Question about Sony VAIO PCG-K35 Notebook
Sony PCG-7K1L fails to boot after dropping. Corner were power connects is broken. System beeps when starting but screen is grey/white with no output. Front green light and amber right are on. also amber light for hard drive appears to flicker. I disassembled but no obvious connectors were loose.
5 Suggested Answers
  • 3 Answers
SOURCE: Sony Vaio PCG-K86P laptop
fjhdsjafjkds
Posted on Jan 02, 2008
commanderzod
  • 112 Answers
SOURCE: Sony PCG-FX340K (PCG-993L) Laptop
Hi z14jc.
Clink on the link below
http://cid-ccc9919d689e8b4c.skydrive.live.com/browse.aspx/Public
Download the VAIO dissasembly.doc
Its not for your model but should be close enough.
I am presuming that your laptop is OUT of warranty and you have a good idea of what you are doing?
Ensure you have an ESD strap on when touching components.
Good luck.
Let me know if this was useful.
Posted on Feb 29, 2008
SOURCE: i have a sony PCG 7K1L. When I turn the power on
May need to re install your operating system.
If there is informatin on the laptop that you value as important. DO NOT FORMAT
Posted on Jan 05, 2010
  • 1335 Answers
SOURCE: Loose power connection on sony vaio PCG 7V1M
I'm assuming the laptop is out of warrantee.
It sounds like the power adapter jack is broken. To replace this you have to take the laptop apart down to the motherboard, unsolder the jack, solder on the replacement and reassemble the laptop. This is not something a novice should attempt.
Check with your laptop repair shops. The replacement/repair should be under $100.
Posted on Mar 02, 2010
I have a sony viao all in one desktop model num pcg-252l i replaced the screen and i trun it on and it lights up but it stays all white
A white screen meant the LCD controller was not working - what you saw was the backlight without polarization in front of it. If the cpu fan isn't spinning, that means the system board doesn't detect the right startup conditions. You probably connected the inverter improperly and it may be preventing booting, or you may have damaged a component with static.
http://www.experts-exchange.com/questions/27848125/PCG-252L-Sony-All-in-One-Viao-No-Display.html
Mar 29, 2016 | Sony Computers & Internet
Laptop screen divided
Try connecting the laptop to an external monitor if it works well. Be a problem in the laptop screen
May 09, 2013 | Sony VAIO PCG-K23 Notebook
Unit will not boot up. The Vaio logo and Intel logo will briefly flash on the screen and then the screen will go blank for good. The power indicator light and battery light are both on. The fan is on and...
It sounds like you have corrupted files in windows, or you have a problem with the hard drive. Remove the hard drive and re-seat it back in place, start up the computer! If no change, use the original recovery disc if you have one and reload the operational system, if that fails have the hard drive tested for bad sectors at the computer repair store.
Jan 22, 2011 | Sony VAIO PCG-K23 Notebook
I have a sony viao pcg-k23, when i open and power it on it has white displayed on screen white horizontal lines. what must be the problem? thanks
This is most likely an LCD screen fault. You could check the LVDS cable that connects the motherboard to the screen also.
Jan 21, 2011 | Sony VAIO PCG-K23 Notebook
My laptop ( sony viao laptop) fell and now once turned on I have a black screen all lights and sounds are good. Could this be a led disconnect problem or a video card situation. What type of video card...
Unlikely to be a vga cable loose, but you can check by removing the switch panel cover and the screen to check it is still firmly housed.
test the laptop first in an external monitor, if you get an image, then the graphics chip is still ok
This then points to the screen, may appear undamaged, closer inspection with a torch, shone through the back of it will show any cracks you do not see straight away.
If the screen will not light up, fault is probably with a damaged backlight or inverter, you are then looking at a new (or 2nd hand) screen
Dec 30, 2010 | Sony VAIO PCG-K35 Notebook
I have a Sony VAIO PCG-K25 Notebook Problem. When I Push the Power on Button, A flickering white screen comes up. The system goes throught boot up just fine but the LCD screen remains white. When hooked...
Hello
These symptoms are not the inverter problem, What can you do if the laptop LCD screen turned completely white? From my experience I can tell that this problem may be related to the following: 1. Loose connection between the video cable and the LCD screen. 2. Defective LCD screen. 3. Defective motherboard (I assume the graphics card is integrated into the motherboard).
Check these by yourself or get assistance from sony support.
Good Luck
Dec 22, 2010 | Sony VAIO PCG-K25 Notebook
Need a link
http://www.manualshark.org/manualshark/files/4/pdf_4310.pdf
Apr 17, 2010 | Sony VAIO PCG-K35 Notebook
I have a sony PCG 7K1L. When I turn the power on its just a black screen that says (error loading operating system) what can I do?
Jan 05, 2010 | Computers & Internet
Sony pcg-tr3a laptop beep continue &notbooting
Ur ram is not working u need to change ram.this beep is becouse ur ram is nor wroking.
Plz dont forget to rate thnx
Sep 09, 2009 | Sony PCG-TR3A Notebook
Ps3
When you turn on the PS3 one beep is good, two beeps are bad. Two beeps will require a service call to support.
Common causes for this are:
  • Faulty connections, the cables are not seated properly or damaged.
  • Faulty television, you will need to test the input jack with another device such as a vcr or dvd player
  • The output selector in the PS3 is set to the wrong output. HDMI / Component / Composite. If you have mistakenly changed the output in the menu from HDMI (one cable) to the Compsite (Red yellow white cables) or vice versus the PS3 is attempting to output to the other connection.
While the system is off, hold down the power button until it turn on and keep holding it until it beeps and turns off again.
This will reset the PS3 to the defaults settings, the default connection will be RCA Composite so make sure you have the red yellow white cables connected to your tv which came with the system.
Aug 06, 2008 | Sony Playstation 3 (PS3) Console
Sony VAIO PCG-K35 Notebook Logo
173 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
