Question about Pioneer DEH-P2600 CD Player
I'm not sure which wires to splice together - Pioneer DEH-P2600 CD Player
    President:
  • 676 Answers
Hello my name is Isrel. Here is a diagram that will help you out.
Posted on Feb 22, 2011
How do I remove alarm brain box from wiring on a
"I bypassed the immobilizer circuit only on my alarm module (which is really tedious). Bypassing the whole
module is possible (and little easier), but you will lose the use of the remotes and the ability to arm the alarm.
The alarm module in my '97 900 SETC is located under the carpet, below the driver's power seat switches (a
pain to get at).
If you want to bypass the module completely:
1. Disconnect the battery (make sure you know the radio code-if needed)
2. Unplug the connector from alarm module and remove module from car
3. Install a wire jumper between pin 8 and pin 20 in the connector
4. Install a wire jumper between pin 9 and pin 21 in the connector
5. Install a wire jumper between pin 10 and pin 22 in the connector
6. Wrap securely with electrical tape
If you want to bypass the immobilizer circuit only:
2. Unplug the connector from the alarm module
3. Cut the following wires from the back of the connector and splice together as follows (Don't cut the wires too
close to the connector, because someday down the road you may want install a new module, so you'll have to
reverse this process):
4. Cut the wires to pin 8 and pin 20 and splice together w/ wire nut
5. Cut the wires to pin 9 and pin 21 and splice together w/ wire nut
6. Cut the wires to pin 10 and pin 22 and splice together w/ wire nut
7. Secure all with electrical tape
8. Reconnect the connector to the module
Not knowing the details of your problem, please be aware that this may, or may not, solve it. Good luck and let
me know how you make out."
Oct 02, 2014 | 1997 Saab 900
Can you splice an adapter with an end that will fit the round hole on a scanner?
what are you trying to splice? if you are just putting it back together where a pet chewed it sure just make sure you have the polarity correct on the wiring (on the insulation there is usually a white stripe on one of the wires or on edge of one of the wires will have ribs on it) if you are trying to wire in a replacement adapter the make sure the output is the same (it will say on the adapter what the output is (if your replacing the round end then again just make sure you have the polarity correct)
Oct 22, 2012 | Nike 12 Volt 12v Dc Power Adaptor Adapter...
Drove over something and ripped wires in front left of car- need the wires put back together
You may need to strip the wires and solder them back together, you should reroute the wires to where they will not do this again. Make sure to splice the wires well and wrap them with electrical tape. Also make sure you use the right gauge wire, 12 gauge or 14.
May 10, 2010 | Cars & Trucks
Dog chew cable in half on my skull candy headphones. Can cable be splice?
Yes there are ways to splice cables together, This depends on the extent you would like to go to. if splice needs replaced near end replacement end can be bought at radio shack. You can splice wires together by striping the wires back and reconnecting them together making sure all wires are connected together and not touching one another, Twist red to red white to white and ground to ground, wrap with electrical tape each by them self use heat shrink to make it look a lot better.
Feb 20, 2010 | Skull Candy Hesh Stereo DJ Headphones -...
No power at all in any cycle have electric to it.
Check the lid switch.....make sure the switch is being pushed all the way in. On some models there is a fuse, usually wired in somewhere near the lid switch, check the fuse and make sure it isn't blown. If there is no fuse you can also check the switch by cutting the wires running to the switch: strip the wires about a quarter inch and wire nut them together....cut the wire at the switch so that there is enough wire left to splice back together if the switch isn't the problem....if you cut the wire too close to the switch it is a pain trying to splice the wiring back together. If your problem is a bad lid switch the washer should come start working. Good luck
Jan 13, 2010 | Maytag Washing Machines
The AV cable on our Smart cycle got wound up in the bicycle's pedel and snapped in half. It is a red yellow and white connector cable like on a dvd player. Can it be spliced together?
Hello, yes it can be spliced together just make sure that you seal each wire well with electrcal tape. Once this is done use electrical tape and wrap the three wires together neatly. I hope this helps.
Nov 04, 2009 | Toys
The wire leading to the turn signal in front was somehow torn. Can you just splice it together like a wire in the house and if so, do you have to worry about touching it?
YOU CAN SPLICE IT TOGETHER..TWIST THEM TOGETHER AND THEY SHOULD BE SOLDERED AND HEATSHRINK TUBING INSTALLED BEFORE SPLICING..NO NEED TO WORRY ABOUT TOUCHING THEM..ONLY 12V DC
Jul 07, 2009 | 2007 Jeep Patriot Sport
I have a 300 watt Malibu transformer to run 4 step lights on a patio. the wires from the step lights go through conduit under patio and all come out under some steps at the house. So I have 4 sets of wires...
Take one cable to the x-former to the 4 sets, then Splice all the wires (5 in one nut and 5 in the other) together. Then connect the one set at the x-former. Don't worry too much about the 10 ft issue. It will work fine.
Jul 05, 2009 | Intermatic Malibu 300W Power Pack...
Wiring diagram for ford focus 2005 ghia 1.6
If you know which wires they are, ask an electrician to "but-splice" the wires back together.
Or if you think yourself wise enough to handle the situation, go buy, wire-strippers, **** splices and a crimper for those wire splices.
MAKE SURE YOU GET THE RIGHT SPLICES FOR THE GAUGE WIRE.
Strip the ends of either wire(you only need to strip about a1/4 inch), twist them CLOCKWISE, place them in the **** splice, and crimp the ends, and PRESTO! wire has continuity.
Make sure you splice the right wires together, or you will have blown fuses, and things not operating correctly.
Oct 07, 2008 | 2005 Ford Focus
Pioneer DEH-P2600 CD Player Logo
165 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
