhausts the heat out of the Peltier cooling module. Go to you tube and search as it looks very similar to this: http://youtu.be/JqCLdT2k0dc Take the fan off the aluminum fins and vacuum and/or use compressed air in a can. Amazing how much dust you will find. Reassemble and you should see a difference. Good luck.
Sep 08, 2013 | Wine Enthusiast Refrigerators
I have a "the wine enthusiast" wine cooler and it's a 2001 model 2720216, 16 bottle storage, and it is not cooling the temperature stays at 80 degrees can it be fix or just get rid of it and buy a new one?
At that temp I'm sorry to say sounds like the compressor is shot or all the gas has leaked out. A service call is about $100.00 to ring the door bell and then add about $500.00-600.00 for a compressor and or 300.00 if the coil is bad. It might be better to get a new box with a warranty. Best of luck!
Aug 23, 2010 | Wine Enthusiast Grand Cru 1600 Wine Cellar...
Nov 02, 2009 | Refrigerators
Refrigerators Logo
186 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
