Question about Air Tools & Compressors
My quincy air compressor model # qtd45ht won't load when the pressure goes down.
5 Suggested Answers
  • 19 Answers
SOURCE: Air leakage through pressure switch needle
1)Let your unit pump up.
2)Turn it off.
3)Find the supply line from the pump to the tank.
4)Remove the supply line from the pump head.
5a)If you hear air coming from the tank you have a bad check valve.
5b)If you do not hear air coming from the tank, you have a leaky
pressure switch.
Posted on Feb 02, 2009
SOURCE: 6 gallon proforce air compressor not building any pressure
You might have a broken valve. You'll need to pull the head apart. But make sure replacement parts are available first. Does this unit have an unloader valve on it ? That could also be your problem. You probably should check this first
Posted on Apr 01, 2009
  • 89 Answers
SOURCE: kobalt air compressor problem plastic tube gets a hole
EVERYONE WANTS TO MAKE EVERYTHING PLASTIC THESE DAYS. REMOVE PLASTIC LINE AND REPLACE WITH 1/4" FLEXIBLE COPPER ( ANY KIND ) JUST PICKUP A SMALL ROLL AT A HARDWARE STORE. MAKE SURE YOU GET A COUPLE OF FITTINGS, NUTS AND/OR FERRELS. HOPE THIS HELPS, JODY
Posted on Apr 20, 2009
  • 98 Answers
SOURCE: my air compressor won't restart
minimum pressure check valve is bad , does the compressor when it shuts off bleed air out at the pressure switch , if so does it continue till it starts back up , if so the unit is trying to start under a load. You have a bad minimum pressure valve usually located where the air line goes into the tank.
Posted on Jul 28, 2009
QGS-50 compressor runs fine for a couple hours then trips the breaker it runs about 180-200 deg allready replaced thermostat and cleaned coolers also when it reaches full pressure and unloads it doesnt...
Check the size of the breaker in your electric panel, then check the motor name plate on compressor. Make sure you know what voltage you have to determine switch amp draw that your motor will be pulling. Once you have the amp draw multiply that # by 1.75. That is the smallest breaker that you can use. If you take the same amp draw and multiply by 2.25 that is the largest breaker that you use. Somewhere between those two numbers there is a breaker out there for you, unless your panel is to small.
May 27, 2014 | Quincy Compressor 1624221408...
Compressor shuts down and will not allow enough pressure run machine
Sounds like the oil is low or the cooler is dirty. If that's not the case then you have a defective thermal valve.
Dec 17, 2013 | Quincy Compressor Quincy QGS Rotary Screw...
How much oil for a quincy compressor model #216
What type of gauge belongs on the side of a 216 quincy compressor?
Also were can i locate one?
Thank you!
Tom
Mar 24, 2013 | Honda Quincy 17 - Gallon Air Compressor...
Quincy model model QMB/T is leaking oil out of filter
tighten filter
check that the filter is not too tight and distorting the seal
replace the filter
Oct 24, 2012 | Quincy Compressor Quincy 30 Rotary Screw...
Compressor has no oil pressure but seems to be running good
If you're sure its not just a bad oil pressure gauge, and there is no pressure, the oil pump is probably bad. If you don't run it hard, it may still last awhile, running more like a "splash lube" compressor. Still, if this is a pressure lubed Quincy, it's a good compressor - I'd fix the oil pump and it'll last for years.
Dec 15, 2009 | Honda Quincy 17 - Gallon Air Compressor...
Need to know torque specs for rod and head bolts on a quincy model 350-11 air compresser
25-35 ft. lbs. Never saw any air compressor head bolts any other torque range If that number is a little squishy for you, call Quincy up tomorrow at
212-222-7700
Aug 21, 2009 | Air Tools & Compressors
Kicking overloads but not consistantly
First: Most all compessors use check valves at the tank and an unloader to allow the compressor to start without a load. Make sure that system is unloading and that check valve is not leaking causing head pressure at start. Second: Too frequent starts and stops will cause motor to overheat. Check Quincy manual for max starts per hour. enjoy
Nov 14, 2008 | Honda Quincy 17 - Gallon Air Compressor...
Air Tools & Compressors Logo
144 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
