Question about Sony Playstation 3 (PS3) Console
What can i do when my PS3 does not show video output?
  • 225 Answers
You can fix this no display error and all you need to do is fix some of the settings on the factory presets. Use a good repair guide to show you how or send it in.
Posted on Aug 24, 2010
My problem is earlier today i was playing my ps3, the picture was showing on the t.v. ( a HDMI Cable conected it to the tv), but 30 minutes later, i tried to play my ps3, the picture was not showing up...
Sounds like your video settings are wrong. Since you were on the HDMI connection the video was outputting in HD. When you switched over to normal AV (composite) cables the video was still outputting in HD.
Simple fix: power off your PS3 (so it's in standby; red light is showing). Then turn it back on, using the power button on the console (not the PS3 controller) and hold down the power button until it beeps a second time (about 5 seconds). The video settings will reset to composite. If needed, change your video settings.
Normally I'd put down like 3 other things it could be (each worse than the last), but I'm fairly certain that this will fix it. If it doesn't, just say so and I have many a more potential fix available.
Hope it works!
Sep 24, 2011 | Sony Playstation 3 (PS3) Console
My ps3 will come on but will not show up on the tv could it be the output and input chird for video?
Hold Power button down for two beeps (while PS3 is off): Reset video to lowest settings.
Oct 09, 2010 | Sony Playstation 3 (PS3) Console
My ps3 wont show on my tv anymore. what do i do?
not to worry it is very simple
1. if u are using hdmi port and it is connected to hdmi in your tv
setting might have been changed
1. take out ur nomal av output wire which is given by sony , plug it on to a normal tv (rgb) now u can see the display (if not try mannual swithch off the ps3 and on for 3 to 4 times) u will get the display
2. now go to settings (video settings) there is a option called video output u can change it to AUTOMATIC
3.NOW COME OUT of it and switch off
4. now pug into ur hdmi port it will work
Mar 15, 2010 | Sony Playstation 3 (PS3) Console
Ps3 not working with the output. doesnt show the ps3 screen
you have to go to the output settings under the settings option on the ps3 home screen and change it to multi and then go to the input on your tv and say yes to the question
Jan 02, 2010 | Sony Playstation 3 (PS3) Console
No video output
for the ps3 i know why u are not gettin any video. make sure the ps3 is off with the red light showeing in the front then hold down the power button for (i think) 30 sec. u will see the light blink a bunch of times them you might have to re start it but it should show the vedeo againg
Dec 13, 2009 | Sony Playstation 3 (PS3) Console
Green light on ps3 but no video show's up
Turn the PS3 on from the console by pressing the power button and holding it until you hear the first beep followed by a second beep. let it go after that. This resets the video to seek an active output on the console itself
Dec 10, 2009 | Sony Playstation 3 (PS3) Console
Ps3 plays audio but does not show image on tv
Well you can just use the hdmi cable if you're going both audio and video in to your tv. With your hdmi cable you get the best quality for both.
But in anycase, it seems that your PS3 is set up to output video via HDMI cable. To reset our video output settings, simply power down your PS3 (turned off) and hold down the power button until you hear the second beep. (around 5-10 secs) Power back up and hopefully you'll have video via your av cable. Hope this helps.
Apr 22, 2009 | Sony Playstation 3 (PS3) Console
Ps3 start up promlem
so if you have ever had your ps3 connected to HDMI (HD cable) before, and your forgot to change it back to the normal cords that came with the game (yellow, white, and red) then you will have to connect it back up to the HDMI and go to the Display Settings and change your video output to the one that came with the ps3 (which looks like just one yellow in the settings.) then after you do that then the screen might go black if your HDMI and regular cable are on a deffirent channels, so you turn to the channel that the yellow white and red cable needs to be to, then it will show the screen and ask you if you want to leave it at this setting with this video output/cable then you say yes then your good to go.
Oct 09, 2008 | Sony Playstation 3 (PS3) Console
Ps3 wont show up on tv
Hey i just posted i have the same problem as you do but then I checked the SONY PS3 website and it solved my problem. Try resetting your video output. I'll paste what it says on the PS3 website but if that doesn't solve your problem go to the website. They have a bunch of troubleshooting solutions for this problem...
If while manually changing the Video Output Settings, the screen remains blank for more than 30 seconds, you may need to perform the following steps to reset the Video Output Settings.
  1. Make sure the Component AV Cable is connected to the [AV MULTI-OUT] port on the back of the PLAYSTATION 3 system.
  2. Connect the other end of the Component AV Cable into the video and audio RCA jacks of the TV or display monitor.
  3. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  4. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically be reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Nov 03, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
14 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
