Question about Canon CanoScan LiDE 60
Problems in using it
my scanner worked until yestarday, now when i try to scan i get error message : selected application is invalid : what can i do?
domenico
  • danallan2 Aug 27, 2008
    scanner worked fine. Now it looks for the twain driver and cannot find it. software has been installed, removed and re-installed. Still cannot find device.
    Using Windows Vista 32 bit. I've searched and tried as much (or little) as I know. Nothing works.
I ran into a similar problem with my LiDE 20 right after I upgraded my Adobe Reader from version 8.0 to version 9.0. Under the "Link scanned images to" section, the path was still pointing to the old version of Adobe Reader. To fix it, I clicked the "Set..." button and selected the appropriate path to the new version of Adobe Reader. You can also try clicking the "Link Deletion" button if you just want the file to be saved without displaying the image after scanning.
Posted on Oct 12, 2008
  • WindyCityUSA Mar 03, 2011
    On Vista: I encountered this very same problem but mine happened when upgrading from version 9.0 to 10.0. I made the mistake of uninstalling and reinstalling (downloaded from the Canon Site) both the Scan Gear Software and Drivers (a total of 4 files). Did not work. The solution was much simpler -- simply, as indicated -- to associate the program with the new version of Acrobat Reader. Also my scanner is LIDE 25 NOT 20.
  • 86 Answers
Maybe for some reason the software went bad, reinstal the software
Posted on May 05, 2008
The scanner is not available while in use by another application or user i get this darn error. I use this scan multiple times a day and all of a sudden i see this.... why?
The error message could be Twain Driver error or ScandAll pro Application error. Please go through the followings:
SCANDALL-PRO APPLICATION ERROR:
Error Code: [SA01020E] No scanner is found.
There is a possibility that no scanner is connected, the connected scanner is not turned on, or the scanner is currently used by some other application.
Status: [Scan] or [Select Scanner] is specified, but no connected scanner is found. Or, the scanner is currently used by some other application.
Action: Make sure that the scanner is connected and is turned on. If the scanner is currently used by some other application, use the scanner after the application ends. Make sure that the driver selected on the [Scan] tab of [Preferences] in the [Tool] menu is installed correctly.
TWAIN DRIVER ERROR:
-The scanner may be OFF or not connected. Check the power supply of the scanner or connection with PC.
-The scanner may be already in use by other application or the "Scanner and Camera" in [Control Panel].Close other application or "Scanner and Camera" in [Control Panel]
-The connected image scanner is not a model supported by this driver. No image scanner is connected. The cable is disconnected.Check whether the image scanner is connected.
-Another application may already be using the image scanner. Alternatively, the TWAIN driver may have been activated twice.Terminate all applications, and start scanning again.
For more information, please refer to the help contents of Scanner utility/Twain driver and scanning application installed on your PC.Hope the above information is helpful.
Thanks,
ScanCare
Jun 22, 2012 | Office Equipment & Supplies
Hi, my terminal Motorola MC3190 doesn't want to enable scanner and i really don't know why.... There is an error code A0000032 with message: "CANNNOT ENABLE SCANNER"
The scanner engine/output can be used only by one application. If a second application is trying to access the scanner, while in use. The error message will come.
Please check if there are more applications running in background. Usual MC9090 applications with scanner drivers are Telnet, Datawedge, Rapid Deployment and custom software.
Exit one of the application or try to exit all of them. Start your scanning application again, no error should appear now.
Nov 09, 2010 | Zebra Symbol Technologies MC909X-G Series...
Symbol MC9090 Barcode Scanner cannot enable scanner error code "A0000008"
Please check if there are more applications running in background. Usual MC9090 applications with scanner drivers are Telnet, Datawedge, Rapid Deployment and custom software. Exit one of the application or try to exit all of them. Start your scanning application again, no error should appear now.
Oct 21, 2010 | Symbol MC9090 Barcode Scanner
I am unable to scan. While in the Scan Mode, the message says "Downloading scan application list from your computer, please wait" The next message says "cannot retrieve scan application list from my...
the reason why the printer is giving you that error msg is because the all in one center is not communicating properly with the programs on your computer to your printer.
try to scan directly to your computer using the all in one center instead.
Jul 23, 2009 | Dell 966 All-In-One InkJet Printer
Epson Perfection v200 stopped working on my imac
Try to scan using epson scan to isolate the issue. You can launch epson scan from applications. If you can scan using epson scan, call adobe to troubleshoot further on photoshop.
If you get an error epson scan cannot be started or if it won't launch. It could be connection or driver issue.
To uninstall/re-install twain on mac, follow the instructions:
- go to applications. Trash epson scan and epson scanner monitor
- Go to library then application support. Trash epson scanner module.
- Go to library then image capture. Trash twain data sources.
- Go to the hard drive. Click on user. Click on the name of your computer. Click on library. Click on preferences. Click on epson. Trash epson scan.
- Empty the trash.
- Restart your mac.
- Log on to support.epson.com. Type in v200 in the search box on the top right corner of the page then click search. click on the first search result. Click on the drop down box and select macintosh operating system instead of windows. click on the second driver down, epson12527.dmg then click on download now. Select no thanks, i prefer not to receive this information then click accept. Install the epson scan installer after the download.
- Then try to scan using epson scan.
If epson scan won't launch or you get an error, try a different usb cable.
Goodluck.
sherlyn c.
P { font-family : Verdana, Geneva, Arial, Helvetica, sans-serif; font-size : 10px; } .boldBlue { color : #2A57A5; font-weight : bold; } .qatable { width : 390px; } P { font-family : Verdana, Geneva, Arial, Helvetica, sans-serif; font-size : 10px; } .boldBlue { color : #2A57A5; font-weight : bold; } .qatable { width : 390px; } P { font-family : Verdana, Geneva, Arial, Helvetica, sans-serif; font-size : 10px; } .boldBlue { color : #2A57A5; font-weight : bold; } .qatable { width : 390px; }
May 21, 2009 | Epson Perfection V200 Flatbed Scanner
Scan button not working, message says selected application invalid ?
Hi
The quickest way to resolve this is to reinstall the cano tool box you can find the latest version on the link bellow
http://software.canon-europe.com/products/0000465.asp
please don to forget to leave fixya feedback if you find this helpfull !
Regards Alan (alstech)
May 07, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
Using hp scanjet 3970 Just loaded hp scanning software and the large install of the 3970 drivers. When I enter the program the scanner opens and scans te image on the tray. (I am trying to scan a...
Have you checked the cord from the scanner lid to the scanner base. if that doesn't work I would try uninstalling the scanner and then reinstalling it. It sounds like a problem with the twain driver for the scanner.
Dec 20, 2008 | Computers & Internet
Have uninstalled and reinstalled software for CanoScan LiDE60 and still coming up with 2 error messages - "cannot communicate with scanner" and " unable to open TWAIN source". How do I...
Are you scanning from Toolbox? Make sure the correct scanner is selected in the Settings section.
What OS is this? Try scanning from various applications.
Does the scanner react at all at any time?
Make sure you have installed ScanGear and not just Toolbox.
Apr 30, 2008 | Canon CanoScan 4400f MultiFunction Color...
Scanner command invalid in current state
I have not used CapturePerfect 3.0. Hope the scanner is just fine. Try count only mode to check if it is okay.
Uninstall Captureperfect. Run chkdsk/scandisk to check if OS is ok. Reinstall Captureperfect again and it should work.
S. Mohan
Jan 31, 2008 | Canon DR-9080C Path-Through Scanner
Canon CanoScan LiDE 60 Logo
357 people viewed this question
old marine
old marine
