Question about Gigabyte 965P-DS3 (GA965PDS3) Motherboard
I need to know a compatible CPU for this model motherboard
Hi, I have a used Sempron 3300+ cpu out of a eMachine with a bad M.B. I would like to know if this CPU is compatiable with a(Gigabyte), GA-M68MT-D3(rev.2.3) M.B.
Hi.
We are not going to be able to tell you if the CPU is compatible with the Gigabyte motherboard without knowing the make and model of the motherboard that the CPU originally came out of. If you could provide us with that information we will be able to tell you the socket type and whether or not the CPU is compatible with the Gigabyte motherboard.
Jun 15, 2011 | Gigabyte Motherboard GAM68MTD3 AMD AM3...
I want to upgrade my processor , how can i figure out a compatible processor for my aspire ?
download and install this software ..and it will map you all the components that you have inside it ..including the cpu ..and the socket it has ..and all cpu made for this kinda socket ...(you will find out in it ) ..will be compatible ..or ...get to the support site of Acer ..and ask them the exact model of the cpu that will fit and be compatible with your laptop ..
here is the program ...
http://www.mediafire.com/file/mezeoyv1z41/everest.rar
and here the support site where you can write them ...
http://support.acer.com/us/en/default.aspx
Have a nice day !
Mar 16, 2011 | Acer Aspire 5720 6497 Laptop
I need to know what is this number of the amd processors like this HDX925WFGMBOX. if my motherboard dont say that number of that proccesor is saying that it doesn't support it?
Not neccessarily. The HDX####### number is the serial number of the processor. But as long as the cpu-socket types are the same on the cpu and motherboard, it should be compatible for the most part. Some cpu/motherboard combos require a BIOS update on the motherboard but thats probably not the issue here. AMD Phenom II's like yours are usually socket AM3, so just make sure that your motherboard is also a socket AM3 and you should be okay.
Visit your motherboard vendors website and look up the model number of your board. It should tell you what socket compatibility it has. Or you could even go to newegg.com and look up both the cpu and the motherboard to see if they match up.
Jan 22, 2011 | AMD PHENOM II X4 925 AM345NM 95W 2800MHZ...
I am wanting to upgrade the cpu to a faster
You dont need to know your southbridge info or anything like that, you just need to know the socket type for the processor. If they make a processor for the socket type, then you can assume it is compatible.
Jul 17, 2009 | Toshiba Satellite M45-S331 Notebook
MOTHERBOARDS Compatibility with this processor model.
the model you have given is not the correct model Number. Please check the link below & see where it says " E2160" this is the model number for the Intel CPU. please chk on your CPU & let me know the model you have. also most intel motherboards will support most of the CPU's. anyhow if you can give me the CPU model i can recommend some intel motherboards.
May 26, 2009 | Intel Motherboard
Cpu to support sse2
Highest model cpu your board can support is the AMD Athlon XP model 3200. This is not a dual core cpu. You would need to upgrade to a newer motherboard in order to use a dual or quad core cpu. Hope this helps.
Feb 03, 2009 | Asrock K7S41GX Motherboard
Motherboard compatibility
Which P4 3.0Ghz CPU do you have?
is it socket 478 or LGA-775?
Best thing to do is figure out what brand of motherboard you would prefer and then go to their website and look at their CPU compatibility chart for your CPU to find out which models support it
I personally would recommend ASUS motherboard and you can check out their compatibility chart here: http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us
Or if you prefer a different brand of motherboard you can find links to allmost every brand here: http://www.motherboard.cz/cpusupport/
Hope this info helps
Nov 24, 2008 | Intel Computers & Internet
New cpu for my motherboard
Hopefully it is compatible.
Here is how you can check. First look up the brand and model of the motherboard. Motherboards are usually labeled with that info.
Next go to the motherboard's manufacturer's website. Search Google using the brand name of the motherboard you should get a website in the results.
Then go to the products information of the website, or the downloads section and look up the model number of the motherboard you have.
You should be able to get specs on what CPU the motherboard supports. Or download a manual with specs.
Comment if you need more help.
Aug 16, 2008 | ASUS P4P800 SE (890552603657) Motherboard
How do I know if my motherboard is compatible with my processors voltage? where do i see the voltage indication of the motherboard?
Your board supports P4 CPU with 400Mhz bus speed. You can use any P4 CPU with 400MHz such as 2.4GHz/512/400. I think you can go as high as 2.8GHz.
Good Luck!
Jun 08, 2008 | EliteGroup P4VMM2 Motherboard
Asrock P4i65G motherboard/CPU
Hi Rlforeard, yes the BX80546PG3000E is compatible with the motherboard P4I65G.
http://www.alvio.com/product_view.aspx?product_ID=61048&source_ID=froogle
Here is the list from Asrock. CPU's supported for the Asrock P4I65G board. You will find you can go higher.
http://www.asrock.com/mb/cpu.asp?Model=P4I65G&s=478
Good Luck!
Mike
Jun 02, 2008 | Asrock Computers & Internet
Open Questions:
Gigabyte 965P-DS3 (GA965PDS3) Motherboard Logo
26 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
