Question about Sport & Outdoor - Others
I have a Johnson 6 seahorse, Modle #6R-73S, Serial # J3740818. what is the fuel to oil ratio?
  • 4 Answers
SOURCE: Is there a neutral switch on a johnson 4 hp
If it is like my Evenrude 4hp 'light twin' the answer is no. These motors are nick named 'pull and go'. Before you start the motor besure to get the boat pointed in the direction you want to go.
Posted on Aug 07, 2009
SOURCE: need owners manual for 1956 Johnson Seahorse 15hp
In order to solve the problem I needed to completly break down and diagram the entire motor. Not easy, but it worked. I started with the fuel system and made my way through till I had the motor broke all the way down to the pistons, and rebuilt it after making a diagram of every working and cast part. This included makeing note of part numbers and along with size, shape, and where the parts fit in aspect to the entire motor. In order to do any of this yourself mechanicale dtrafting paper will be needed and a lot of time.
Posted on Oct 25, 2009
  • 52086 Answers
SOURCE: i need to change a water pump on a johnson 6hp
unbolt lower unit and you will be right there . shift rods vary so check where it is and how to unhook.
Posted on Apr 25, 2010
emissionwiz
  • 80339 Answers
SOURCE: 35hpjohnson seahorse
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
Posted on Sep 04, 2012
  • 186 Answers
SOURCE: 1981 70 hp Johnson seahorse outboard motor oil mix ratio please
50:1 Ratio One pint of 2 cycle oil to six gallons of fuel.
Posted on Dec 28, 2014
I have a 40 s Johnson seahorse td20 with serial number 63191 , and I was wondering what year model is it? I gave 280.00 for it, did get a good deal ??
the serial number is not consistent with johnson serial numbers as all have 2 letters followed at the end by 2 numbers which indicates the year of manufacturer 9 ( ft17598 indicates it was mahe in 98)
There are pages on the net explaining when a serial number is used but it must be old as johnsons have used model numbers for identification since 1960's
probably better if you take it to a johnson service dealer as they may have the johnson factor list for serial numbers as you will have to identify it to get parts
go google and type in manufacture date of 40s johnson td 20 outboard serial number 63191
if that shows no results just cahange some words in the search
Jan 07, 2016 | Boating
Dec 28, 2014 | Boating
Evinrude outboards
Johnson and Evinrude carbureted 2-stroke outboards since 1964 require a 50:1 fuel to oil mixture (2%) on engines without an automatic oiling system - 6 gallons of gas to 1 pint of outboard oil.
Aug 30, 2014 | Garden
What is the oil to gas ratio in my 4 horse Evinrude< Model # E4BRHCOB Ser # B101702
50:1 since the late 60's
Too much oil will gum up the rings, smoke too much and foul plugs. Use ONLY major outboard manufacturers oil, Mercury, Yamaha, Johnson/Evinrude TCW-3. They work the best, and no alcohol fuel.
Jul 11, 2014 | Sierra International 18-3090 Marine...
Evinrude serial numbers 18902bc 53303
It looks like you have an old one....?
model # and serial # are on the mounting bracket, port side.
1980 and later, the model number will start with "J25" followed by 5 or 6 characters. there might be another letter in front of the "J".
1956 to 1980, most model #'s begin with the horsepower, before that, it's more random.
Commercial, military and racing versions each have their own model # sequence.
May 18, 2014 | Boating
Johnson serial numbers
if you have no plate on the transom clamp then some had a core plug on the side of engine , or take a picture of engine and send it to a dealer to age it !
Dec 16, 2013 | Boating
Johnson seahorse 6 hp
Check to see that you have proper air flow through the cowlling. It sounds like it's not getting enough air to the breather.
Dec 05, 2013 | Boating
Johnson Seahorse Manual 80 hp
depends on the age of the motor.OLD was 25 to 1 newer is 25 to 1 .
Jun 12, 2013 | Boating
Sport & Outdoor - Others Logo
169 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
