Question about Brother DCP-110C All-In-One InkJet Printer
Brother DCP-110C - "Unable to Clean" - additional questions
Hi you experts,
I need some more info please...
(1) Which is the waste ink tank and how can I remove it. Should I replace it or clean it out.
(2) Since my printer does not have a numeric pad what code can I use to reset the the ink jet counter.
  • Anonymous Oct 26, 2008
    unable to cleen
  • Anonymous Mar 20, 2014
    waste ink counter reset
  • 333 Answers
I suggest you have a search through this forum for your solution
to your problem
Posted on May 05, 2008
DCP-110c is showing machine error 46. I have followed instructions as per cene765 solution #1 withput success. I get as far as 'maintenance 80 display. Pressed 'mono start' many times but still displays...
Many thanks - I fixed the error 46 by following the helful solution provided below.
Rank: Apprentice
Rating: 86%, 8 votes
Here is the "Unable to Clean" (code 46) solution:
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An “initial purge”, for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an “Unable to Clean” external message and will be unable to use the printer. The “Unable to Clean” external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Solution no. 1. (DCP-110C):
The proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons Set, Menu, Mono Start one by one, followed by up arrow key four times.this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press up arrow key several times to get to the Purge item
4. enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Dec 11, 2009 | Brother DCP-110C All-In-One InkJet Printer
Error message can not clean
usually due to waste ink tank full. Replace and reset purge counter
Dec 10, 2009 | Brother DCP-110C All-In-One InkJet Printer
It is reading that is unable to clean
usually is due to waste ink tank full, replace & reset purge counter.
Hi i have a brother printer 110c , the printer sayes unable to clean can you help solve the proplem thanks J
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the
error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
1. Pres 'menu', 'mono start' then 'menu' one by one...
2. Press the arrow up or down to go to 'maintenance 80'.
3. Press 'mono start' several times to go to 'Purge'. Finding the PURGE will show some numeric value
which is Iassume the number of times the printer had cleaned.
4. Press 'arrow up' key and scroll for number "2" then press "set".Do the same for numbers 7, 8 and 3.
After you have entered this combination, the purge numeric value will be reseted to 00000.
Oct 27, 2009 | Brother DCP-110C All-In-One InkJet Printer
DCP-330C All in one
Hi. I had unable to print and unable to init 46 error. Any help available to reset my machine please. Thank you
Jul 27, 2008 | Brother DCP-110C All-In-One InkJet Printer
Unable to clean
you need a new waist ink absorber box and have to do a reset. The absorber box can be purgchased from a service partner (see brother homepage of your country). Same procedure:
Mar 08, 2008 | Brother DCP-110C All-In-One InkJet Printer
Unable to clean
you need a new waist ink tank. Machine pumps ink each time it cleans itself into this tank. search for error 46
Feb 16, 2008 | Brother DCP-110C All-In-One InkJet Printer
Brother DCP 110C printer error
you cant clean the waistinktank because when the felt dries up it wont take up any ink anymore! The rejected ink will flow into machine and cause serious demages!
Anyway you have forgotten to reset the eeprom code to tell the machine thta the ink absorberbox has been CHANGED!
Search here for error 46
Feb 15, 2008 | Brother DCP-110C All-In-One InkJet Printer
Brother DCP-110C All-In-One InkJet Printer Logo
1,221 people viewed this question
James Cagle
James Cagle
Jim Keysor
