Question about Kitchen Ranges
I need to replace the speed switch of my fan Where can I get the replacement part ??? I went to the Home Depo , but they don't have it Thanks , Fred
  • 530 Answers
Repairclinic.com
Posted on Aug 24, 2010
How do you open a wu pin switch. the chain broke & went inside switch
My chain was broken about 1.5 - 2 centimeters inside the wu pin. I took a chain connector (with some chain hanging off one end) and fed it into the hole, trying to connect it to the broken chain. After a couple of tries I managed to get the end of the broken chain inside the wu pin to connect to the chain connector by gently pulling down once it was somewhat inside the chain connector. I hope this works for you. I was so glad I didn't have to resort to cutting any wire or making a trip to a home improvement store!
Jun 13, 2011 | Westinghouse Electric Westinghouse...
Need a replacement capacitor
Voltage rating doesn't matter. 250v or 330v will work.
If this is really a 2 speed original, with the 2.5Amp motor... it will NOT have a capacitor as the motor is a shaded pole unit. The three speed electrically reversible fans, have a capacitor, which can either be in the switch housing/ oil reservoir, or the top of the motor housing, depending on year of manufacture.
Oct 24, 2009 | Hunter 23852 Classic Original Ceiling Fan
Hampton bay ceiling fan works, but can not change speed or stop fan. Model 46006 52" Huntington III. Is there an easy fix?
your pull chain for the fan is bad u can go to home depo & buy a new pull chain but when u replace it on the back ot the switch their is A 1,2,3,4, make sure the wires go to the correct #'s
Oct 05, 2009 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Hampton bay fan only is working at one speed, slow. It does seem to move freely. I pull the chain to change the speeds, but there is not change except, it does turn it off.
if its a hamptom bay fam get all numbers off the top of the fan and call home depo main office all hapton bam fann have a life time warrenty #is 1 800 654 0688falow all promps
Jul 26, 2009 | Dryers
Blower motor or resistor?
I had a truck about the same year with the same problem, it was the wiring harness, but id check the resistor and the fan first before replacing anythings,
May 20, 2009 | 2002 Chevrolet Silverado 1500
Fan switch broken, wires out when opened
I googled Hampton Bay Manufacturing and this is what I found:
Hampton Bay fans are manufactured by "King of Fans Manufacturing, FL". The contact number for them is 800-330-3267. ...
Maybe they can supply you with a wiring diagram.
Jun 08, 2008 | Dryers
Fan switch broken
replacement switches at home depot for 3 speed fans.There should be instructions on the package of the switch.
May 07, 2008 | Hampton Bay 04379 Madison Avenue Ceiling...
Fan speed switch is broken.
Home depot sells replacement switches.  First take a look at what you need in your fan.  By the exact or similar speed switch.  Then remove noting placement of wires and put new switch in.  If your down to one speed that is the capacitor.  Call King of Fans and they will send you one free.  This seems to be a common problem.  This is the second time I have replaced this capacitor.
Nov 25, 2007 | Hampton Bay 36 In. San Marino in Brushed...
Kitchen Ranges Logo
18 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
