Question about Ricoh Aficio 1035 Copier
My copies comes out faintly. pls wat is/ are the cause(s) ?
  • 1,219 Answers
the light copies on these machine can be result of dirty optics. On digital machine when the optics are dirty the copy is light.
You should remove copy glass and clean the lenses and mirrors and glass with glass cleaner and polish it verry well.
Also the problem can be dirty laser unit.Worn developer, worn drum, charge roller,...
Hope that helps!
Posted on Aug 24, 2010
Canon ir3245 copier have faint copies
Run it thru the "cleaning " program. Look in Tools.
Jul 30, 2014 | Canon Office Equipment & Supplies
I went to the doctors for a blood test and fainted the doctor then checked my pulse when I came round and said it was quite low I now have to go back for an ecg could fainting have caused the low pulse
one reason could be low blood pressure, pls get it checked through a doctor. Drinking a mixture of common salt - sugar & water all mixed together is a home remedy to cope after fainting or having a spinning head.
May 06, 2014 | Heating & Cooling
Very Faint copies.\r\nCleaned Top glass, Mirror & change new drum Still very faint copies, one side very bad
clean the laser unit.as the problem appears to be from it.it gets dusty or dirty by toner then u will have faint copies.developing bias can also be a cause but then u have to call a rep.
Sep 06, 2011 | Canon Office Equipment & Supplies
Sc390
SC390 = Toner Density Sensor abormality
Possible causes:
  • Poor concentration of developer
  • Toner density sensor faulty
Are the prints/copies coming out ok? If the copies are very faint or heavily overtoned then changing the developer may cure the error code. If the copies look OK then you probably need to get the toner density sensor replaced by an engineer.
Hope this helps.
Feb 10, 2011 | Ricoh Aficio 450 Copier
I want now what's Common faults in Aficio 2035
THe main problems are toner spill form drom/dev units ..the transfer on the right hand door will have to be emptied every few months. the paper tray paper stops need to be checked as they come out of place and cause paper jams if not set in place..cahrge rollers can be troublesome if not cleaned every coulple of months and may cause dirty image at the sides or lines on copies..dust on laser **** glass can cause faint on sides of copies.. the fuser stripper fingers tat guide the paper need to be checked for toner under the points to stop paper jams in fuser and the lower guide plate entrance to the fuser needs to be cleaned off every now and then to stop crinklin of paper...apart from that good machine
Dec 17, 2009 | Ricoh Aficio 2035 Copier
Gestetner 3245 dev.bias setting....
Hi how you doing the main problem with changing the dev bias is that the gap between the drum charge and dev bias has been brought closer and so more toner is being put onto the drum for image density.. I take it you have cleaned the optics on the scanner mirrrors and that the laser **** glass has been cleaned as these effect the copy quality too.. if the dev hasnt been changed at the pm intervals it slowly looses its charge holding capabilities.. you should change at least at the 160k marks to keep quality good.. you could also adjust the laser power up so you have a stronger image formation..hope this helps..if you know the machine I would take the laser unit out too and take the cover off to see if there a dust coating in the image mirrors as this can cause faint copies over a long period.. Good Luck A
Jul 01, 2009 | Gestetner Office Equipment & Supplies
Sharp AR168D won't copy
There are small mirrors on the copy lamp, wipe with a clean dry soft cloth. Remove the drum unit and wipe upper part where the drum unit was and make sure the area is clean.
Mar 31, 2009 | Sharp AR-235 Copier
Screen still faint after changing module and screen
Which "module" did you change. The Inverter board is causing the "faintness" Replacing the screen will not fix it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 11, 2008 | Compaq Presario 700 470024-192 Notebook
Want to know the symtoms
Often, the error message "NTLDR is missing" simply means that, the file NTLDR could not be found in the root of the C drive. Most of my experiences are with faulty memory causing this. The file is actually in the HD but will not load properly into the memory. Often, cleaning or replacing the memory addresses the issue. In some cases, it may really be true that for some reason, said file was really gone or corrupted. I have successfully copied the file NTLDR from other PCs into the HD with the problem. Of course this would require physical removal of the HD in question and installing it as an external storage device using a USB adapter to a 2nd PC. I have yet to come across a case where the entire HD is corrupt due to missing NTLDR.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 27, 2008 | Hi-Val DVD Kit (DVD6X-00R1) Internal DVD...
My all in one wont copy/scan, but will print
If you arnt putting the original upside down then it will need scanner replaced, no easy fix... approx $Aus250.
Dec 13, 2007 | Brother MFC 9700 All-In-One Laser Printer
Ricoh Aficio 1035 Copier Logo
134 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
